Q-Chem’s implementation of SAPT0 was designed from the start as a correction for XPol calculations, affording the “XSAPT” method that is described in Section 12.10. As such, even a traditional SAPT0 calculation is requested by setting JOBTYPE = XSAPT. However, whereas XSAPT calculations are based on XPol wave functions for the monomers, which can capture many-body polarization effects in systems composed of more than two monomers (see Section 12.10), traditional SAPT calculations are based instead on gas-phase monomer wave functions. This can be realized by turning off the XPol charge embedding, i.e., by setting embed = none in the $xpol section that was introduced in Section 12.8.
Note: (1) Meta-GGAs are not yet available for SAPT(KS) calculations when the projected (pseudocanonicalized) basis set is used. SAPT(KS) calculations can be performed with meta-GGAs using the monomer or dimer basis sets. (2) Both closed- and open-shell (unrestricted) SAPT(KS) calculations are available. (3) Frozen orbitals are not available for use with SAPT(KS).
The remaining job control options for SAPT calculations are specified using various keywords contained in
a $sapt input section, as described below.
Researchers who use Q-Chem’s SAPT code are asked to cite Refs.
584
J. Chem. Phys.
(2011),
134,
pp. 094118.
521
Phys. Chem. Chem. Phys.
(2012),
14,
pp. 7679.
Algorithm
INPUT SECTION: $sapt
MO
MO
Traditional molecular orbital-based algorithm
RI-MO
MO-based algorithm with resolution-of-identity approximation
AO
Atomic orbital-based algorithm.
The standard MO-based algorithm corresponds to an MP2-like implementation of
Eq. (12.62), where the RI-MO algorithm corresponds to an RIMP2-like implementation.
The RI implementation is generally much faster and introduces negligible errors (as compared to the standard implementation),
provided that the auxiliary basis set is matched to the primary basis set. (The former must be specified using
(AUX_BASIS in the $rem section.) The AO-based algorithm
does not implement Eq. (12.62) and is intended only for use with XSAPT(KS)+aiD
calculations; see Section 12.10.3.
Exchange
S_Squared
S_Squared
Use the single-exchange (“”) approximation.
S_Inverse
Compute the exact first order exchange.
The single-exchange approximation is expected to be adequate except possibly at very short
intermolecular distances, and is somewhat faster to compute.
Basis
monomer
monomer
Use the monomer-centered basis set (MCBS).
dimer
Use the dimer-centered basis set (DCBS).
projected
Use the projected (pseudocanonicalized) basis set.
The DCBS (in which the monomer wave functions are iterated to convergence using the
dimer basis set) is the preferred choice in traditional SAPT, although it is more costly than
the MCBS (which uses only the monomer basis set for the monomer wave functions).
The DCBS is ill-defined, and therefore unavailable, for use with XPol charge embedding.
The projected basis set is an efficient approximation to the DCBS for traditional SAPT
calculations,
584
J. Chem. Phys.
(2011),
134,
pp. 094118.
and is available for use with XPol embedding.
CPHF
Requests that the second-order corrections and
be replaced by their infinite-order “response” analogues, and
Not specified
Computing the response corrections requires solving CPHF equations for each pair
of monomers, which is somewhat expensive but may improve the accuracy, especially when
the monomers are polar and induction contributions are large.
DSCF
Requests the correction
Not specified
The correction is computed if this keyword is present.
Evaluating requires an SCF calculation on
the entire (super)system. In the context of SAPT0 calculations, this correction
essentially results in a
“Hartree-Fock plus dispersion” estimate of the interaction energy.
Print
Desired print level
$molecule 0 1 -- formamide 0 1 C -2.018649 0.052883 0.000000 O -1.452200 1.143634 0.000000 N -1.407770 -1.142484 0.000000 H -1.964596 -1.977036 0.000000 H -0.387244 -1.207782 0.000000 H -3.117061 -0.013701 0.000000 -- formamide 0 1 C 2.018649 -0.052883 0.000000 O 1.452200 -1.143634 0.000000 N 1.407770 1.142484 0.000000 H 1.964596 1.977036 0.000000 H 0.387244 1.207782 0.000000 H 3.117061 0.013701 0.000000 $end $rem JOBTYPE XSAPT BASIS AUG-CC-PVDZ AUX_BASIS RIMP2-AUG-CC-PVDZ METHOD HF $end $sapt algorithm ri-mo basis dimer $end
