7.10.28 Dyson Orbitals for Ionized or Attached States within the EOM-CCSD Formalism
Dyson orbitals can be used to compute total photodetachment/photoionization cross-sections, as well as angular distribution of photoelectrons. A Dyson orbital is the overlap between the N-electron molecular wave function and the N-1/N+1 electron wave function of the corresponding cation/anion:
ϕd⁢(1) =1N-1⁢∫ΨN⁢(1,…,n)⁢ΨN-1⁢(2,…,n)⁢d⁢2⁢⋯⁢𝑑n (7.105)
ϕd⁢(1) =1N+1⁢∫ΨN⁢(2,…,n+1),ΨN+1⁢(1,…,n+1)⁢d⁢2⁢⋯⁢d⁢(n+1) (7.106)
For the Hartree-Fock wave functions and within Koopmans’ approximation, these are just the canonical HF orbitals. For correlated wave functions, Dyson orbitals are linear combinations of the reference molecular orbitals:
ϕd =∑pγp⁢ϕp (7.107)
γp =⟨ΨN⁢|p+|⁢ΨN-1⟩ (7.108)
γp =⟨ΨN⁢|p|⁢ΨN+1⟩ (7.109)
The calculation of Dyson orbitals is straightforward within the EOM-IP/EA-CCSD methods, where cation/anion and initial molecule states are defined with respect to the same MO basis. Since the left and right CC vectors are not the same, one can define correspondingly two Dyson orbitals (left and right):
γpR=⟨Φ0⁢eT1+T2⁢LE⁢E⁢|p+|⁢RI⁢P⁢eT1+T2⁢Φ0⟩γpL=⟨Φ0⁢eT1+T2⁢LI⁢P⁢|p|⁢RE⁢E⁢eT1+T2⁢Φ0⟩ (7.110)
The norm of these orbitals is proportional to the one-electron character of the transition.
Dyson orbitals also offer qualitative insight visualizing the difference between molecular and ionized/attached states. In ionization/photodetachment processes, these orbitals can be also interpreted as the wave function of the leaving electron. For additional details, see Refs.  935 Oana C. M., Krylov A. I.
(2007), 127, pp. 234106.
and 936 Oana C. M., Krylov A. I.
(2009), 131, pp. 124114.
. Dyson orbitals can be used for computing total and differential photoelectron cross-sections using a stand-alone ezDyson code 444 Gozem S., Krylov A. I.
(2022), 12, pp. e1546.
or built-in Q-Chem’s functionality (see section 7.10.20.10).
Dyson orbitals can be computed both for valence states and core-level states; 1309 Vidal M. L., Krylov A. I., Coriani S.
(2019), 22, pp. 2693.
see Section 7.10.8 for calculations of Dyson orbitals within the FC-CVS-EOM framework.
The ezSpectra suite: An easy-to-use toolkit for spectroscopy modeling - Presented by Prof. Samer Gozem, Georgia State University
7.10.28.1 Dyson Orbitals Job Control
The calculation of Dyson orbitals is implemented for the ground (reference) and excited states ionization/electron attachment. To obtain the ground state Dyson orbitals one needs to run an EOM-IP/EA-CCSD calculation, request transition properties calculation by setting CC_TRANS_PROP = TRUE and CC_DO_DYSON = TRUE. The Dyson orbitals decomposition in the MO basis is printed in the output, for all transitions between the reference and all IP/EA states. At the end of the file, also the coefficients of the Dyson orbitals in the AO basis are available.
