7.11.2 The Algebraic Diagrammatic Construction (ADC) Scheme
The Algebraic Diagrammatic Construction (ADC) of the polarization propagator is an excited state method originating from Green’s function theory. It has first been derived employing the diagrammatic perturbation expansion of the polarization propagator using the Møller-Plesset partition of the Hamiltonian. 1130 Schirmer J.
Phys. Rev. A
(1982), 26, pp. 2395.
An alternative derivation is available in terms of the intermediate state representation (ISR), 1129 Schirmer J., Trofimov A. B.
(2004), 120, pp. 11449.
which will be presented in the following.
As starting point for the derivation of ADC equations via ISR serves the exact N electron ground state |Ψ0N⟩. From |Ψ0N⟩ a complete set of correlated excited states is obtained by applying physical excitation operators C^J.
|Ψ¯JN⟩=C^J⁢|Ψ0N⟩ (7.111)
with
{C^J}={ca†ci;ca†cb†cicj,i<j,a<b;…} (7.112)
Yet, the resulting excited states do not form an orthonormal basis. To construct an orthonormal basis out of the |Ψ¯JN⟩ the Gram-Schmidt orthogonalization scheme is employed successively on the excited states in the various excitation classes starting from the exact ground state, the singly excited states, the doubly excited states etc.. This procedure eventually yields the basis of intermediate states {|Ψ~JN⟩} in which the Hamiltonian of the system can be represented forming the Hermitian ADC matrix
MI⁢J=⟨Ψ~IN|H^-E0N|Ψ~JN⟩ (7.113)
Here, the Hamiltonian of the system is shifted by the exact ground state energy E0N. The solution of the secular ISR equation
𝐌𝐗=𝐗⁢𝛀, with ⁢𝐗†⁢𝐗=𝟏 (7.114)
yields the exact excitation energies Ωn as eigenvalues. From the eigenvectors the exact excited states in terms of the intermediate states can be constructed as
|ΨnN⟩=∑JXn⁢J⁢|Ψ~JN⟩ (7.115)
This also allows for the calculation of dipole transition moments via
Tn=⟨ΨnN|μ^|Ψ0N⟩=∑JXn⁢J†⁢⟨Ψ~JN|μ^|Ψ0N⟩, (7.116)
as well as excited state properties via
On=⟨ΨnN|o^|ΨnN⟩=∑I,JXn⁢I†⁢Xn⁢J⁢⟨Ψ~IN|o^|ΨJN⟩, (7.117)
where On is the property associated with operator o^.
Up to now, the exact N-electron ground state has been employed in the derivation of the ADC scheme, thereby resulting in exact excitation energies and exact excited state wave functions. Since the exact ground state is usually not known, a suitable approximation must be used in the derivation of the ISR equations. An obvious choice is the nth order Møller-Plesset ground state yielding the nth order approximation of the ADC scheme. The appropriate ADC equations have been derived in detail up to third order. 1278 Trofimov A. B., Schirmer J.
J. Phys. B: At. Mol. Opt. Phys.
(1995), 28, pp. 2299.
, 1280 Trofimov A. B., Stelter G., Schirmer J.
(1999), 111, pp. 9982.
, 1281 Trofimov A. B., Stelter G., Schirmer J.
(2002), 117, pp. 6402.
Due to the dependency on the Møller-Plesset ground state the nth order ADC scheme should only be applied to molecular systems whose ground state is well described by the respective MP(n) method.
As in Møller-Plesset perturbation theory, the first ADC scheme which goes beyond the non-correlated wave function methods in Section 7.2 is ADC(2). ADC(2) is available in a strict and an extended variant which are usually referred to as ADC(2)-s and ADC(2)-x, respectively. The strict variant ADC(2)-s scales with the 5th power of the basis set. The quality of ADC(2)-s excitation energies and corresponding excited states is comparable to the quality of those obtained with CIS(D) (Section 7.9) or CC2. More precisely, excited states with mostly single excitation character are well-described by ADC(2)-s, while excited states with double excitation character are usually found to be too high in energy. The ADC(2)-x variant which scales as the sixth power of the basis set improves the treatment of doubly excited states, but at the cost of introducing an imbalance between singly and doubly excited states. As result, the excitation energies of doubly excited states are substantially decreased in ADC(2)-x relative to the states possessing mostly single excitation character with the excitation energies of both types of states exhibiting relatively large errors. Still, ADC(2)-x calculations can be used as a diagnostic tool for the importance doubly excited states in the low-energy region of the spectrum by comparing to ADC(2)-s results. A significantly better description of both singly and doubly excited states is provided by the third order ADC scheme ADC(3). The accuracy of excitation energies obtained with ADC(3) is almost comparable to CC3, but at computational costs that scale with the sixth power of the basis set only. 489 Harbach P. H., Wormit M., Dreuw A.
(2014), 141, pp. 064113.
