As for ground state calculations, performing an adequate excited-state calculation involves making an appropriate choice of method and basis set. The development of effective approaches to modeling electronic excited states has historically lagged behind advances in treating the ground state. In part this is because of the much greater diversity in the character of the wave functions for excited states, making it more difficult to develop broadly applicable methods without molecule-specific or even state-specific specification of the form of the wave function. Recently, however, a hierarchy of single-reference ab initio methods has begun to emerge for the treatment of excited states. Broadly speaking, Q-Chem contains methods that are capable of giving qualitative agreement, and in many cases quantitative agreement with experiment for lower optically allowed states. The situation is less satisfactory for states that involve two-electron excitations, although even here reasonable results can sometimes be obtained. Moreover, some of the excited state methods can treat open-shell wave functions, e.g. diradicals, ionized and electron attachment states and more.
In excited-state calculations, as for ground state calculations, the user must strike a compromise between cost and accuracy. This chapter summarizes Q-Chem’s capabilities in four general classes of excited state methods:
Single-electron wave function-based methods (Section 7.2). These are excited state treatments of roughly the same level of sophistication as the Hartree-Fock ground state method, in the sense that electron correlation is essentially ignored. Single excitation configuration interaction (CIS) is the workhorse method of this type. The spin-flip variant of CIS extends it to diradicals.
Time-dependent density functional theory (TDDFT, Section 7.3). TDDFT is a widely used extension of DFT to excited states. For a cost that is only a little larger than that of a CIS calculation, TDDFT typically affords significantly greater accuracy due to a treatment of electron correlation. It, too, has a spin-flip variant that can be used to study di- and tri-radicals as well as bond breaking.
The Maximum Overlap Method (MOM) for excited SCF states (Section 7.6). This method overcomes some of the deficiencies of TDDFT and, in particular, can be used for modeling charge-transfer and Rydberg transitions as well as core-excited states.
Restricted open-shell Kohn-Sham (ROKS) method is a spin-purified, orbital optimized approach for excited states (Section 7.8.3). It is very accurate for modeling charge-transfer states and core-excitations.
The Square Gradient Minimization (SGM) algorithm can be used to converge both SCF and ROKS excited states. Details about using SGM in practice can be found in Section 4.5.14.
The State-Targeted Energy Projection (STEP) algorithm (Section 7.8.5) is available for SCF and ROKS excited states. It is less expensive than SGM and usually more robust than MOM.
Wave function-based electron correlation treatments (Sections 7.9, 7.11, 7.12 and 7.10). Roughly speaking, these are excited state analogues of the ground state wave function-based electron correlation methods discussed in Chapter 6. They are more accurate than the methods of Section 7.2, but also significantly more computationally expensive. These methods can also describe certain multi-configurational wave functions, for example, problematic doublet radicals, diradicals, triradicals, and more.
Note: Core electrons are frozen by default in most correlated excited-state calculations (see Section 6.2).
In general, a basis set appropriate for a ground state density functional theory or a Hartree-Fock calculation will be appropriate for describing valence excited states. However, many excited states involve significant contributions from diffuse Rydberg orbitals, and, therefore, it is often advisable to use basis sets that include additional diffuse functions. The 6-31+G* basis set is a reasonable compromise for the low-lying valence excited states of many organic molecules. To describe true Rydberg excited states, Q-Chem allows the user to add two or more sets of diffuse functions (see Chapter 8). For example the 6-311(2+)G* basis includes two sets of diffuse functions on heavy atoms and is generally adequate for description of both valence and Rydberg excited states.
Q-Chem supports four main types of excited state calculation:
Vertical absorption spectrum
This is the calculation of the excited states of the molecule at the
ground state geometry, as appropriate for absorption spectroscopy. The
methods supported for performing a vertical absorption calculation are:
CIS, RPA, XCIS, SF-XCIS, CIS(D), ADC(2)-s, ADC(2)-x,
ADC(3), RAS-SF, EOM-CCSD and EOM-OD, each of which will be discussed in turn.
The calculation of core-excited states for the simulation of
X-ray absorption spectra can be performed with TDDFT as well as
EOM-CCSD and ADC within the CVS approximation (Section
7.13). All ADC- and EOM-based methods can be combined
with the polarizable continuum model (PCM) to model the absorption
spectrum in solution following state-specific non-equilibrium approach.