Two implementations of Dyson orbitals are currently available: (i) the original implementation in CCMAN; and (ii) new implementation in CCMAN2. The CCMAN implementation is using a diffuse orbital trick (i.e., EOM_FAKE_IPEA will be automatically set to TRUE in these calculations). Note: this implementation has a bug affecting the values of norms of Dyson orbitals (the shapes are correct); thus, using this code is strongly discouraged. The CCMAN2 implementation has all types of initial states available: Dyson orbitals from ground CC, excited EOM-EE, and spin-flip EOM-SF states; it is fully compatible with all helper features for EOM calculations, like FNO, RI, Cholesky decomposition. The CCMAN2 implementation can use a user-specified EOM guess (using EOM_USER_GUESS keyword and $eom_user_guess section), which is recommended for highly excited states (such as core-ionized states). In addition, CCMAN2 can calculate Dyson orbitals involving meta-stable states (see Section 7.10.9) and core-level states (see Section 7.10.8).
For calculating Dyson orbitals between excited or spin-flip states from the reference configuration and IP/EA states, same CC_TRANS_PROP = TRUE and CC_DO_DYSON = TRUE keywords have to be added to the combination of usual EOM-IP/EA-CCSD and EOM-EE-CCSD or EOM-SF-CCSD calculations. (However, note the separate keyword CC_DO_DYSON_EE = TRUE for CCMAN.) The IP_STATES keyword is used to specify the target ionized states. The attached states are specified by EA_STATES. The EA-SF states are specified by EOM_EA_BETA. The excited (or spin-flipped) states are specified by EE_STATES and SF_STATES. The Dyson orbital decomposition in MO and AO bases is printed for each EE/SF-IP/EA pair of states first for reference, then for all excited states in the order: CC-IP/EA1, CC-IP/EA2,…, EE/SF1 - IP/EA1, EE/SF1 - IP/EA2,…, EE/SF2 - IP/EA1, EE/SF2 - IP/EA2,…, and so on. CCMAN implementation keeps reference transitions separate, in accordance with separating keywords.
CC_DO_DYSON
CC_DO_DYSON
       CCMAN2: starts all types of Dyson orbitals calculations. Desired type is determined by requesting corresponding EOM-XX transitions CCMAN: whether the reference-state Dyson orbitals will be calculated for EOM-IP/EA-CCSD calculations.
       FALSE (the option must be specified to run this calculation)
       TRUE/FALSE
       none
CC_DO_DYSON_EE
CC_DO_DYSON_EE
       Whether excited-state or spin-flip state Dyson orbitals will be calculated for EOM-IP/EA-CCSD calculations with CCMAN.
       TRUE/FALSE
       none
Dyson orbitals are most easily visualized by setting IQMOL_FCHK = TRUE (equivalently, GUI = 2) and reading the resulting checkpoint file into IQmol. In addition to the canonical orbitals, the Dyson orbitals will appear under the Surfaces item in the Model View. For step-by-step instructions, see the ezDyson manual. Alternatively Dyson orbitals can be plotted using IANLTY = 200 and the $plots utility. Only the sizes of the box need to be specified, followed by a line of zeros:
$plots
   comment
   10   -2   2
   10   -2   2
   10   -2   2
   0     0   0    0
$plots
All Dyson orbitals on the Cartesian grid will be written in the resulting plot.mo file (only CCMAN). For RHF(UHF) reference, the columns order in plot.mo is: ϕ1l⁢r⁢α⁢(ϕ1l⁢r⁢β)⁢ϕ1r⁢l⁢α⁢(ϕ1r⁢l⁢β)⁢ϕ2l⁢r⁢α⁢(ϕ2l⁢r⁢β)⁢…
In addition, setting the MAKE_CUBE_FILES keyword to TRUE will create cube files for Dyson orbitals which can be viewed with Visual Molecular Dynamics (VMD)W. Humphrey, A. Dalke, and K. Schulten (1996), 15 or other programs; see Section 10.5.5 for details. This option is available for CCMAN and CCMAN2. The Dyson orbitals will be written to files mo.1.cube, mo.2.cube, … in the order ϕ1l⁢r⁢ϕ1r⁢l ϕ2l⁢r⁢ϕ2r⁢l⁢…. For meta-stable states, the real and imaginary parts of the Dyson orbitals are written to separate files in the order Re⁢(ϕ1l⁢r)⁢Re⁢(ϕ1r⁢l) Re⁢(ϕ2l⁢r)⁢Re⁢(ϕ2r⁢l)⁢…⁢Im⁢(ϕ1l⁢r)⁢Im⁢(ϕ1r⁢l) Im⁢(ϕ2l⁢r)⁢Im⁢(ϕ2r⁢l)⁢…
Note:  Visualization via the MolDen format is not available.
