For MECP optimization, set MECP_OPT = TRUE in the $rem section, and note that the $derivative_coupling input section discussed in Section 9.8.2 is not necessary in this case.
MECP_OPT
MECP_OPT
Determines whether we are doing MECP optimizations.
Do MECP optimization.
Do not do MECP optimization.
MECP_METHODS
MECP_METHODS
Determines which method to be used.
BRANCHING_PLANE
BRANCHING_PLANE
Use the branching-plane updating method.
MECP_DIRECT
Use the direct method.
PENALTY_FUNCTION
Use the penalty-constrained method.
The direct method is stable for small molecules or molecules with high
symmetry. The branching-plane updating method is more efficient for larger
molecules but does not work if the two states have different symmetries. If
using the branching-plane updating method, GEOM_OPT_COORDS must be
set to 0 in the $rem section, as this algorithm is available in Cartesian
coordinates only. The penalty-constrained method converges slowly and is suggested only if other methods fail.
MECP_STATE1
MECP_STATE1
Sets the first Born-Oppenheimer state for MECP optimization.
INTEGER/INTEGER ARRAY
[i,j]
Find the jth excited state with the total spin i; j=0 means the SCF ground state.
i is ignored for restricted calculations; for unrestricted calculations, i can only be 0 or 1.
MECP_STATE2
MECP_STATE2
Sets the second Born-Oppenheimer state for MECP optimization.
[i,j]
CIS_S2_THRESH
CIS_S2_THRESH
Determines whether a state is a singlet or triplet in unrestricted calculations.
120
n
Sets the ⟨ˆS2⟩ threshold to n/100
For the default case, states with ⟨ˆS2⟩>1.2 are treated as triplet states and
other states are treated as singlets.
MECP_PROJ_HESS
MECP_PROJ_HESS
Determines whether to project out the coupling vector
from the Hessian when using branching plane updating method.
Use the default.
Example 9.26 MECP optimization of an intersection between the S2 and S3 states of NO-2, using the direct method at the SOS-CIS(D0) level.
$molecule -1 1 N1 O2 N1 RNO O3 N1 RNO O2 AONO RNO = 1.50 AONO = 100 $end $rem JOBTYPE = opt METHOD = soscis(d0) BASIS = aug-cc-pVDZ AUX_BASIS = rimp2-aug-cc-pVDZ PURECART = 1111 CIS_N_ROOTS = 4 CIS_TRIPLETS = false CIS_SINGLETS = true MEM_STATIC = 900 MEM_TOTAL = 1950 MECP_OPT = true MECP_STATE1 = [0,2] MECP_STATE2 = [0,3] MECP_METHODS = mecp_direct $end
Example 9.27 Optimization of the ethylidene MECP between S0 and S1 at the SF-TDDFT level using the branching-plane updating method.
$molecule 0 3 C 0.044626 -0.2419240 0.357157 C 0.008905 0.6727548 1.460500 H 0.928425 -0.1459163 -0.272095 H -0.831032 -0.1926895 -0.288529 H -0.009238 0.9611331 2.479936 H 0.068314 -1.2533580 0.778847 $end $rem JOBTYPE opt METHOD bhhlyp BASIS 6-31G(d,p) MECP_OPT true MECP_METHODS branching_plane MECP_PROJ_HESS true ! project out y vector from the hessian GEOM_OPT_COORDS 0 ! currently only works for Cartesian coordinate GEOM_OPT_DRIVER optimize SPIN_FLIP true UNRESTRICTED true CIS_N_ROOTS 4 MECP_STATE1 [0,1] MECP_STATE2 [0,2] CIS_S2_THRESH 120 $end
Example 9.28 Optimization of the twisted-pyramidalized ethylene MECP between S0 and S1 at the SF-TDDFT level using the penalty-constrained updating method.
$molecule 0 3 C -0.015889 0.073532 -0.059559 C 0.012427 -0.002468 1.315694 H 0.857876 0.147014 -0.710529 H -0.936470 -0.011696 -0.626761 H 0.764557 0.663381 1.762573 H 0.740773 -0.869764 1.328583 $end $rem JOBTYPE opt MECP_OPT true MECP_METHODS penalty_function METHOD bhhlyp SPIN_FLIP true UNRESTRICTED true BASIS 6-31G(d,p) CIS_N_ROOTS 4 MECP_STATE1 [0,1] MECP_STATE2 [0,2] CIS_S2_THRESH 120 GEOM_OPT_DRIVER optimize $end
Example 9.29 Optimization of the ˜B1A2 and ˜A1B2 states of N+3 at the EOM-EE-CCSD level using the direct method. See Section 7.10.27 for the specifics of performing MECP optimization with coupled cluster.
$molecule 1 1 N1 N2 N1 rNN N3 N2 rNN N1 aNNN rNN = 1.54 aNNN = 50.0 $end $rem JOBTYPE opt MECP_OPT true MECP_METHODS mecp_direct METHOD eom-ccsd BASIS 6-31g EE_SINGLETS [0,2,0,2] XOPT_STATE_1 [0,2,2] XOPT_STATE_2 [0,4,1] CCMAN2 false GEOM_OPT_TOL_GRADIENT 30 GEOM_OPT_DRIVER optimize $end
Example 9.30 Optimization of the ethylidene MECP between S0 and S1 at the SF-TDDFT level with analytic derivative couplings.
$molecule 0 3 C 0.044626 -0.241924 0.357157 C 0.008905 0.672754 1.460500 H 0.928425 -0.145916 -0.272095 H -0.831032 -0.192689 -0.288529 H -0.009238 0.961133 2.479936 H 0.068314 -1.253358 0.778847 $end $rem JOBTYPE opt MECP_OPT true MECP_METHODS branching_plane MECP_PROJ_HESS true GEOM_OPT_COORDS 0 MECP_STATE1 [0,1] MECP_STATE2 [0,2] UNRESTRICTED true SPIN_FLIP true CIS_N_ROOTS 4 CALC_NAC true CIS_DER_NUMSTATE 2 MAX_CIS_CYCLES 50 EXCHANGE bhhlyp BASIS 6-31G(d,p) INTEGRAL_SYMMETRY true $end
