12.6 Second-Generation ALMO-EDA Method
12.6.4 Further Decomposition of the Frozen Energy
The frozen interaction energy in ALMO-EDA is defined as the energy difference between the unrelaxed frozen (Heitler-London) wave function and the isolated fragments. In other literature (e.g. Ref.  555 Hopffgarten M., Frenking G.
(2012), 2, pp. 43.
), this interaction is often decomposed in a classical fashion:
Δ⁢Efrz=Δ⁢Eeleccls+Δ⁢EPaulicls, (12.5)
where the contribution from permanent electrostatics is defined as the Coulomb interaction between isolated fragment charge distributions:
Δ⁢Eeleccls=∑A<B∫r1∫r2ρAtot⁢(𝐫1)⁢1𝐫12⁢ρBtot⁢(𝐫2)⁢d𝐫1⁢d𝐫2 (12.6)
and the remainder constitutes the Pauli (or exchange) term. Such a decomposition (referred to as the classical decomposition below) is associated with two issues: (i) the evaluation of permanent electrostatics makes use of the “promolecule" state (whose density is the simple sum of monomer densities) rather than a properly anti-symmetrized wave function; (ii) when dispersion-corrected density functionals are used, the Pauli term contains dispersion interaction and thus loses its original meaning.
Horn et al. 558 Horn P. R., Mao Y., Head-Gordon M.
(2016), 144, pp. 114107.
proposed a new scheme to further decompose the frozen term into contributions from permanent electrostatics (ELEC), Pauli repulsion (PAULI) and dispersion (DISP):
Δ⁢Efrz=Δ⁢Eelec+Δ⁢EPauli+Δ⁢Edisp (12.7)
This approach is compatible with the use of all kinds of density functionals except double hybrids, and all three components of the FRZ term are computed with the antisymmetrized frozen wave function. The key step of this method is the orthogonal decomposition of the 1PDM associated with the frozen wave function into contributions from individual fragments: 𝐏frz=∑A𝐏~A. This is achieved by minimizing an objective function as follows:
Ω=∑AEA⁢[𝐏~A]-EA⁢[𝐏A] (12.8)
while interfragment orthogonality is enforced between 𝐏~As. The readers are referred to Ref.  558 Horn P. R., Mao Y., Head-Gordon M.
for more details about the orthogonal decomposition.
The ELEC term is then defined as the Coulomb interaction between distorted fragment densities (ρ~A⁢(𝐫)):
Δ⁢Eelec=∑A<B∫r1∫r2ρ~Atot⁢(𝐫1)⁢1𝐫12⁢ρ~Btot⁢(𝐫2)⁢d𝐫1⁢d𝐫2. (12.9)
The DISP term is evaluated by subtracting the dispersion-free part of the total exchange-correlation (XC) interaction, where an auxiliary “dispersion-free" XC (DFXC) functional is used in company with the primary (target) XC functional:
Δ⁢Edisp=(Exc⁢[𝐏frz]-∑AExc⁢[𝐏~A])-(ExcDF⁢[𝐏frz]-∑AExcDF⁢[𝐏~A]). (12.10)
It has been suggested 838 Mao Y. et al.
Annu. Rev. Phys. Chem.
(2021), 72, pp. 641.
that HF is an appropriate DFXC for use with dispersion-inclusive or dispersion-corrected hybrid functionals such as ωB97M-V or B3LYP-D3, while revPBE is appropriate for semi-local functionals such as B97M-V. However, more recent work suggests that for hybrid GGA functionals (e.g., PBE0-D3), the correlation energy should be included in the DFXC, which would then be HF-PBE rather than HF alone. 448 Gray M., Herbert J. M.
Annu. Rep. Comput. Chem.
(2024), 20, pp. 1.
This avoids putting the correlation contribution to electrostatics and Pauli repulsion into the dispersion term, and affords better agreement with dispersion energies from symmetry-adapted perturbation theory.
