11.6.3 Previous Implementation Based on “EmbedMan”
The original implementation of the projection-based embedding in Q-Chem was through the “EmbedMan” module, which was based on the old SCF module that is no longer the default. This implementation applies a level-shift projection operator to enforce the orthogonality between orbitals belonging to fragments 1 and 2. For the 1-in-2 case, the Fock matrix can be written as
𝐟(1)=𝐡+𝐉⁢[γ(1)+γ(2)]+νx⁢c⁢[γ(1)+γ(2)]+μ⁢𝐏(2) (11.118)
where 𝐏(2) is the level-shift projection operator constructed as:
𝐏α⁢β(2)=[𝐒⁢γ(2)⁢𝐒]α⁢β (11.119)
where γ(2) is the localized density of fragment 2, and 𝐒 is the AO overlap matrix. Upon convergence, an energy correction term is added to the final energy to account for the level-shift projection operator contribution to the Fock matrix energy. The correction term is calculated as the following:
Ecorrection=μ*tr⁢(γ(1)⁢𝐏(2)) (11.120)
Once the KS-DFT energy of fragment 1-in-2 is computed, a post-SCF method can be applied to this converged density to obtain the high-level QM additive energy of fragment 1. The same procedure can be repeated for fragment 2-in-1, without continuing to a post-SCF method to yield the low-level QM additive energy of the fragment 2. These energies are then summed to yield the total energy.
To run an embedding calculation through the “EmbedMan” module, one must split the super-molecular system into two fragments indexed 1 and 2, and set EMBEDMAN to 1. This is done through the standard Q-Chem fragment input syntax. Two separate jobs must be run to find the total energy of fragment 1-in-2 at a high level QM theory, and fragment 2-in-1 at a low level QM theory. The order of the fragments in the $molecule section determines which fragment will undergo the high level QM. The user must submit a separate job for the 2-in-1 low-level QM calculation, with the order of the fragments reversed and EMBED_THEORY set to 0, which is the default value. The user must then add the final energies of the calculations to determine the total QM/QM embedded energy.
For the current Q-Chem implementation of density embedding, it is necessary to specify the basis as MIXED, which requires to define the basis for each individual atom. When using CCSD(T), one should specify CCMAN2 as TRUE, for Q-Chem’s most updated coupled-cluster code. The current implementation of density embedding only works in combination with the following settings: SCF_ALGORITHM = DIIS, INCFOCK = 0, and PURECART = 222. It is also recommended that users disable symmetry for calculations with INTEGRAL_SYMMETRY = FALSE, and POINT_GROUP_SYMMETRY = FALSE. Refer to the sample input for correct job settings.
EMBEDMAN
EMBEDMAN
       Turns density embedding on.
       0 Do not use density embedding. 1 Turn on density embedding.
       Use EMBEDMAN for QM/QM density embedded calculations.
EMBED_THEORY
EMBED_THEORY
       Specifies post-DFT method performed on fragment one.
       0 No post HF method, only DFT on fragment one. 1 Perform CCSD(T) calculation on fragment one. 2 Perform MP2 calculation on fragment one.
       This should be 1 or 2 for the high-level QM calculation of fragment 1-in-2, and 0 for fragment 2-in-1 low-level QM calculation.
EMBED_MU
EMBED_MU
       Specifies exponent value of projection operator scaling factor, μ [Eqs. (11.118) and (11.120)].
       7
       n μ=10n.
       Values of 2 - 7 are recommended. A higher value of μ leads to better orthogonality of the fragment MOs but μ>107 introduces numerical noise. μ<102 results in non-additive terms becoming too large. Energy corrections are fairly insensitive to changes in μ within the range of 102-107.
EMBED_THRESH
EMBED_THRESH
       Specifies threshold cutoff for AO contribution used to determine which MOs belong to which fragments
       500
       n Threshold =n/1000
       Acceptable values range from 0 to 1000. Should only need to be tuned for non-highly localized MOs
Example 11.11.39  Input for a MP2/PBE density embedding calculation of He-in-HF. The sum of the final energies for these two jobs will yield the total QM/QM energy.
2023/4/5 use core guess becuase autosad and sad do not work with basis mixed
   He      -4.63032        2.10289       -1.62399
   F       -8.00612        1.74605       -1.25581
   H       -7.40964        1.84462       -0.47756
   EXCHANGE        PBE
   CORRELATION     PBE
   BASIS           mixed  ! Must specify basis sets per atom in $basis section below
   PURECART        222
   MAX_SCF_CYCLES  100
   SCF_ALGORITHM   DIIS
   INCFOCK         0
   CC_SYMMETRY     false
   EMBEDMAN        1      ! Turning density embedding on
   EMBED_THEORY    2      ! Running MP2 on fragment 1 in 2, or He in FH
   EMBED_MU        7      ! Default value
   EMBED_THRESH    500    ! Default value for assigning MOs to fragments
   SCF_GUESS       CORE
   INTEGRAL_SYMMETRY    false
   POINT_GROUP_SYMMETRY false
$basis
  he 1
  6-31G
  f 2
  6-31G
  h 3
  6-31G
  EXCHANGE        PBE
  CORRELATION     PBE
  BASIS           mixed
  PURECART        222
  MAXSCF          100
  SCF_ALGORITHM   DIIS
  INCFOCK         0
  EMBEDMAN        1
  EMBED_THEORY    0      ! There will be no post-DFT calculations for HF-in-He
  SCF_GUESS       core
$basis
  f 1
  6-31G
  h 2
  6-31G
  he 3
  6-31G
