Analogous quantities can be defined in momentum space; ˉI(𝐯), for example,
represents the probability density for the relative momentum
𝐯=𝐩1-𝐩2:
ˉI(𝐯)=∫π(𝐩1,𝐩2)δ(𝐩12-𝐯)𝑑𝐩1𝑑𝐩2 |
(13.14) |
where π(𝐩1,𝐩2) momentum two-electron density. Similarly, the
spherically averaged intracule
where Ω𝐯 is the angular part of 𝐯, is a measure of relative
momentum v=|𝐯| and is called the momentum intracule. The quantity M(v)
can be written as
M(v)=∑μνλσΓμνλσ(μνλσ)M |
(13.16) |
where Γμνλσ is the two-particle density
matrix and (μνλσ)M is the momentum integral
112
Besley N. A., Lee A. M., Gill P. M. W.
Mol. Phys.
(2002),
100,
pp. 1763.
(μνλσ)M=v22π2∫ϕ∗μ(𝐫)ϕν(𝐫+𝐪)ϕ∗λ(𝐮+𝐪)ϕσ(𝐮)j0(qv)𝑑𝐫𝑑𝐪𝑑𝐮 |
(13.17) |
The momentum integrals only possess four-fold permutational symmetry, i.e.,
(μνλσ)M=(νμλσ)M=(σλνμ)M=(λσμν)M |
(13.18) |
(νμλσ)M=(μνσλ)M=(λσνμ)M=(σλμν)M |
(13.19) |
and therefore generation of M(v) is roughly twice as expensive as P(u).
Momentum intracules can also be decomposed into Coulomb MJ(v) and exchange
MK(v) components:
MJ(v)=12∑μνλσDμνDλσ(μνλσ)M |
(13.20) |
MK(v)=-12∑μνλσ[DαμλDανσ+DβμλDβνσ](μνλσ)M |
(13.21) |
Again, the even-order moments are physically significant:
112
Mol. Phys.
(2002),
100,
pp. 1763.
where n is the number of electrons and ET is the total electronic
kinetic energy. Currently, Q-Chem can compute M(v), MJ(v) and
MK(v) using s and p basis functions only. Moments are generated
using quadrature and consequently for accurate results M(v) must be computed
over a large and closely spaced v range.
