13.5.3 Job Control for the NEO-SCF methods
13.5.3.1 General Keywords
The NEO method is a natural extension of the SCF method and it inherits most of its functionalities. Thus, the keywords that are used in the SCF Job Control are used in the NEO-SCF methods with a few additional keywords. The NEO-SCF methods require definition of the nuclear basis sets (see Examples for more information). Refer to Ref.  271 Culpitt T. et al.
(2019), 150, pp. 201101.
for selection of the protonic basis sets. Only pure (spherical) Gaussian basis sets are currently available. The following three $rem variables must be specified in order to run NEO-SCF calculations:
NEO
NEO
       Enable a NEO-SCF calculation.
       TRUE Enable a NEO-SCF calculation. FALSE Disable a NEO-SCF calculation.
       Set to TRUE if desired.
METHOD
METHOD
       No default
       NAME Use METHOD = NAME, where NAME is one of the following: HF for Hartree-Fock theory; one of the DFT methods listed in Section 5.3.5.;
BASIS
BASIS
       Specifies the electronic basis sets to be used.
       No default basis set
       General, Gen User defined ($basis keyword required). Symbol Use standard basis sets as per Chapter 8. Mixed Use a mixture of basis sets (see Chapter 8).
In addition, the following $rem variables, that appear in the conventional SCF calculations can be used to customize the NEO-SCF calculation:
SCF_CONVERGENCE
SCF_CONVERGENCE
       NEO-SCF is considered converged when the electronic wave function error is less that 10-SCF⁢_⁢CONVERGENCE. Adjust the value of THRESH at the same time. (Starting with Q-Chem 3.0, the DIIS error is measured by the maximum error rather than the RMS error as in earlier versions.)
       5 For single point energy calculations. 8 For geometry optimizations.
       User-defined
NEO_N_SCF_CONVERGENCE
       NEO-SCF is considered converged when the nuclear wave function error is less that 10-NEO⁢_⁢N⁢_⁢SCF⁢_⁢CONVERGENCE.
       7
       User-defined
UNRESTRICTED
UNRESTRICTED
       FALSE Closed-shell systems. TRUE Open-shell systems.
       FALSE Constrain the spatial part of the alpha and beta orbitals to be the same. TRUE Do not Constrain the spatial part of the alpha and beta orbitals.
       The ROHF method is not available. Note that for unrestricted calculations on systems with an even number of electrons it is usually necessary to break α/β symmetry in the initial guess, by using SCF_GUESS_MIX or providing $occupied information (see Section 4.4 on initial guesses).
MAX_SCF_CYCLES
MAX_SCF_CYCLES
       50
       n n>0 User-selected.
SCF_ALGORITHM
SCF_ALGORITHM
       DIIS Pulay DIIS.
       DIIS Pulay DIIS. DM Direct minimizer. DIIS_DM Uses DIIS initially, switching to direct minimizer for later iterations (See THRESH_DIIS_SWITCH, MAX_DIIS_CYCLES). DIIS_GDM Use DIIS and then later switch to geometric direct minimization (See THRESH_DIIS_SWITCH, MAX_DIIS_CYCLES). GDM Geometric Direct Minimization. RCA Relaxed constraint algorithm RCA_DIIS Use RCA initially, switching to DIIS for later iterations (see THRESH_RCA_SWITCH and MAX_RCA_CYCLES described later in this chapter) ROOTHAAN Roothaan repeated diagonalization.
       In the NEO methods, the GDM procedure is recommended.
JOBTYPE
JOBTYPE
       Specifies the calculation.
       Default is single-point, which should be changed to one of the following options.
       OPT Equilibrium structure optimization. TS Transition structure optimization is currently not available in NEO. RPATH Intrinsic reaction path following is currently not available in NEO.
       Application-dependent. Always use POINT_GROUP_SYMMETRY = FALSE with geometry optimization.
XC_GRID
XC_GRID
       0 Use SG-0 for H, C, N, and O; SG-1 for all other atoms. n Use SG-n for all atoms, n=1,2, or 3 X⁢Y A string of two six-digit integers X and Y, where X is the number of radial points and Y is the number of angular points where possible numbers of Lebedev angular points, which must be an allowed value from Table 5.2 in Section 5.5. -X⁢Y Similar format for Gauss-Legendre grids, with the six-digit integer X corresponding to the number of radial points and the six-digit integer Y providing the number of Gauss-Legendre angular points, Y=2⁢N2.
