5.6.3 User-Defined RSH Functionals
As pointed out in Ref.  330 Dreuw A., Weisman J. L., Head-Gordon M.
(2003), 119, pp. 2943.
and elsewhere, the description of charge-transfer excited states within density functional theory (or more precisely, time-dependent DFT, which is discussed in Section 7.3) requires full (100%) non-local HF exchange, at least in the limit of large donor–acceptor distance. Hybrid functionals such as B3LYP 89 Becke A. D.
(1993), 98, pp. 5648.
, 1222 Stephens P. J. et al.
J. Phys. Chem.
(1994), 98, pp. 11623.
and PBE0 20 Adamo C., Scuseria G. E., Barone V.
(1999), 111, pp. 2889.
that are well-established and in widespread use, however, employ only 20% and 25% HF exchange, respectively. While these functionals provide excellent results for many ground-state properties, they cannot correctly describe the distance dependence of charge-transfer excitation energies, which are enormously underestimated by most common density functionals. This is a serious problem in any case, but it is a catastrophic problem in large molecules and in non-covalent clusters, where TDDFT often predicts a near-continuum of spurious, low-lying charge transfer states. 710 Lange A., Herbert J. M.
(2007), 3, pp. 1680.
, 712 Lange A. W., Herbert J. M.
J. Am. Chem. Soc.
(2009), 131, pp. 124115.
The problems with TDDFT’s description of charge transfer are not limited to large donor–acceptor distances, but have been observed at ∼2 Å separation, in systems as small as uracil–(H2O)4. 710 Lange A., Herbert J. M.
Rydberg excitation energies also tend to be substantially underestimated by standard TDDFT.
One possible avenue by which to correct such problems is to parameterize functionals that contain 100% HF exchange, though few such functionals exist to date. An alternative option is to attempt to preserve the form of common GGAs and hybrid functionals at short range (i.e., keep the 25% HF exchange in PBE0) while incorporating 100% HF exchange at long range, which provides a rigorously correct description of the long-range distance dependence of charge-transfer excitation energies, but aims to avoid contaminating short-range exchange-correlation effects with additional HF exchange. The separation is accomplished using the range-separation ansatz that was introduced in Section 5.3. In particular, functionals that use 100% HF exchange at long range (cx,LR=1 in Eq. (5.13)) are known as “long-range-corrected” (LRC) functionals. An LRC version of PBE0 would, for example, have cx,SR=0.25.
To fully specify an LRC functional, one must choose a value for the range separation parameter ω in Eq. (5.12). In the limit ω→0, the LRC functional in Eq. (5.13) reduces to a non-RSH functional where there is no “SR” or “LR”, because all exchange and correlation energies are evaluated using the full Coulomb operator, r12-1. Meanwhile the ω→∞ limit corresponds to a new functional, Ex⁢cRSH=Ec+ExHF. Full HF exchange is inappropriate for use with most contemporary GGA correlation functionals, so the latter limit is expected to perform quite poorly. Values of ω>1.0 bohr-1 are likely not worth considering, according to benchmark tests. 717 Lange A. W., Rohrdanz M. A., Herbert J. M.
J. Phys. Chem. B
(2008), 112, pp. 6304.
, 1100 Rohrdanz M. A., Herbert J. M.
(2008), 129, pp. 034107.
Evaluation of the short- and long-range HF exchange energies is straightforward, 24 Adamson R. D., Dombroski J. P., Gill P. M. W.
(1999), 20, pp. 921.
so the crux of any RSH functional is the form of the short-range GGA exchange functional, and several such functionals are available in Q-Chem. These include short-range variants of the B88 and PBE exchange described by Hirao and co-workers, 573 Iikura H. et al.
(2001), 115, pp. 3540.
, 1198 Song J. W. et al.
(2007), 126, pp. 154105.
called μB88 and μPBE in Q-Chem, 1093 Richard R. M., Herbert J. M.
