7.10.25 Job Control for EOM-CC(2,3)
(September 1, 2024)
EOM-CC(2,3) is invoked by METHOD=EOM-CC(2,3). The following options are available:
EOM_PRECONV_SD
EOM_PRECONV_SD
       Solves the EOM-CCSD equations, prints energies, then uses EOM-CCSD vectors as initial vectors in EOM-CC(2,3). Very convenient for calculations using energy additivity schemes.
       n Do n SD iterations
       Turning this option on is recommended
CC_REST_AMPL
CC_REST_AMPL
       Forces the integrals, T, and R amplitudes to be determined in the full space even though the CC_REST_OCC and CC_REST_VIR keywords are used.
       FALSE Do apply restrictions TRUE Do not apply restrictions
CC_REST_TRIPLES
CC_REST_TRIPLES
       Restricts R3 amplitudes to the active space, i.e., one electron should be removed from the active occupied orbital and one electron should be added to the active virtual orbital.
       1 Applies the restrictions
CC_REST_OCC
CC_REST_OCC
       Sets the number of restricted occupied orbitals including frozen occupied orbitals.
       n Restrict n occupied orbitals.
CC_REST_VIR
CC_REST_VIR
       Sets the number of restricted virtual orbitals including frozen virtual orbitals.
       n Restrict n virtual orbitals.
To select the active space, orbitals can be reordered by specifying the new order in the $reorder_mosection. The section consists of two rows of numbers (α and β sets), starting from 1, and ending with n, where n is the number of the last orbital specified.
The following example $reorder_mo section shows orbitals 16 and 17 swapped for both α and β electrons:
$reorder_mo
   1 2 3 4 5 6 7 8 9 10 11 12 13 14 15   17  16
7.10.25.1 Examples
Example 7.134  EOM-SF(2,3) calculations of methylene.
   C
   H 1 CH
   H 1 CH 2 HCH
   CH  = 1.07
   HCH = 111.0
   METHOD             eom-cc(2,3)
   BASIS              6-31G
   SF_STATES          [2,0,0,2]
   N_FROZEN_CORE      1
   N_FROZEN_VIRTUAL   1
   EOM_PRECONV_SD     20 Get EOM-CCSD energies first (max_iter=20).
Example 7.135  This is active-space EOM-SF(2,3) calculations for methane with an elongated CC bond. HF MOs should be reordered as specified in the $reorder_mosection such that active space for triples consists of sigma and sigma* orbitals.
   C
   H  1  CH
   H  1  CHX  2  HCH
   H  1  CH   2  HCH  3  A120
   H  1  CH   2  HCH  4  A120
   CH   = 1.086
   HCH  = 109.4712206
   A120 = 120.
   CHX  = 1.8
   METHOD            eom-cc(2,3)
   BASIS             6-31G*
   SF_STATES         [1,0]
   N_FROZEN_CORE     1
   EOM_PRECONV_SD    20   does eom-ccsd first, max_iter=20
   CC_REST_TRIPLES   1   triples are restricted to the active space only
   CC_REST_AMPL      0   ccsd and eom singles and doubles are full-space
   CC_REST_OCC       4   specifies active space
   CC_REST_VIR       17  specifies active space
   PRINT_ORBITALS    10  (number of virtuals to print)
$reorder_mo
   1 2 5 4 3
   1 2 3 4 5
Example 7.136  EOM-IP-CC(2,3) calculation of three lowest electronic states of water cation.
   H   0.774767     0.000000     0.458565
   O   0.000000     0.000000    -0.114641
   H  -0.774767     0.000000     0.458565
   METHOD       eom-cc(2,3)
   BASIS        6-311G
   IP_STATES    [1,0,1,1]