13.5.3.2 Additional Keywords
Additional NEO specific $rem variables can be used to customize the NEO-SCF calculation:
NEO_E_CONV
NEO_E_CONV
       Energy convergence criteria in the NEO-SCF calculations so that the difference in energy between electronic and protonic iterations is less than 10-NEO⁢_⁢E⁢_⁢CONV.
       8
       User-defined
       Tighter criteria for geometry optimization are recommended.
NEO_BASIS_LIN_DEP_THRESH
       This keyword is used to set the liner dependency threshold for nuclear basis sets. It is defined as 10-NEO⁢_⁢BASIS⁢_⁢LIN⁢_⁢DEP⁢_⁢THRESH.
       DOUBLE
       5.0
       User-defined
       No recommendation.
NEO_PURECART
NEO_PURECART
       This keyword is used to specify Cartesian or spherical Gaussians for nuclear basis functions.
       2222
       User-defined
       The default value corresponds to the use of Cartesian Gaussians for all angular momentum classes. The value NEO_PURECART = 1111 would use spherical Gaussians instead, similar to the use of PURECART.
NEO_ISOTOPE
NEO_ISOTOPE
       Enable calculations of different types of isotopes. Only one type of isotope is allowed at present.
       1 Default is the proton isotope.
       1 This NEO calculation is using proton isotope. 2 This NEO calculation is using deuterium isotope. 3 This NEO calculation is using tritium isotope.
       Refer to the NEO literature for the best performance on the isotope effects calculations.
NEO_VPP
NEO_VPP
       This keyword is used to control whether to remove J-K terms from the nuclear Fock matrix and the corresponding kernel terms for NEO excited state methods. Note that the purpose for the removal of these terms in the case of one quantum proton is to save on computational cost.
       LOGICAL/INTEGER
       TRUE (or 1) Enable this option (include nuclear J-K terms). FALSE (or 0) Disable this option (remove nuclear J-K terms).
       Set NEO_VPP = 0 only in the case of one quantum hydrogen.
NEO_EPC
NEO_EPC
       Specifies the electron-proton correlation functional.
       No default
       NAME Use NEO_EPC = NAME, where NAME can be either epc172 or epc19.
       Consult the NEO literature to guide your selection.
NEO_SCFV
NEO_SCFV
       Enable a NEO-SCFV calculation
       0 No NEO-SCFV calculation.
       1 Enable a NEO-SCFV calculation. 0 Disable a NEO-SCFV calculation.
NEO_MSDFT
NEO_MSDFT
       Enable a NEO-MSDFT calculation
       0 No NEO-MSDFT calculation.
       1 Enable a NEO-MSDFT calculation. 0 Disable a NEO-MSDFT calculation.
       See Section 13.5.2.3 for details on customizing a NEO-MSDFT calculation.
CNEO
CNEO
       Enable a CNEO calculation
       0 No CNEO calculation.
       1 Enable a CNEO calculation. 0 Disable a CNEO calculation.
       Use currently only for a single NEO center.
13.5.3.3 Dispersion-corrected NEO-DFT
Most of the available DFT-D3 empirical dispersion methods for modeling non-covalent interactions introduced in Section 5.7.2 have been extended to NEO-DFT, RT-NEO-TDDFT with fixed classical nuclei, and RT-NEO-TDDFT with moving classical nuclei. Note that the extended D3 model, D4, is currently unsupported but can be made available in a future release. NEO-DFT-D3 is available in Q-Chem (including both energies and analytic gradients) and can be requested via the $rem variable DFT_D, which is discussed below:
DFT_D
DFT_D
       Controls the empirical dispersion correction to be added.
       FALSE (or 0) Do not apply the DFT-D3 scheme D3_ZERO DFT-D3(0) dispersion correction from Grimme et al. 450 Grimme S. et al.
(2010), 132, pp. 154104.
D3_BJ DFT-D3(BJ) dispersion correction from Grimme et al. 452 Grimme S., Ehrlich S., Goerigk L.
(2011), 32, pp. 1456.
D3_CSO DFT-D3(CSO) dispersion correction from Schröder et al. 1136 Schröder H., Creon A., Schwabe T.
(2015), 11, pp. 3163.
D3_ZEROM DFT-D3M(0) dispersion correction from Smith et al. 1190 Smith D. G. et al.
J. Phys. Chem. Lett.
(2016), 7, pp. 2197.
D3_BJM DFT-D3M(BJ) dispersion correction from Smith et al. 1190 Smith D. G. et al.
D3_OP DFT-D3(op) dispersion correction from Witte et al. 1378 Witte J. et al.
(2017), 13, pp. 2043.