(2011), 7, pp. 1296.
and an alternative formulation of short-range PBE exchange proposed by Scuseria and co-workers, 515 Henderson T. M., Janesko B. G., Scuseria G. E.
(2008), 128, pp. 194105.
which is known as ωPBE. These functionals are available in Q-Chem thanks to the efforts of the Herbert group. 1100 Rohrdanz M. A., Herbert J. M.
, 1101 Rohrdanz M. A., Martins K. M., Herbert J. M.
(2009), 130, pp. 054112.
By way of notation, the terms “μPBE”, “ωPBE”, etc., refer only to the short-range exchange functional, Ex,SRDFT in Eq. (5.13). These functionals could be used in “screened exchange” mode, as described in Section 5.3, as for example in the HSE03 functional, 536 Heyd J., Scuseria G. E., Ernzerhof M.
(2003), 118, pp. 8207.
therefore the designation “LRC-ωPBE”, for example, should only be used when the short-range exchange functional ωPBE is combined with 100% Hartree-Fock exchange in the long range.
In general, LRC-DFT functionals have been shown to remove the near-continuum of spurious charge-transfer excited states that appear in large-scale TDDFT calculations. 717 Lange A. W., Rohrdanz M. A., Herbert J. M.
J. Phys. Chem. B
However, certain results depend sensitively upon the value of the range-separation parameter ω, 717 Lange A. W., Rohrdanz M. A., Herbert J. M.
J. Phys. Chem. B
J. Am. Chem. Soc.
, 1287 Uhlig F. et al.
(2014), 118, pp. 7507.
especially in TDDFT calculations (Section 7.3) and therefore the results of LRC-DFT calculations must therefore be interpreted with caution, and probably for a range of ω values. This can be accomplished by requesting a functional that contains some short-range GGA exchange functional (ωPBE or μPBE, in the examples mentioned above), in combination with setting the $rem variable LRC_DFT = TRUE, which requests the addition of 100% Hartree-Fock exchange in the long-range. Basic job-control variables and an example can be found below. The value of the range-separation parameter is then controlled by the variable OMEGA, as shown in the examples below.
LRC_DFT
LRC_DFT
       Controls the application of long-range-corrected DFT
       FALSE (or 0) Do not apply long-range correction. TRUE (or 1) Add 100% long-range Hartree-Fock exchange to the requested functional.
       The $rem variable OMEGA must also be specified, in order to set the range-separation parameter.
OMEGA
OMEGA
       Sets the range-separation parameter, ω, also known as μ, in functionals based on Hirao’s RSH scheme.
       No default
COMBINE_K
COMBINE_K
       Controls separate or combined builds for short-range and long-range K
       FALSE (or 0) Build short-range and long-range K separately (twice as expensive as a global hybrid) TRUE (or 1) Build short-range and long-range K together (≈ as expensive as a global hybrid)
       Most pre-defined range-separated hybrid functionals in Q-Chem use this feature by default. However, if a user-specified RSH is desired, it is necessary to manually turn this feature on.
HFK_SR_COEF
HFK_SR_COEF
       Sets the coefficient for short-range HF exchange
       n Corresponding to n/100000000
HFK_LR_COEF
HFK_LR_COEF
       Sets the coefficient for long-range HF exchange
       100000000
Example 5.6  Application of LRC-μBOP to (H2⁢O)2-.
   The value of omega is 0.47 by default but can
   be overwritten by specifying OMEGA.
   O           1.347338    -0.017773    -0.071860
   H           1.824285     0.813088     0.117645
   H           1.805176    -0.695567     0.461913
   O          -1.523051    -0.002159    -0.090765
   H          -0.544777    -0.024370    -0.165445
   H          -1.682218     0.174228     0.849364
   EXCHANGE      LRC-BOP
   BASIS         6-311(1+,2+)G*
   XC_GRID       2
   LRC_DFT       TRUE
   OMEGA         300      ! = 0.300 bohr**(-1)
Rohrdanz et al. 1101 Rohrdanz M. A., Martins K. M., Herbert J. M.
