10.6 Electric Fields
10.6.1 Overview
The derivatives of electrostatic potential (ESP) with respect to positions give electric fields, which is a fundamental physical quantity that has been shown to play an important role in applications ranging from vibrational spectroscopy to molecular and enzyme catalysis. Similar to the case of ESP, Q-Chem is able to compute the values of E-field on nuclear positions or a given grid, which is also controlled by the $rem variable ESP_GRID. The calculation of electric field is turned on when the value of ESP_EFIELD >0:
ESP_EFIELD
ESP_EFIELD
       Triggers the calculation of ESP and/or electric field at nuclear positions or on a given grid of points
       0 Compute ESP only 1 Compute both ESP and electric field 2 Compute electric field only
Example 10.25  Calculate the electric field on the nuclear positions of a water molecule
   O    -0.9112629280    1.0922672019    1.0200719528
   H    -1.7568362275    1.5186695533    1.2826042030
   H    -0.5592940377    1.7449530375    0.3694007293
   METHOD       b3lyp
   BASIS        cc-pvtz
   ESP_GRID     0
   ESP_EFIELD   2 ! compute E-field on atomic positions
Q-Chem 6 supports two DFT-based electronic structure methods for the evaluation of electric fields (and also ESPs) arising from a chemical environment (e.g. solvents) at the specific sites of a “probe” molecule (typically at the atomic positions). These methods, whose details are provided in Ref.  1454 Zheng C. et al.
Nat. Chem.
(2022), 14, pp. 891.
, involve a partition of the electron density of the entire system into those belonging to the central system and to the environment. The first approach is based on the SPADE partitioning scheme (see Section 11.6.1), 236 Claudino D., Mayhall N. J.
(2019), 15, pp. 1053.
which transforms the converged occupied MOs obtained from a standard SCF calculation and then assigns them to different parts of a system. The second approach is based on DFT calculations using absolutely localized molecular orbitals (ALMOs, see Section 12.5.1), 646 Khaliullin R. Z., Head-Gordon M., Bell A. T.
(2006), 124, pp. 204105.
which invokes fragmentation of the supersystem from the beginning and the fragment MOs are then variationally optimized when they are polarized by other fragments. Both of these methods then construct the electron density for the “environment” part of the supersystem (ρE) using the correspondingly assigned occupied MOs, and the ESP and electric field at a specific site of the central “probe” system can be calculated using the electron density and nuclear charges of the environment. Denoting the embedded central system and its environment as S and E, respectively, the ESP and electric field vector at site A∈S (ϕA and 𝐅A) can be evaluated using
ϕA=∑B∈EZB|𝐫A-𝐫B|-∫ρE⁢(𝐫)|𝐫A-𝐫|⁢d𝐫 (10.36)
and
𝐅A=-∇^⁢ϕA=∑B∈EZB⁢(𝐫A-𝐫B)|𝐫A-𝐫B|3-∫ρE⁢(𝐫)⁢(𝐫A-𝐫)|𝐫A-𝐫|3⁢d𝐫. (10.37)
The current implementation of these methods requires two Q-Chem jobs to be performed for a single environment ESP and electric field calculation. In the first job, one performs an SCF or SCF-MI calculation and generate the occupied MOs or electron density assigned to the environment; in the second job, the environment MOs or electron density is read in and the ESP and electric fields are calculated using Eqs. (10.36) and (10.37). Note that in the second job, the embedded central system (“probe”) is represented using ghost atoms to probe the nuclear positions; and for SPADE and ALMO the SCF_GUESS for the 2nd job must be READ and READ_DEN, respectively. To evaluate the potential and field at the nuclear positions of the central system, one should set ESP_GRID = 0; for other options (e.g. evaluating the ESP and its gradient on grid points), one should refer to the documentation of “ESP_GRID” in Section 10.5.8.
ALMO_EFIELD
ALMO_EFIELD
       Calculate the environment ESP/E-field using ALMO-based partitioning
       TRUE In job 1, it saves the electron density for the environment constructed from ALMOs; In job 2, it reads in the electron density (must be together with SCF_GUESS = READ_DEN) FALSE Don’t do ALMO-based ESP/field calculations
       Required for both jobs in ALMO-based electric field calculations
ALMO_EFIELD_PROBE_FRGM
       Specify the index of the probe fragment in ALMO-based ESP and electric field calculations
       n Specify the nth fragment as the probe
Example 10.26  Using the SPADE partitioning method to calculate the ESP and electric field arising from the environment (the second H2O molecule) at the atomic positions of the 1st H2O
jobtype  sp
method   b3lyp
basis    6-31G(d)
env_method b3lyp
gen_scfman_embed true
spade_partition  true
scf_convergence  8
embedding_early_stop true ! skip the embedded SCF
integral_symmetry    false
point_group_symmetry false
@O  -1.551007  -0.114520   0.000000
@H  -1.934259   0.762503   0.000000
@H  -0.599677   0.040712   0.000000
method      b3lyp
basis       6-31G(d)
scf_guess   read
skip_scfman true ! generate results directly from the MOs read in
esp_grid    0
esp_efield  1    ! compute ESP and E-field on atomic positions
Example 10.27  Using ALMO-based partitioning to calculate the ESP and electric field arising from the environment (the second H2O molecule) at the atomic positions of the 1st H2O
jobtype  sp
method   b3lyp
basis    6-31G(d)
scf_convergence  8
frgm_method   stoll  ! doing SCF-MI (ALMO) calculation
scfmi_mode    1
almo_efield   true   ! save electron density belonging to the 2nd fragment
jobtype sp
method  b3lyp
basis   6-31G(d)
scf_guess  read_den
almo_efield true   ! with read_den, this will read in the density saved in the 1st job
skip_scfman true
esp_grid    0