D3 Automatically select the “best” available D3 dispersion correction
Two caveats are worth pointing out: First, note that the functional form of the D3 empirical dispersion potential, EdispD3⁢(RA⁢B), is a sum over all pairwise atomic contributions. For convenience, our implementation of the D3 correction uses the positions of the quantum proton(s) basis function center positions for computing the interatomic distances RA⁢B. 770 Li T. E., Hammes-Schiffer S.
(2023), 158, pp. 114118.
Second, the D3 dispersion potentials have been parameterized for classical nuclei represented as point charges.
13.5.3.4 Usage of Pseudopotentials with NEO Methods
Q-Chem’s Effective Core Potential (ECP) package has been integrated with the NEO method to enable the description of relativistic and core electronic effects for systems in which some of the atoms may bear pseudopotentials. This is done by adding an additional one-electron potential contribution, which serves to model the effects of the core electrons, into the electronic Fock or analagous Kohn-Sham matrix (also see Section 8.10). In both the electronic and protonic Fock or analogous Kohn-Sham matrices, the one-electron term corresponding to the interaction of electrons or quantum protons with the classical nucleus with an ECP utilizes the effective nuclear charge shielded by the core electrons. 771 Li T. E., Paenurk E., Hammes-Schiffer S.
(2024), 15, pp. 751.
NEO analytic gradient calculations with ECPs and RT-NEO-TDDFT dynamics simulations with ECPs are also supported. The following $rem variable controls which ECP is used:
ECP
ECP
       Defines the effective core potential and associated basis set to be used
       No ECP
       General, Gen User defined. ($ecp keyword required) Symbol Use standard ECPs discussed above.
       ECPs are recommended for first row transition metals and heavier elements. Also consult Section 8.10 for more details.
13.5.3.5 Keywords for Simultaneous NEO-SCF
The NEO-SCF iteration procedure performed in the above section (see Section 13.5.3.1) solves the electronic and quantum nuclear Roothaan/Kohn-Sham equations in alternating fashion until convergence towards the variational solution is reached. This approach can become computationally expensive, especially when many SCF iterations are required to achieve self-consistency. To accelerate this procedure, those equations may instead be solved simultaneously at every step of the NEO-SCF iteration procedure. At the moment, we support the simultaneous implementation of the Direct Inversion in the Iterative Subspace (DIIS) algorithm. 791 Liu A. et al.
(2022), 126, pp. 7033.
Through extrapolation/interpolation, the simultaneous DIIS algorithm constructs an improved electronic and protonic Fock matrix at every kth step given a shared set of DIIS coefficients cj and the previous Fock matrices:
𝐅ke=∑j=1k-1cj⁢𝐅je    and    𝐅kp=∑j=1k-1cj⁢𝐅jp (13.78)
This is different from the traditional stepwise/alternating NEO-SCF approach, wherein only either 𝐅ke or 𝐅kp is computed at each step. The following $rem variables permit some customization of the simultaneous DIIS iterations:
NEO_SIMULTANEOUS_SCF
       Enables simultaneous optimization algorithm.
       TRUE FALSE
Note:  SCF_ALGORITHM = DIIS should also be set if NEO_SIMULTANEOUS_SCF = TRUE.
NEO_STEPWISE_SCF_STEPS
       Specifies the number of NEO-SCF stepwise/alternating macro-iterations to perform before switching to simultaneous algorithm.
       User-defined
       The rate of convergence of the NEO-SCF procedure is dependent on the initial guess for the electronic and protonic orbitals. For especially difficult systems, we recommend performing at least one round of stepwise optimization before beginning simultaneous.
DIIS_SUBSPACE_SIZE
DIIS_SUBSPACE_SIZE
       Controls the size of the DIIS subspace during the SCF.
       10
       User-defined
DIIS_ERR_RMS
DIIS_ERR_RMS
       Changes the DIIS convergence metric from the maximum to the RMS error.
       TRUE FALSE
       Use the default, the maximum error provides a more reliable criterion.
13.5.3.6 Keywords for NEO Excited-State Methods
The following additional $rem variables can be used to customize the NEO excited states methods calculation to obtain excitation energies:
CIS_N_ROOTS
CIS_N_ROOTS
       Sets the number of NEO excited state roots to find by Davidson or display the number of roots obtained by direct diagonalization.
       n n>0 Looks for n NEO excited states.
RPA
RPA
       Do a NEO-TDDFT or NEO-TDHF calculation.
       FALSE Do a NEO-TDA or NEO-CIS calculation. TRUE Do a NEO-TDDFT or NEO-TDHF calculation.
