6.6.1 Introduction
For a molecule of fixed size, increasing the number of basis functions per atom, n, leads to 𝒪⁢(n4) growth in the number of significant four-center two-electron integrals, since the number of non-negligible product charge distributions, |μ⁢ν⟩, grows as 𝒪⁢(n2). As a result, the use of large (high-quality) basis expansions is computationally costly. Perhaps the most practical way around this “basis set quality” bottleneck is the use of auxiliary basis expansions. 360 Feyereisen M., Fitzgerald G., Komornicki A.
(1993), 208, pp. 359.
, 331 Dunlap B. I.
(2000), 2, pp. 2113.
, 620 Jung Y. et al.
Proc. Natl. Acad. Sci. USA
(2005), 102, pp. 6692.
The ability to use auxiliary basis sets to accelerate a variety of electron correlation methods, including both energies and analytical gradients, is a major feature of Q-Chem.
|μ⁢ν⟩≈|μ⁢ν~⟩=∑K|K⟩⁢Cμ⁢νK (6.19)
∑L⟨K|L⟩⁢Cμ⁢νL=⟨K|μ⁢ν⟩ (6.20)
⟨μ⁢ν|λ⁢σ⟩≈⟨μ⁢ν~|λ⁢σ~⟩=∑K,LCμ⁢νL⁢⟨L|K⟩⁢Cλ⁢σK (6.21)
Standardized auxiliary basis sets have been developed by the Karlsruhe group for second-order perturbation (MP2) calculations of the correlation energy. 1337 Weigend F. et al.
(1998), 294, pp. 143.
, 1339 Weigend F., Kohn A., Hättig C.
(2002), 116, pp. 3175.
Using these basis sets, absolute errors in the correlation energy are small (e.g., below 60 μHartree per atom), and errors in relative energies are smaller still At the same time, speedups of 3–30× are realized. This development has made the routine use of auxiliary basis sets for electron correlation calculations possible.
Correlation calculations that can take advantage of auxiliary basis expansions are described in the remainder of this section (MP2, and MP2-like methods) and in Section 6.18 (simplified active space coupled cluster methods such as PP, PP(2), IP, RP). These methods automatically employ auxiliary basis expansions when a valid choice of auxiliary basis set is supplied using the AUX_BASIS_CORR or AUX_BASIS keyword which is used in the same way as the BASIS keyword. The PURECART $rem is no longer needed here, even if using a auxiliary basis that does not have a predefined value. There is a built-in automatic procedure that provides the effect of the PURECART $rem in these cases by default.
