6.13 Coupled Cluster Active Space Methods
6.13.5 Local Pair Models for Valence Correlations Beyond Doubles
Working with Prof. Head-Gordon at Berkeley, John Parkhill has developed implementations for pair models which couple 4 and 6 electrons together quantitatively. Because these truncate the coupled cluster equations at quadruples and hextuples respectively they have been termed the “Perfect Quadruples” and “Perfect Hextuples” models. These can be viewed as local approximations to CASSCF. The PQ and PH models are executed through an extension of Q-Chem’s coupled cluster code, and several options defined for those models will have the same effects although the mechanism may be different (CC_DIIS_START, CC_DIIS_SIZE, CC_DOV_THRESH, CC_CONV, etc.).
In the course of implementation, the non-local coupled cluster models were also implemented up to T^6. Because the algorithms are explicitly sparse their costs relative to the existing implementations of CCSD are much higher (and should never be used in lieu of an existing CCMAN code), but this capability may be useful for development purposes, and when computable, models above CCSDTQ are highly accurate. To use PQ, PH, their dynamically correlated “+SD” versions or this machine generated cluster code set: METHOD = MGC.
MGC_AMODEL
MGC_AMODEL
       Choice of approximate cluster model.
       Determines how the CC equations are approximated:
       0 Local Active-Space Amplitude iterations (pre-calculate GVB orbitals with your method of choice (RPP is good)). 7 Optimize-Orbitals using the VOD 2-step solver. (Experimental-only use with MGC_AMPS = 2, 24 ,246) 8 Traditional Coupled Cluster up to CCSDTQPH. 9 MR-CC version of the Pair-Models. (Experimental)
MGC_NLPAIRS
MGC_NLPAIRS
       Number of local pairs on an amplitude.
       Must be greater than 1, which corresponds to the PP model. 2 for PQ, and 3 for PH.
MGC_AMPS
MGC_AMPS
       Choice of Amplitude Truncation
       2≤ n ≤ 123456, a sorted list of integers for every amplitude which will be iterated. Choose 1234 for PQ and 123456 for PH
MGC_LOCALINTS
MGC_LOCALINTS
       Pair filter on an integrals.
       Enforces a pair filter on the 2-electron integrals, significantly reducing computational cost. Generally useful for more than 1 pair locality.
MGC_LOCALINTER
MGC_LOCALINTER
       Pair filter on an intermediate.
       Any nonzero value enforces the pair constraint on intermediates, significantly reducing computational cost. Not recommended for ≤ 2 pair locality
