9.4 Constrained Optimization
9.4.7 Atomic Confining Potentials as Alternatives to Constrained Optimization
In principle, the same effect of constrained optimization using fixed atoms can be achieved instead using soft harmonic confining potentials of the form
Vconf⁢(𝐫1,𝐫2,…)=12⁢∑ik⁢∥𝐫i-𝐫i0∥2. (9.42)
This represents an external potential that confines the ith atom (having coordinates 𝐫i) around the position 𝐫i0. In applications to cluster models of enzymes (as a low-cost alternative to QM/MM simulations), it is necessary to lock certain atoms at their crystallographic positions in order to relax the geometry (in the gas phase or in continuum solvent) without collapsing the active-site model. 1167 Siegbahn P. E. M., Himo F.
(2011), 1, pp. 323.
, 284 Dasgupta S., Herbert J. M.
J. Phys. Chem. B
(2020), 124, pp. 1137.
Use of a confining potential allows this optimization to proceed in an unconstrained manner, using delocalized internal coordinates (rather than Cartesian coordinates) for efficiency, yet achieves the same effect as the traditional fixed-atom approach that is widely used in cluster models of enzymatic reactions. 1167 Siegbahn P. E. M., Himo F.
(2011), 1, pp. 323.
Moreover, the use of harmonic confining potentials does not result in imaginary frequencies that can plague fixed-atom optimizations, making it straightforward to compute zero-point vibrational corrections. 284 Dasgupta S., Herbert J. M.
J. Phys. Chem. B
Harmonic confining potentials are activated by setting the $rem variable HARM_OPT to true, listing the indices of the confined atoms in the $harmonic_opt section and their corresponding equilibrium positions (𝐫i0) in the $coords section.
HARM_OPT
HARM_OPT
       Controls whether the job uses confining potentials
       False
       False Do not use the potential True Use the potential
       False
HOATOMS
HOATOMS
       Controls the number of confined atom
       No default
       User defined
HARM_FORCE
HARM_FORCE
       Sets the force constant for harmonic confiner, in units of N/m.
       No default
       User defined
Example 9.14  Optimization using soft harmonic confining potentials
   C         2.2847229688   -0.3069830925   -0.2968221397
   C         0.9156471557    0.1503924513    0.1693932675
   N        -0.0576877706   -0.7876400788    0.0645249649
   H         2.9837678662    0.5043669375   -0.1693203557
   H         2.2497378474   -0.5929607607   -1.3422589452
   H         2.6126794028   -1.1626691284    0.2825927880
   O         0.6966207559    1.2669942030    0.6077661092
   C        -1.4350712383   -0.4874947903    0.4670886412
   H         0.1463602169   -1.6783001309   -0.3307859180
   C        -2.1768099264    0.3412632672   -0.5936684676
   H        -1.3995705380    0.0636682083    1.3955334557
   H        -1.9421824240   -1.4270154508    0.6422037013
   H        -1.6624625664    1.2829541077   -0.7297597438
   H        -3.1943263155    0.5415731987   -0.2762358302
   H        -2.2051967614   -0.1880845317   -1.5391034623
   JOBTYPE       OPT
   METHOD        HF
   BASIS         3-21G
   NO_REORIENT   true
   HARM_OPT      1    ! Turn on harmonic confining potential
   HOATOMS       2    ! No. of confined atoms
   HARM_FORCE    450  ! Force constant of the potential
   POINT_GROUP_SYMMETRY False
$harmonic_opt
   1  10 ! indices of the confined atoms
$coords !coordinates of confined atoms
   C1     2.2847229688   -0.3069830925   -0.2968221397
   C10   -2.1768099264    0.3412632672   -0.5936684676
