MEM_STATIC
MEM_STATIC
Sets the memory for individual Fortran program modules
240
corresponding to 240 MB or 12% of MEM_TOTAL
User-defined number of megabytes.
For direct and semi-direct MP2 calculations, this must exceed OVN +
requirements for AO integral evaluation (32–160 MB). Up to 2000 MB for large
coupled-clusters calculations.
CC_MEMORY
CC_MEMORY
Specifies the maximum size, in MB, of the buffers for in-core storage of
block-tensors in CCMAN and CCMAN2.
50% of MEM_TOTAL. If MEM_TOTAL is not set, use 1.5 GB.
A minimum of
192 MB is hard-coded.
Integer number of MB
Larger values can give better I/O performance and are recommended for systems
with large memory (add to your .qchemrc file. When running
CCMAN2 exclusively on a node, CC_MEMORY should be set to
75–80% of the total available RAM. )
CC_BACKEND
CC_BACKEND
Used to specify the computational back-end of CCMAN2.
VM
Default shared-memory disk-based back-end
XM
libxm shared-memory disk-based back-end
INCORE
in-core memory back-end
Use XM for large jobs with limited memory or when the performance of the
default disk-based back-end is not satisfactory, INCORE for small jobs that
fit in main memory.