The remainder of the frozen interaction goes into the PAULI term, which includes the net repulsive interaction given by Eq. (12.8) and the “dispersion-free" part of the XC interaction:
Δ⁢EPauli=∑A(EA⁢[𝐏~A]-EA⁢[𝐏A])+(ExcDF⁢[𝐏frz]-∑AExcDF⁢[𝐏~A]). (12.11)
The PAULI term and the ELEC term can also be combined together and reported as the dispersion-free frozen (DFFRZ) term if desired.
In Q-Chem’s implementation of “EDA2", the classical frozen decomposition and the new scheme defined by Eqs. (12.9)–(12.11) are both computed by default. The classical ELEC term only depends on monomer properties and the distances between fragments, therefore, it can be particularly useful for scenarios such as force field development (as the reference for permanent electrostatics). When the DISP term calculated by the new scheme is available, a modified classical Pauli term 835 Mao Y. et al.
(2016), 12, pp. 5422.
is also reported, which is simply defined as
Δ⁢EPaulimod=Δ⁢EPaulicls-Δ⁢Edisp, (12.12)
i.e., the dispersion contribution is removed from the classical Pauli term computed using its original definition. The overall decomposition of the frozen energy with the classical scheme is given by
Δ⁢Efrz=Δ⁢Eeleccls+Δ⁢EPaulimod+Δ⁢Edisp (12.13)
Alternatively, this can also be achieved without performing the orthogonal decomposition, by setting EDA_CLS_DISP to TRUE. This also evaluates the DISP term via Eq. (12.10) except that undistorted monomer densities ({𝐏A}) are used instead of their distorted counterparts ({𝐏~A}):
Δ⁢Edisp=(Exc⁢[𝐏frz]-∑AExc⁢[𝐏A])-(ExcDF⁢[𝐏frz]-∑AExcDF⁢[𝐏A]). (12.14)
FRZ_ORTHO_DECOMP
FRZ_ORTHO_DECOMP
       Perform the decomposition of frozen interaction energy based on the orthogonal decomposition of the 1PDM associated with the frozen wave function.
       FALSE (automatically set to TRUE by EDA2 options 1–5)
       FALSE Do not perform the orthogonal decomposition. TRUE Perform the frozen energy decomposition using orthogonal fragment densities.
       Use default value automatically set by “EDA2". Note that users are allowed to turn off the orthogonal decomposition by setting FRZ_ORTHO_DECOMP to -1. Also, for calculations that involve ECPs, it is automatically set to FALSE since unreasonable results will be produced otherwise.
FRZ_ORTHO_DECOMP_CONV
       Convergence criterion for the minimization problem that gives the orthogonal fragment densities.
       6
       n 10-n
       Use the default unless tighter convergence is preferred.
EDA_CLS_ELEC
EDA_CLS_ELEC
       Perform the classical decomposition of the frozen term.
       FALSE Do not compute the classical ELEC and PAULI terms. TRUE Perform the classical decomposition.
EDA_CLS_DISP
EDA_CLS_DISP
       Compute the DISP contribution without performing the orthogonal decomposition, which will then be subtracted from the classical PAULI term.
       FALSE Use the DISP term computed with orthogonal decomposition (if available). TRUE Use the DISP term computed using undistorted monomer densities.
       Set it to TRUE when orthogonal decomposition is not performed.
DISP_FREE_X
DISP_FREE_X
       Specify the employed “dispersion-free" exchange functional.
       HF
       Exchange functionals (e.g. revPBE) or exchange-correlation functionals (e.g. B3LYP) supported by Q-Chem.
       HF is recommended for hybrid (primary) functionals (e.g.ωB97X-V) and revPBE for semi-local ones (e.g.B97M-V). Other reasonable options (e.g. B3LYP for B3LYP-D3) can also be applied.
DISP_FREE_C
DISP_FREE_C
       Specify the employed “dispersion-free" correlation functional.
       Correlation functionals supported by Q-Chem.
       Put the appropriate correlation functional paired with the chosen exchange functional (e.g. put PBE if DISP_FREE_X is revPBE); put NONE if DISP_FREE_X is set to an exchange-correlation functional.
