6.8 Size-Consistent Brillouin-Wigner Perturbation Theory
6.8.1 Introduction
While second-order Møller-Plesset perturbation theory (MP2) offers the simplest and most cost-effective ab initio correlation energy, it requires a separate formulation for degenerate states because the MP2 energy diverges in the zero-gap limit. Second-order Brillouin-Wigner perturbation theory (BW2) requires no such reformulation, as the second-order energy given by,
Ec(2)=-14⁢∑i⁢j⁢a⁢b|⟨i⁢j|⁢|a⁢b⟩|2Δi⁢ja⁢b+Ec(2) (6.27)
is finite when the orbital energy gap Δi⁢ja⁢b=εa+εb-εi-εj is zero due to the presence of the correlation energy in the denominator. However, the BW2 correlation energy is not size-consistent in the sense that it does not satisfy E⁢(A∪B)=E⁢(A)+E⁢(B) for two distant, noninteracting subsystems A and B, severely limiting its applicability to chemistry.
Recently, Carter-Fenk and Head-Gordon introduced a size-consistent-to-second-order Brillouin-Wigner perturbation theory (BW-s2) that retains this essential property while remaining finite for zero-gap systems. 178 Carter-Fenk K., Head-Gordon M.
(2023), 158, pp. 234108.
This theory, based on a repartitioning of the zeroth-order Hamiltonian, results in a slightly-modified amplitude equation. Whereas the MP2 amplitudes can be found by solving,
Δi⁢j⁢k⁢la⁢b⁢c⁢d⋅tk⁢lc⁢d=-⟨i⁢j|⁢|a⁢b⟩, (6.28)
the BW-s2 amplitude equation contains a regularizing tensor,
(Δi⁢j⁢k⁢la⁢b⁢c⁢d+Ri⁢j⁢k⁢la⁢b⁢c⁢d)⋅tk⁢lc⁢d=-⟨i⁢j|⁢|a⁢b⟩ (6.29)
In the above equations Δi⁢j⁢k⁢la⁢b⁢c⁢d is composed of Fock matrix elements and reduces to the familiar Δi⁢ja⁢b when canonical orbitals are used, and
Ri⁢j⁢k⁢la⁢b⁢c⁢d=α2⁢(Wi⁢k⁢δj⁢l+δi⁢k⁢Wj⁢l)⁢δa⁢c⁢δb⁢d (6.30)
where,
Wi⁢j=12⁢∑k⁢a⁢b(ti⁢ka⁢b⁢⟨j⁢k|⁢|a⁢b⟩+tj⁢ka⁢b⁢⟨i⁢k|⁢|a⁢b⟩) (6.31)
This form of 𝐖 was chosen because it is size-consistent, leading to a size-consistent BW-s2 correlation energy. Physically, 𝐖 represents the correlation energy of a Koopmans’ (static orbital) ionization process. Thus, the occupied orbitals in BW-s2 are imbued with correlation such that the occupied/virtual gap increases. After rotating the occupied orbitals into a basis where 𝚫+𝑹 is diagonal, the BW-s2 working equation looks like that of MP2,
Ec(2)=-14⁢∑i⁢j⁢a⁢b|⟨i⁢j|⁢|a⁢b⟩~|2εa+εb-ε~i-ε~j (6.32)
but the orbitals and corresponding anti-symmetrized two-electron integrals have been rotated into the new basis.
In equation 6.30 there is an implicit parameter α that controls the regularization strength. Initially, this parameter was set to α=1 to obtain the exact result for the two-electron two-orbital system of minimal-basis H2 at the dissociation limit, but α was later tuned to achieve much more accurate results for a wide array of chemical problems ranging from thermochemical properties to noncovalent interaction energies and closed-shell transition-metal reaction energies. 184 Carter-Fenk K., Shee J., Head-Gordon M.
(2023), 159, pp. 171104.
The optimal α value for the resultant BW-s2(α) approach varies somewhat between chemical problems, but was found to be more flexible than gap-dependent regularizer parameters like κ-, σ-, or σ2-MP2. A “universal” parameter of α=4 was suggested as a compromise to achieve the best all-around results for a wide array of chemical properties. 184 Carter-Fenk K., Shee J., Head-Gordon M.