7.10.28.2 Examples
Example 7.142  Plotting grd-ex and ex-grd state Dyson orbitals for ionization of the oxygen molecule. The target states of the cation are 2Ag and 2B2⁢u. Works for CCMAN only.
   O    0.000  0.000  0.000
   O    1.222  0.000  0.000
   BASIS          6-31G*
   METHOD         eom-ccsd
   IP_STATES      [1,0,0,0,0,0,1,0] Target EOM-IP states
   CC_TRANS_PROP  true  request transition OPDMs to be calculated
   CC_DO_DYSON    true  calculate Dyson orbitals
   IANLTY         200
$plots
plots excited states densities and trans densities
   10   -2   2
   10   -2   2
   10   -2   2
   0     0   0    0
$plots
Example 7.143  Plotting ex-ex state Dyson orbitals between the 1st A12 excited state of the HO radical and the the 1st A1 and A2 excited states of HO-. Works for CCMAN only.
   H    0.000   0.000  0.000
   O    1.000   0.000  0.000
   METHOD             eom-ccsd
   BASIS              6-31G*
   IP_STATES          [1,0,0,0]  states of HO radical
   EE_STATES          [1,1,0,0]  excited states of HO-
   CC_TRANS_PROP      2          calculate transition properties
   CC_DO_DYSON        true       calculate Dyson orbitals for ionization from ex. states
   IANLTY             200
$plots
plot excited states densities and trans densities
   10   -2   2
   10   -2   2
   10   -2   2
   0     0   0    0
$plots
Example 7.144  Dyson orbitals for ionization of CO molecule; A1 and B1 ionized states requested.
   C  O  1.131
   CORRELATION           CCSD
   BASIS                 cc-pVDZ
   PURECART              111        5d, will be required for ezDyson
   IP_STATES             [1,0,1,0]  (A1,A2,B1,B2)
   CCMAN2                true
   CC_DO_DYSON           true
   CC_TRANS_PROP         true       necessary for Dyson orbitals job
   PRINT_GENERAL_BASIS   true       will be required for ezDyson
Example 7.145  Dyson orbitals for ionization of H2O; core (A1) state requested — ionization from O(1s).
   H1  O  0.955
   H2  O  0.955  H1  104.5
   CORRELATION           CCSD
   BASIS                 cc-pVTZ
   IP_STATES             [1,0,0,0]  (A1,A2,B1,B2)
   EOM_USER_GUESS        1          on, further defined in $eom_user_guess
   CCMAN2                true
   CC_DO_DYSON           true
   N_FROZEN_CORE         false
$eom_user_guess
Example 7.146  Dyson orbitals for ionization of NO molecule using EOM-EA and a closed-shell cation reference; A1 and B2 states requested.
   N   0.00000  0.00000  0.00000
   O   0.00000  0.00000  1.02286
   CORRELATION            CCSD
   BASIS                  aug-cc-pVTZ
   EA_STATES              [1,0,0,1] (A1,A2,B1,B2)
   CCMAN2                 true
   CC_DO_DYSON            true
Example 7.7.147  Dyson orbitals for detachment from the meta-stable Πg2 state of N-2.