published a thorough benchmark study of both ground- and excited-state properties using the LRC-ωPBEh functional, in which the “h” indicates a short-range hybrid (i.e., the presence of some short-range HF exchange). Empirically-optimized parameters of cx,SR=0.2 (see Eq. (5.13)) and ω=0.2 bohr-1 were obtained, 1101 Rohrdanz M. A., Martins K. M., Herbert J. M.
and these parameters are taken as the defaults for LRC-ωPBEh. Caution is warranted, however, especially in TDDFT calculations for large systems, as excitation energies for states that exhibit charge-transfer character can be rather sensitive to the precise value of ω. 712 Lange A. W., Herbert J. M.
J. Am. Chem. Soc.
In such cases (and maybe in general), the “tuning” procedure described in Section 5.6.4 is recommended.
Example 5.7  Application of LRC-ωPBEh to the C2⁢H4–C2⁢F4 dimer at 5 Å separation.
    This example uses the "optimal" parameter set discussed above.
    It can also be run by setting METHOD = LRC-wPBEh.
   C           0.670604    0.000000    0.000000
   C          -0.670604    0.000000    0.000000
   H           1.249222    0.929447    0.000000
   H           1.249222   -0.929447    0.000000
   H          -1.249222    0.929447    0.000000
   H          -1.249222   -0.929447    0.000000
   C           0.669726    0.000000    5.000000
   C          -0.669726    0.000000    5.000000
   F           1.401152    1.122634    5.000000
   F           1.401152   -1.122634    5.000000
   F          -1.401152   -1.122634    5.000000
   F          -1.401152    1.122634    5.000000
   EXCHANGE      GEN
   BASIS         6-31+G*
   LRC_DFT       TRUE
   OMEGA         200      ! = 0.2 a.u.
   CIS_N_ROOTS   4
   CIS_TRIPLETS  FALSE
$xc_functional
   C  PBE   1.00
   X  wPBE  0.80
   X  HF    0.20
By adding 100% Hartree-Fock exchange to the asymptotic Coulomb operator, LRC functionals guarantee that an electron and hole experience an asymptotic interaction potential 1/r. This is correct for a molecule in the gas phase, but to simulate a material one might desire an asymptotic behavior of 1/(ε⁢r), where ε is the (static) dielectric constant of the material. In conjunction with “optimal tuning” of the range-separation parameter, as described in Section 5.6.4, such functionals have been shown to afford accurate fundamental gaps for organic photovoltaic materials, 681 Kronik L., Kümmel S.
Adv. Mater.
(2018), 30, pp. 1706560.
and are naturally combined with polarizable continuum models (Section 11.2.3) that employ the same dielectric constant. 121 Bhandari S. et al.
(2019), 14, pp. 6287.
These have come to be called screened RSH (sRSH) functionals. 681 Kronik L., Kümmel S.
Adv. Mater.
An XC function of this type can be expressed generically as 33 Alam B., Morrison A. F., Herbert J. M.
J. Phys. Chem. C
(2020), 124, pp. 24653.
Ex⁢csRSH=cx,SR⁢Ex,SRHF+ε-1⁢Ex,LRHF+(ε-1-cx,SR)⁢Ex,SRDFT+(1-ε-1)⁢Ex,LRDFT+EcDFT, (5.17)
which should be compared to Eq. (5.13) that provides the generic form for an RSH functional. Although the RSH formalism allows for an arbitrary coefficient cx,LR for the long-range Hartree-Fock exchange term, as in Eq. (5.13), this implies that the asymptotic electron–hole interaction has the form cx,LR/r rather than 1/r. 330 Dreuw A., Weisman J. L., Head-Gordon M.
As such, LRC functionals are a particular class of RSH functionals where cx,LR=1, ensuring proper asymptotic behavior in vacuum. Along the same lines, sRSH functionals set cx,LR=ε-1 to ensure proper asymptotic behavior in a dielectric material. Using Eq. (5.17), users may construct sRSH functionals by means of a $xc_functional input section.