DIRECT_DIAG
DIRECT_DIAG
       Perform direct diagonalization to obtain all the NEO excitation energies.
       0 Use Davidson algorithm.
       1 Do the direct diagonalization. 0 Use Davidson algorithm.
       Only use this option when Davidson solutions are not stable.
CIS_STATE_DERIV
CIS_STATE_DERIV
       This keyword is used to specify for which NEO excited state the gradient or geometry optimization is needed.
       No default.
       n n>0 Looks to calculate gradient or conduct geometry optimization for the nth NEO excited state.
       Consult the keyword NEO_SET_ESTATE if gradient is desired for a vibronic excited state with dominant electronic character.
NEO_SET_ESTATE
NEO_SET_ESTATE
       This keyword is used to specify for which vibronic excited state with dominant electronic character the gradient or geometry optimization is needed.
       No default.
       n n>0 Looks to calculate gradient or conduct geometry optimization for the nth NEO vibronic excited state with dominant electronic character.
       Make sure enough roots are requested by the CIS_N_ROOTS keyword because the vibronic excited states with dominant protonic character usually come before.
NEO_SET_OPT
NEO_SET_OPT
       Enable a NEO excited state geometry optimization.
       1 Enable a NEO excited state geometry optimization. 0 Disable a NEO excited state geometry optimization.
       Need to use with CIS_STATE_DERIV. Consult the keyword NEO_SET_ESTATE if geometry optimization is desired for a vibronic excited state with dominant electronic character.
NEO_ZVEC_LINEAR
NEO_ZVEC_LINEAR
       Use linear solver for Z-vector equations for NEO excited state gradient.
       1 Use linear solver 0 Use iterative conjugate gradient solver
       Use the default iterative conjugate gradient solver because it is more memory efficient.
NEO_ZVEC_CG_MAXITER
NEO_ZVEC_CG_MAXITER
       Controls the maximum number of iterative gradient solver iterations permitted.
       300
       n Use n>0 iterations.
NEO_ZVEC_CG_CONV
NEO_ZVEC_CG_CONV
       The convergence threshold (10-NEO⁢_⁢ZVEC⁢_⁢CG⁢_⁢CONV) for the iterative gradient solver for NEO Z-vector equations.
       8
SET_SUBSPACE
SET_SUBSPACE
       Specify the number of protonic guess vectors for NEO-TDDFT
       Number of states desired (as set by CIS_N_ROOTS) if the number is smaller than the size of the protonic subspace (number of protonic occupied orbitals × number of protonic virtual orbitals) or the size of the protonic subspace
       n Use n>0 vectors.
The following $rem variable must be specified in order to run NEO-CC calculations:
NEO_RICCSD
NEO_RICCSD
       Enable a NEO-RICCSD calculation.
       1 Enable this option. 0 Disable this option.
       Both electronic and protonic auxiliary basis sets must be specified.
The following additional $rem variables can be used to customize the NEO-RICCSD calculation:
NEO_CCSD_MAX_CYCLES
NEO_CCSD_MAX_CYCLES
       Controls the maximum number of CC iterations permitted.
       5000
       n Set the maximum number of iterations to n>0.
NEO_CCSD_CONVERGENCE
       NEO-RICCSD is considered converged when the energy error is less than 10-NEO⁢_⁢CCSD⁢_⁢CONVERGENCE.
       8
       User-defined
NEO_RIMP2
NEO_RIMP2
       Enable a NEO-MP2 or NEO-OOMP2 calculation.
       2 Perform a NEO-OOMP2 calclulation. 1 Perform a NEO-MP2 calculation. 0 Disable this option.
SCS
SCS
       Set the type of spin-component scaling.
       1 Turns on spin-component scaling with SCS (css=0.33, cos=1.2). 2 Turns on spin-component scaling with SOS (css=0.0, cos=1.2 for MP2, cos=1.3 for OOMP2). 3 arbitrary SCS (set with SSS_FACTOR and SOS_FACTOR). 0 no spin-component scaling.
SSS_FACTOR
SSS_FACTOR
       Controls the strength of the same-spin component of the MP2 electron-electron correlation energy.
       1000000
       n Corresponding to css=n/106.
SOS_FACTOR
SOS_FACTOR
       Controls the strength of the opposite-spin component of the MP2 electron-electron correlation energy.
       1000000
       n Corresponding to cos=n/106.
EP_FACTOR
EP_FACTOR
       Controls the strength of the electron-proton component of the NEO-MP2 correlation energy.
       1000000
       n Corresponding to cep=n/106.