   N   0.0   0.0    0.55
   N   0.0   0.0   -0.55
   GH  0.0   0.0    0.0
   METHOD            EOM-CCSD
   EA_STATES         [0,0,2,0,0,0,0,0]
   CC_MEMORY         5000
   MEM_STATIC        1000
   BASIS             GEN
   COMPLEX_CCMAN     TRUE
   CC_TRANS_PROP     TRUE
   CC_DO_DYSON       TRUE
   MAKE_CUBE_FILES   TRUE
   IANLTY            200
   FORCE_SYMMETRY_ON TRUE
$complex_ccman
   CS_HF             1
   CAP_TYPE          1
   CAP_X             2760
   CAP_Y             2760
   CAP_Z             4880
   CAP_ETA           400
$plots
plot Dyson orbitals
   50 -10.0 10.0
   50 -10.0 10.0
   50 -10.0 10.0
   0 0 0 0
$basis
N    0
S    8    1.000000
   1.14200000E+04    5.23000000E-04
   1.71200000E+03    4.04500000E-03
   3.89300000E+02    2.07750000E-02
   1.10000000E+02    8.07270000E-02
   3.55700000E+01    2.33074000E-01
   1.25400000E+01    4.33501000E-01
   4.64400000E+00    3.47472000E-01
   5.11800000E-01   -8.50800000E-03
S    8    1.000000
   1.14200000E+04   -1.15000000E-04
   1.71200000E+03   -8.95000000E-04
   3.89300000E+02   -4.62400000E-03
   1.10000000E+02   -1.85280000E-02
   3.55700000E+01   -5.73390000E-02
   1.25400000E+01   -1.32076000E-01
   4.64400000E+00   -1.72510000E-01
   5.11800000E-01    5.99944000E-01
S    1    1.000000
   1.29300000E+00    1.00000000E+00
S    1    1.000000
   1.78700000E-01    1.00000000E+00
P    3    1.000000
   2.66300000E+01    1.46700000E-02
   5.94800000E+00    9.17640000E-02
   1.74200000E+00    2.98683000E-01
P    1    1.000000
   5.55000000E-01    1.00000000E+00
P    1    1.000000
   1.72500000E-01    1.00000000E+00
D    1    1.000000
   1.65400000E+00    1.00000000E+00
D    1    1.000000
   4.69000000E-01    1.00000000E+00
F    1    1.000000
   1.09300000E+00    1.00000000E+00
S    1    1.000000
   5.76000000E-02    1.00000000E+00
P    1    1.000000
   4.91000000E-02    1.00000000E+00
D    1    1.000000
   1.51000000E-01    1.00000000E+00
F    1    1.000000
   3.64000000E-01    1.00000000E+00
GH   0
S    1    1.000000
   2.88000000E-02    1.00000000E+00
S    1    1.000000
   1.44000000E-02    1.00000000E+00
S    1    1.000000
   0.72000000E-02    1.00000000E+00
S    1    1.000000
   0.36000000E-02    1.00000000E+00
S    1    1.000000
   0.18000000E-02    1.00000000E+00
S    1    1.000000
   0.09000000E-02    1.00000000E+00
P    1    1.000000
   2.45000000E-02    1.00000000E+00
P    1    1.000000
   1.22000000E-02    1.00000000E+00
P    1    1.000000
   0.61000000E-02    1.00000000E+00
P    1    1.000000
   0.305000000E-02    1.00000000E+00
P    1    1.000000
   0.152500000E-02    1.00000000E+00
P    1    1.000000
   0.076250000E-02    1.00000000E+00
D    1    1.000000
   0.755000000E-01    1.00000000E+00
D    1    1.000000
   0.377500000E-01    1.00000000E+00
D    1    1.000000
   0.188750000E-01    1.00000000E+00
D    1    1.000000
   0.094375000E-01    1.00000000E+00
D    1    1.000000
   0.047187500E-01    1.00000000E+00
D    1    1.000000
   0.023593750E-01    1.00000000E+00
Example 7.148  Dyson orbitals for ionization of triplet O2 and O-2 at slightly stretched (relative to the equilibrium O2 geometry); B3⁢g states are requested.
