Analytic gradients are available for CCSD, OO-CCD/VOD, CCD, and QCCD/VQCCD methods for both closed- and open-shell references (UHF and RHF only), including frozen core and/or virtual functionality, as well as RI/Cholesky representations of the electron-repulsion integrals. Analytic gradients are available for CCVB-SD for only closed-shell references (RHF). In addition, gradients for selected GVB models are available.
For the CCSD and OO-CCD wave functions, Q-Chem can also calculate dipole moments, (as well as , , and moments separately, which is useful for assigning different Rydberg states, e.g., vs. , etc.), and the values. Interface of the CCSD and (V)OO-CCD codes with the NBO 5.0 package is also available. This code is closely related to EOM-CCSD properties/gradient calculations (Section 7.10.20). Solvent models available for CCSD are described in Chapter 11.2.
Limitations: Gradients and fully relaxed properties for ROHF and non-HF (e.g., B3LYP) orbitals as well as RI approximation are not yet available.
Note: If gradients or properties are computed with frozen core/virtual, the algorithm will replace frozen orbitals to restricted. This will not affect the energies, but will change the orbital numbering in the CCMAN printout.
CC_REF_PROP
CC_REF_PROP
Whether or not the non-relaxed (expectation value) or full response (including
orbital relaxation terms) one-particle CCSD
properties will be calculated. The properties currently include permanent
dipole moment, the second moments
(, , and )
of the electron density along with
This option is
incompatible with JOBTYPE = FORCE, OPT, or FREQ.
(no one-particle properties will be calculated)
FALSE, TRUE
Additional equations need to be solved (-CCSD equations) for properties
with the cost approximately the same as CCSD equations. Use the default if you do
not need properties. The cost of the properties calculation itself is low. The
CCSD one-particle density can be analyzed with NBO package by specifying
NBO = TRUE, CC_REF_PROP = TRUE, and
JOBTYPE = FORCE.
CC_REF_PROP_TE
CC_REF_PROP_TE
Request for calculation of non-relaxed two-particle CCSD properties. The
two-particle properties currently include . The one-particle
properties also will be calculated, since the additional cost of the
one-particle properties calculation is small compared to the cost of
The variable CC_REF_PROP must be also set to TRUE.
(no two-particle properties will be calculated)
FALSE, TRUE
The two-particle properties are computationally expensive, since
they require calculation and use of the two-particle density matrix (the cost
is approximately the same as the cost of an analytic gradient calculation). Do
not request the two-particle properties unless you really need them.
CC_FULLRESPONSE
CC_FULLRESPONSE
Fully relaxed properties (including orbital relaxation terms) will be computed.
(no orbital response will be calculated)
FALSE, TRUE
Not available for non UHF/RHF references and for the methods that do not have
analytic gradients (e.g., QCISD).
$molecule 0 1 H 0.000000 0.000000 -1.886789 He 0.000000 0.000000 -1.093834 F 0.000000 0.000000 0.333122 $end $rem JOBTYPE OPT METHOD CCSD BASIS aug-cc-pVDZ GEOM_OPT_TOL_GRADIENT 1 GEOM_OPT_TOL_DISPLACEMENT 1 GEOM_OPT_TOL_ENERGY 1 $end @@@ $molecule read $end $rem JOBTYPE SP METHOD CCSD BASIS aug-cc-pVDZ SCF_GUESS READ CC_REF_PROP 1 CC_FULLRESPONSE 1 $end
