A QM/MM job is requested by setting the $rem variables QM_MM_INTERFACE and FORCE_FIELD. Also required are a $qm_atoms input section and appropriate modifications to the $molecule section, as described above. Additional job control variables are detailed here.
QM_MM_INTERFACE
QM_MM_INTERFACE
Enables internal QM/MM calculations.
MM
Molecular mechanics calculation (i.e., no QM region)
ONIOM
QM/MM calculation using two-layer mechanical embedding
JANUS
QM/MM calculation using electronic embedding
The ONIOM model and Janus models are described above. Choosing MM
leads to no electronic structure calculation. However, when using MM, one
still needs to define the $rem variables BASIS and EXCHANGE
in order for Q-Chem to proceed smoothly.
FORCE_FIELD
FORCE_FIELD
Specifies the force field for MM energies in QM/MM calculations.
AMBER99
AMBER99 force field
CHARMM27
CHARMM27 force field
OPLSAA
OPLSAA force field
CHARGE_CHARGE_REPULSION
The repulsive Coulomb interaction parameter for YinYang atoms.
550
Use Q =
The repulsive Coulomb potential maintains bond lengths involving YinYang
atoms with the potential . The default is parameterized for carbon atoms.
FORCEMAN_PRINT
FORCEMAN_PRINT
Controls printing level for MM (and thus QM/MM) jobs.
Minimal printing, as befits a large MM job that runs for many steps.
Additional information including MM gradient.
Print individual terms in the MM energy expression.
3
Print connectivity information.
4
Print individual terms in the MM gradient.
Use the default unless trying to diagnose a problem.
GAUSSIAN_BLUR
GAUSSIAN_BLUR
Enables the use of Gaussian-delocalized external charges in a QM/MM calculation.
Delocalizes external charges with Gaussian functions.
Point charges
GAUSS_BLUR_WIDTH
GAUSS_BLUR_WIDTH
Delocalization width for external MM Gaussian charges in a Janus calculations.
Use a width of Å.
Blur all MM external charges in a QM/MM calculation with the specified width.
Gaussian blurring is currently incompatible with PCM calculations. Values of
1.0–2.0 Å are recommended in Ref.
282
J. Chem. Phys.
(2002),
117,
pp. 10534.
MM_SUBTRACTIVE
MM_SUBTRACTIVE
Specifies whether a subtractive scheme is used in the , Eq. (11.50), portion of the calculation.
Only pairs that are not 1-2, 1-3, or 1-4 pairs are used.
All pairs are calculated, and then the pairs that are double counted (1-2, 1-3, and 1-4) are subtracted out.
When running QM/MM or MM calculations there is not recommendation. When running a QM/MM-Ewald calculation
the value must be set to TRUE.
MODEL_SYSTEM_CHARGE
MODEL_SYSTEM_CHARGE
Specifies the QM subsystem charge if different from the $molecule section.
The charge of the QM subsystem.
This option only needs to be used if the QM subsystem (model system)
has a charge that is different from the total system charge.
MODEL_SYSTEM_MULT
MODEL_SYSTEM_MULT
Specifies the QM subsystem multiplicity if different from the $molecule section.
The multiplicity of the QM subsystem.
has a multiplicity that is different from the total system multiplicity.
ONIOM calculations must be closed shell.
PRINT_INPUT
PRINT_INPUT
Specifies whether to echo the input file in the output.
Print the Q-Chem input file as part of the Q-Chem output file.
Do not repeat the input file.
This is useful for record-keeping and defaults to TRUE except for QM/MM jobs,
where the default value is FALSE due to the size of some input files.
USER_CONNECT
USER_CONNECT
Enables explicitly defined bonds.
Bond connectivity is read from the $molecule section
Bond connectivity is determined by atom proximity
Set to TRUE if bond connectivity is known, in which case this connectivity must be
specified in the $molecule section. This greatly accelerates MM calculations.