   EOM-IP-CCSD/6-311+G* and EOM-EA-CCSD/6-311+G* levels of theory,
   UHF reference.  Start from O2:
    1) detach electron - ionization of neutral (alpha IP).
    2) attach electron, use EOM-EA w.f. as initial state
       - ionization of anion (beta EA).
   O   0.00000  0.00000  0.00000
   O   0.00000  0.00000  1.30000
   CORRELATION           CCSD
   BASIS                 6-311(3+)G*
   PURECART              2222          6d, will be required for ezDyson
   EOM_IP_ALPHA          [0,0,0,1,0,0,0,0]  (Ag,B1g,B2g,B3g,Au,B1u,B2u,B3u)
   EOM_EA_BETA           [0,0,0,1,0,0,0,0]  (Ag,B1g,B2g,B3g,Au,B1u,B2u,B3u)
   CCMAN2                true
   CC_DO_DYSON           true
Example 7.149  Dyson orbitals for ionization of formaldehyde from the first excited state AND from the ground state.
   O     1.535338855      0.000000000     -0.438858006
   C     1.535331598     -0.000007025      0.767790994
   H     1.535342484      0.937663512      1.362651452
   H     1.535342484     -0.937656488      1.362672535
   CORRELATION           CCSD
   BASIS                 6-31G*
   CCMAN2                true    new Dyson code
   EE_STATES             [1]
   EOM_IP_ALPHA          [1]
   EOM_IP_BETA           [1]
   CC_DO_DYSON           true
Example 7.150  Dyson orbitals for core ionization of Li atom use Li+ as a reference, get neutral atom via EOM-EA get 1st excitation for the cation via EOM-EE totally: core ionization AND 1st ionization of Li atom.
   Li   0.00000  0.00000  0.00000
   CORRELATION            CCSD
   BASIS                  6-311+G*
   EE_STATES              [1,0,0,0,0,0,0,0]
   EA_STATES              [1,0,0,0,0,0,0,0]
   EOM_NGUESS_SINGLES     5             to converge to the lowest EA state
   CC_DO_DYSON            true
Example 7.151  Dyson orbitals for ionization of CH2 from high-spin triplet reference and from the lowest SF state.
   C
   H  1 rCH
   H  1 rCH 2 aHCH
   rCH    = 1.1167
   aHCH   = 102.07
   CORRELATION           CCSD
   BASIS                 6-31G*
   SCF_GUESS             core
   CC_SYMMETRY           false
   SF_STATES             [1]
   EOM_IP_ALPHA          [2]     one should be careful to request
   EOM_EA_BETA           [2]     meaningful spin for EA/IP state(s)
   CC_DO_DYSON           true
   IQMOL_FCHK            true    generate formatted checkpoint file for IQMol
Example 7.152  Dyson orbitals for ionization of SO- using EOM-EA to describe the anion states and EOM-SF to describe the neutral; both sets of EOM states are generated using neutral triplet reference.
SO-, calculating Dyson orbitals using EOM-EA to describe
both sets of EOM states are generated using triplet reference.
S    0.0000000    0.0000000   -0.5241891
O    0.0000000    0.0000000    1.0676951
JOBTYPE¯¯¯SP
METHOD¯          ¯EOM-CCSD
BASIS                  ¯6-31G*
PURECART¯¯111 needed for ezDyson
EA_BETA¯¯        [0,0,0,1]  anion state
SF_STATES               [2,2,0,0]  neutral states
CC_DO_DYSON¯¯true
CC_TRANS_PROP¯¯true
PRINT_GENERAL_BASIS¯true  needed for ezDyson
$trans_prop
state_list
ea_beta   4 1      !state 1
sf_states 1 1    !state 2
sf_states 1 2    !state 3
sf_states 2 1
sf_states 2 2
end_list
state_pair_list
1 2   ! transition 1 <-> 2
1 3
1 4
1 5
end_pairs
calc dyson
