9.8 Nonadiabatic Couplings and Optimization of Minimum-Energy Crossing Points
9.8.1 Nonadiabatic Couplings
Conical intersections are degeneracies between Born-Oppenheimer potential energy surfaces that facilitate nonadiabatic transitions between excited states, i.e., internal conversion and intersystem crossing processes, both of which represent a breakdown of the Born-Oppenheimer approximation. 858 Matsika S., Krause P.
Annu. Rev. Phys. Chem.
(2011), 62, pp. 621.
, 525 Herbert J. M. et al.
Acc. Chem. Res.
(2016), 49, pp. 931.
Although simultaneous intersections between more than two electronic states are possible, 858 Matsika S., Krause P.
consider for convenience the two-state case, and let
𝐇=(HJ⁢J⁢(𝐑)HJ⁢K⁢(𝐑)HJ⁢K∗⁢(𝐑)HK⁢K⁢(𝐑)). (9.46)
denote the matrix representation of the vibronic (vibrational + electronic) Hamiltonian [Eq. (4.2)] in a basis of two electronic states, J and K. (Electronic degrees of freedom have been integrated out of this expression, and 𝐑 represents the remaining, nuclear coordinates.) By definition, the Born-Oppenheimer states are the ones that diagonalize 𝐇 at a particular molecular geometry 𝐑, and thus two conditions must be satisfied in order to obtain degeneracy in the Born-Oppenheimer representation: HJ⁢J=HK⁢K and HJ⁢K=0. As such, degeneracies between two Born-Oppenheimer potential energy surfaces exist in subspaces of dimension Nint-2, where Nint=3⁢Natoms-6 is the number of internal (vibrational) degrees of freedom (assuming the molecule is non-linear). This (Nint-2)-dimensional subspace is known as the seam space because the two states are degenerate everywhere within this space. In the remaining two degrees of freedom, known as the branching space, the degeneracy between Born-Oppenheimer surfaces is lifted by an infinitesimal displacement, which in a three-dimensional plot resembles a double cone about the point of intersection, hence the name conical intersection.
The branching space is defined by the span of a pair of vectors 𝐠J⁢K and 𝐡J⁢K. The former is simply the difference in the gradient vectors of the two states in question,
𝐠J⁢K=∂⁡EJ∂⁡𝐑-∂⁡EK∂⁡𝐑, (9.47)
and is readily evaluated at any level of theory for which analytic energy gradients are available (or less-readily, via finite difference, if they are not!). The definition of the nonadiabatic coupling vector 𝐡J⁢K, on the other hand, is more involved and not directly amenable to finite-difference calculations:
𝐡J⁢K=⟨ΨJ|(∂⁡H^/∂⁡𝐑)|ΨK⟩. (9.48)
This is closely related to the derivative coupling vector
𝐝J⁢K=⟨ΨJ⁢|(∂/∂⁡𝐑)|⁢ΨK⟩=𝐡J⁢KEJ-EK. (9.49)
The latter expression for 𝐝J⁢K demonstrates that the coupling between states becomes large in regions of the potential surface where the two states are nearly degenerate. The relative orientation and magnitudes of the vectors 𝐠J⁢K and 𝐡J⁢K determined the topography around the intersection, i.e., whether the intersection is “peaked” or “sloped”; 52 Atchity G. J., Xantheas S. S., Ruedenberg K.
(1991), 95, pp. 1862.
, 1415 Yarkony D. R.
(2001), 114, pp. 2601.
see Ref.  525 Herbert J. M. et al.
Acc. Chem. Res.
for a pedagogical overview.
Algorithms to compute the nonadiabatic couplings 𝐝J⁢K are not widely available in quantum chemistry codes, but thanks to the efforts of the Herbert and Subotnik groups, they are available in Q-Chem when the wave functions ΨJ and ΨK, and corresponding electronic energies EJ and EK, are computed at the CIS or TDDFT level, 354 Fatehi S. et al.
(2011), 135, pp. 234105.
, 1433 Zhang X., Herbert J. M.
(2014), 141, pp. 064104.
, 1434 Zhang X., Herbert J. M.
(2015), 142, pp. 064109.
, 959 Ou Q. et al.
(2015), 142, pp. 064114.
or at the corresponding spin-flip (SF) levels of theory (SF-CIS or SF-TDDFT). The spin-flip implementation 1433 Zhang X., Herbert J. M.
is particularly significant, because only that approach—and not traditional spin-conserving CIS or TDDFT—affords correct topology around conical intersections that involve the ground state.
To understand why, suppose that J in Eq. (9.46) represents the ground state; call it J=0 for definiteness. In linear response theory (TDDFT) or in CIS (by virtue of Brillouin’s theorem), the coupling matrix elements between the reference (ground) state and all of the excited states vanish identically, hence H0⁢K⁢(𝐑)≡0. This means that there is only one condition to satisfy in order to obtain degeneracy, hence the branching space is one- rather than two-dimensional, for any conical intersection that involves the ground state. 761 Levine B. G. et al.
Mol. Phys.
(2006), 104, pp. 1039.
(For intersections between two excited states, the topology should be correct.) In the spin-flip approach, however, the reference state has a different spin multiplicity than the target states; if the latter have spin quantum number S, then the reference state has spin S+1. This has the effect that the ground state of interest (spin S) is treated as an excitation, and thus on a more equal footing with excited states of the same spin, and it rigorously fixes the topology problem around conical intersections. 1433 Zhang X., Herbert J. M.
Acc. Chem. Res.
This can have consequences for simulation of internal conversion to the ground state, where for example S1 lifetimes may be significantly affected by warping of the potential energy surfaces around the S1/S0 intersection in conventional TDDFT. 1436 Zhang X., Herbert J. M.
(2021), 155, pp. 124111.
Nonadiabatic (derivative) couplings are available for both CIS and TDDFT. The CIS nonadiabatic couplings can be obtained from direct differentiation of the wave functions with respect to nuclear positions. 354 Fatehi S. et al.
For TDDFT, the same procedure can be carried out to calculate the approximate nonadiabatic couplings, in what has been termed the “pseudo-wave function” approach. 960 Ou Q. et al.
(2014), 141, pp. 024114.
Formally more rigorous TDDFT nonadiabatic couplings derived from quadratic response theory are also available, although they are subject to certain undesirable, accidental singularities if for the two states J and K in Eq. (9.48), the energy difference |EJ-EK| is quasi-degenerate with the excitation energy ωI=EI-E0 for some third state, I. 1434 Zhang X., Herbert J. M.
, 959 Ou Q. et al.
As such, the pseudo-wave function method is the recommended approach for computing nonadiabatic couplings with TDDFT, although in the spin flip case the pseudo-wave function approach is rigorously equivalent to the pseudo-wave function approach, and is free of singularities. 1434 Zhang X., Herbert J. M.
Finally, we note that there is mounting evidence that SF-TDDFT calculations are most accurate when used with functionals containing ∼50% Hartree-Fock exchange, 1156 Shao Y., Head-Gordon M., Krylov A. I.
(2003), 118, pp. 4807.
, 566 Huix-Rotllant M. et al.
(2010), 12, pp. 12811.
and many studies with this method have used the BH&HLYP functional; see Refs.  525 Herbert J. M. et al.
Acc. Chem. Res.
and for reviews. The BH&HLYP functional combines LYP correlation is combined with Becke’s “half and half” (BH&H) exchange functional, consisting of 50% Hartree-Fock exchange and 50% Becke88 exchange (EXCHANGE = BHHLYP in Q-Chem.)
