RDM_POSITIVITY
RDM_POSITIVITY
Indicates positivity conditions enforced in the v2RDM optimization.
DQG
DQG,
Two-electron conditions
DQGT1
Two-electron conditions plus the T1 partial three-electron conditions
DQGT2
Two-electron conditions plus the T2 partial three-electron conditions
DQGT1T2
Two-electron conditions plus the T1 and T2 partial three-electron conditions
DQG3POS
Two-electron conditions plus the full three-electron conditions
For high-accuracy, use DQG3POS or DQGT2, although such
computations become impractical for large active spaces. For large active
spaces (e.g., n > 16 for CAS(n, n)), use DQG.
RDM_CONSTRAIN_SPIN
RDM_CONSTRAIN_SPIN
Indicates if the spin-constraints are enforced.
Enforce spin-constraints.
Do not enforce spin-constraints.
Use default.
PDFT_EXCHANGE
PDFT_EXCHANGE
Specifies the exchange functional to be used in MC-PDFT calculation.
No default
NAME
Use PDFT_EXCHANGE = NAME, where NAME must be one of the LDA or GGA exchange
functionals listed in Section 5.3.3. This keyword is only invoked when
method is set to RDM(PDFT).
In general, consult the literature to guide your selection.
PDFT_CORRELATION
PDFT_CORRELATION
Specifies the correlation functional to be used in MC-PDFT calculation.
NAME
Use PDFT_CORRELATION = NAME, where NAME is one of the LDA or GGA correlation
functionals listed in Section 5.3.4. This keyword is only invoked when
RDM_E_CONVERGENCE
RDM_E_CONVERGENCE
The threshold for the primal-dual energy gap.
4
N
for a threshold of 10-N
Increase for gradient computations.
RDM_EPS_CONVERGENCE
RDM_EPS_CONVERGENCE
The threshold for the error in the primal and dual constraints.
4
N
RDM_MAXITER
RDM_MAXITER
Maximum number of diagonalization steps in the BPSDP solver.
50000
N>0
Increase for computations that are difficult to converge.
RDM_CG_CONVERGENCE
RDM_CG_CONVERGENCE
The minimum threshold for the conjugate gradient solver.
12
N
Should be at least (RDM_EPS_CONVERGENCE+2).
RDM_CG_MAXITER
RDM_CG_MAXITER
Maximum number of iterations for each conjugate gradient computations in the BPSDP algorithm.
1000
N>0
Use default unless problems arise.
RDM_TAU
RDM_TAU
Step-length parameter used in the BPSDP solver.
10
N
for a value of 0.1 * N
RDM_TAU should range between 10 and 16 for 1.0≤τ≤1.6.
RDM_MU_UPDATE_FREQUENCY
The number of v2RDM iterations after which the penalty parameter μ is updated.
200
N>0
Change if convergence problems arise.
RDM_TPDM_GUESS
RDM_TPDM_GUESS
Initial guess for the RDMs
HF_GUESS
HF_GUESS
Use RDMs from Hartree-Fock calculations as the initial density for the semidefinite solver
RANDOM_GUESS
Use random numbers as the initial density for the semidefinite solver
Use default unless convergence problems arise.
RDM_DIAGONALIZER
RDM_DIAGONALIZER
The algorithm used to diagonalize matrices inside semidefinite programming.
11
Use parallel LAPACK function DSYEV
Use parallel LAPACK function DSYEVD
10
Use multiple simultaneous calls to serial LAPACK function DSYEV
11
Use multiple simultaneous calls to serial LAPACK function DSYEVD
Use default. Under certain circumstances (e.g., low symmetry), algorithm 1 may be faster.
RDM_PRINT
RDM_PRINT
Controls the amount of printing.
Print minimal information.
Print information about all iterations.
Use 1 to analyze convergence issues.
RDM_ORBOPT_GRADIENT_CONVERGENCE
The threshold for the orbital gradient during orbital optimization.
4
N
for threshold of 10-N
Tighten for gradient computations.
RDM_ORBOPT_ENERGY_CONVERGENCE
The threshold for energy convergence during orbital optimization.
8
N
RDM_ORBOPT_MAXITER
RDM_ORBOPT_MAXITER
The maximum number of orbital optimization steps each time the orbital optimization routine is called.
20
N>0
RDM_ORBOPT_FREQUENCY
The number of v2RDM iterations after which the orbital optimization routine is called.
500
N>0