Most EOM methods can be combined with explicit solvent treatments using
classical (QM/MM) and polarizable (QM/EFP) embedding.
Visualization
It is possible to visualize the excited states either by
attachment/detachment density analysis (available for CIS, RPA, TDDFT,
ADC, EOM-CC) or by plotting the transition density (see $plots
descriptions in Chapters 3 and 10).
Transition densities can be calculated for CIS, EOM-CCSD, and ADC methods.
The theoretical basis of the attachment/detachment density analysis
is discussed in Section 7.14.2 of this Chapter (more
details are given in Section 10.2.11).
In addition Dyson orbitals can be calculated and plotted for ionization
from the ground and electronically excited states or detachment from
electron-attached states for CCSD and EOM-CCSD wave functions. For the
RAS-SF method (Section 7.12), one can plot the natural orbitals
of a computed electronic state.
Excited-state optimization
Optimization of the geometry of stationary points on excited state
potential energy surfaces is valuable for understanding the geometric
relaxation that occurs between the ground and excited state. Analytic
first derivatives are available for UCIS, RCIS, TDDFT and EOM-CCSD.
Excited state optimizations may also be performed using finite difference
methods, however, these can be very time-consuming to perform.
Optimization of the crossings between potential energy surfaces
Seams between potential energy surfaces can be located and optimized by using analytic
gradients within EOM-CCSD, CIS, and TD-DFT formalisms.
Properties
Properties such as dipole moments, spatial extent
of electron densities and values can be computed for
ADC, EOM-CCSD, EOM-MP2, EOM-OD, RAS-SF and CIS wave functions.
Static polarizabilities are available for CCSD, EOM-EE-CCSD, and
EOM-SF-CCSD methods.
Transition properties and state interactions
Transition dipole moments and oscillator strengths can be computed with
practically all excited-state methods. Matrix elements and
cross-sections for two-photon absorption are available for EOM-EE-CCSD
and ADC methods. Spin-orbit couplings can be computed for EOM-CCSD, RAS-SF, CIS,
and TDDFT wave functions. Dyson orbitals are available for EOM-CC wave
functions. Transition properties can be computed between the reference
and target states (e.g., HF-CIS) or between different target states
(e.g., CIS-CIS).
Excited-state vibrational analysis
Given an optimized excited state geometry, Q-Chem can calculate the
force constants at the stationary point to predict excited state
vibrational frequencies. Stationary points can also be characterized as
minima, transition structures or th-order saddle points.
Analytic excited state vibrational analysis can only be performed using
the UCIS, RCIS, and TDDFT methods, for which efficient analytical second
derivatives are available. EOM-CCSD frequencies are also available using
analytic first derivatives and second derivatives obtained from finite
difference methods. EOM-OD frequencies are only available through finite
difference calculations.
Note: EOM-CC and most of the CI codes are part of CCMAN and CCMAN2. CCMAN is a legacy code which is being phased out. All new developments and performance-enhancing features are implemented in CCMAN2.
METHOD
METHOD
Specifies the level of theory.
No Correlation
CIS
Section 7.2.2
CIS(D)
Section 7.9.2
RI-CIS(D)
Section 7.9.3
SOS-CIS(D)
Section 7.9.4
SOS-CIS(D0)
Section 7.9.5
CISD
Section 7.10.3
CISDT
Section 7.10.3
EOM-OD
Section 7.10.3
EOM-CCSD
Section 7.10.3
EOM-MP2
Section 7.10.15.1
EOM-MP2T
Section 7.10.15.1
EOM-CCSD-S(D)
Section 7.10.15.2
EOM-MP2-S(D)
Section 7.10.15.2
EOM-CCSD(dT)
Section 7.10.26
EOM-CCSD(fT)
Section 7.10.26
EOM-CC(2,3)
Section 7.10.23
ADC(0)
Section 7.11
ADC(1)
Section 7.11
ADC(2)
Section 7.11
ADC(2)-X
Section 7.11
ADC(3)
Section 7.11
SOS-ADC(2)
Section 7.11
SOS-ADC(2)-X
Section 7.11
CVS-ADC(1)
Section 7.11
CVS-ADC(2)
Section 7.11
CVS-ADC(2)-X
Section 7.11
CVS-ADC(3)
Section 7.11
RAS-CI
Section 7.12
RAS-CI-2
Section 7.12
