At present the RASCI1 and RASCI2 implementations employ different keywords (which will be reconciled in a future version). This subsection applies to RASCI1 (spin adapted algorithm using exact integrals).
The use of the RASCI1 methodology is controlled by setting the $rem variable CORRELATION to RASCI and EXCHANGE should be set to HF. The RASCI1 implementation is only compatible with even numbers of electrons and restricted orbitals, i.e., UNRESTRICTED = FALSE.
The minimum input also requires specifying the desired (non-zero) value for RAS_ROOTS, the number of electrons in the “active” RAS2 space and the number of orbitals in RAS1 and RAS2 subspaces.
RAS_ROOTS
RAS_ROOTS
n
n>0 Compute n RAS-CI states
None. Only works with RAS-CI.
RAS_ELEC
RAS_ELEC
Sets the number of electrons in RAS2 (active electrons).
n
User-defined integer, n>0
RAS_ELEC_ALPHA
RAS_ELEC_ALPHA
Sets the number of spin-α electrons in RAS2 (active electrons).
n
RAS_ELEC_BETA
RAS_ELEC_BETA
Sets the number of spin-β electrons in RAS2 (active electrons).
n
RAS_ACT
RAS_ACT
Sets the number of orbitals in RAS2 (active orbitals).
n
RAS_OCC
RAS_OCC
Sets the number of orbitals in RAS1
n
These are the initial doubly occupied orbitals (RAS1) before
including hole type of excitations.
The RAS1 space starts from the lowest orbital up to RAS_OCC,
i.e. no frozen orbitals option available yet. Only works with RAS-CI.
RAS_DO_HOLE
RAS_DO_HOLE
Controls the presence of hole excitations in the RAS-CI wave function.
Include hole configurations (RAS1 to RAS2 excitations)
Do not include hole configurations
RAS_DO_PART
RAS_DO_PART
Controls the presence of particle excitations in the RAS-CI wave function.
Include particle configurations (RAS2 to RAS3 excitations)
Do not include particle configurations
RAS_AMPL_PRINT
RAS_AMPL_PRINT
Defines the absolute threshold (×102) for the CI amplitudes to be printed.
10
0.1 minimum absolute amplitude
n
User-defined integer, n≥0
RAS_ACT_ORB
RAS_ACT_ORB
Sets the user-selected active orbitals (RAS2 orbitals).
INTEGER ARRAY
From RAS_OCC + 1 to RAS_OCC + RAS_ACT
[i,j,k…]
The number of orbitals must be equal to the RAS_ACT variable
RAS_NATORB
RAS_NATORB
Controls the computation of the natural orbital occupancies.
Compute natural orbital occupancies for all states
Do not compute natural orbital occupancies
RAS_NATORB_STATE
RAS_NATORB_STATE
Saves the natural orbitals of the ith RAS-CI computed state into the .fchk file.
i
Saves the natural orbitals for the ith state
None. Only works with RAS-CI and if GUI = 2.
RAS_GUESS_CS
RAS_GUESS_CS
Controls the number of closed shell guess configurations in RAS-CI.
n
Imposes to start with n closed shell guesses
Only relevant for the computation of singlet states. Only works with RAS-CI.
RAS_SPIN_MULT
RAS_SPIN_MULT
Specifies the spin multiplicity of the roots to be computed
Singlet states
Compute any spin multiplicity
2n+1
RAS_SPIN_MULT option is only available for MS=0 systems, that is, with the same number of
α and β electrons.
RAS_PT2
RAS_PT2
Perform second-order perturbative correction to RAS-CI energy
Compute RASCI(2) energy corrections
Do not compute RASCI(2) energy corrections
RAS_PT2_PARTITION
RAS_PT2_PARTITION
Specifies the partitioning scheme in RASCI(2)
Davidson-Kapuy (DK) partitioning
Epstein-Nesbet (EN) partitioning
Do both DK and EN partitionings
Only for RAS-CI if RAS_PT2 is set to true.
RAS_PT2_VSHIFT
RAS_PT2_VSHIFT
Defines the energy level shift (×103au) in RASCI(2)
n
RAS_SRDFT
RAS_SRDFT
Perform short-range density functional RAS-CI calculation
Compute RASCI-srDFT states and energies
Do not perform a RASCI-srDFT calculation
RAS_SRDFT_EXC and RAS_SRDFT_COR need to be set.
RAS_SRDFT_EXC
RAS_SRDFT_EXC
Define short-range exchange functional
No default
NAME
Use RAS_SRDFT_EXC = NAME, where NAME is
one of the short-range exchange functionals listed in
Section 5.3.3
RAS_SRDFT_COR
RAS_SRDFT_COR
Define short-range correlation functional
No default
NAME
Use RAS_SRDFT_COR = NAME, where NAME is
one of the short-range correlation functionals listed in Section 5.3.4
RAS_OMEGA
RAS_OMEGA
Sets the Coulomb range-separation parameter within the RAS-CI-srDFT method.
400
(ω=0.4 bohr-1)
n
Corresponding to ω=n/1000, in units of bohr-1
None. Range-separation parameter is typical indicated by ω or μ. Only works with RAS-CI.
RAS_SRDFT_DAMP
RAS_SRDFT_DAMP
Sets damping factor (α<1) in the RAS-CI-srDFT method.
REAL
0.5
(α=0.5)
α
Damping factor 0<α<1
Modify in case of convergence issues along the RAS-CI-srDFT iterations. Only works with RAS-CI
RAS_SRDFT_SA_ROOTS
RAS_SRDFT_SA_ROOTS
Sets the list of roots used to build the state averaged reference density in RAS-CI-srDFT.
INTEGER ARRAY
All computed states
[i,j,k…]
List of states.
RAS_NFRAG
RAS_NFRAG
If n>0 activates the excitation analysis in RAS-CI
n
Number of fragments to be considered
Only for RAS-CI. The printed information level is controlled by RAS_PRINT.
RAS_NFRAG_ATOMS
RAS_NFRAG_ATOMS
Sets the number of atoms in each fragment.
INTEGER ARRAY
[i,j,k…]
The sum of the numbers must be equal to the total number
of atoms in the systems
RAS_FRAG_SETS
RAS_FRAG_SETS
Defines the number of orbitals in each disjoint set to perform orbital localization.
INTEGER ARRAY
[NOcc,NAct,NVir]
Number of orbitals within RAS1, RAS2 and RAS3 spaces
[i,j,k…]
Defines sets of canonical MOs to be localized into n fragments
Setting within RAS1, RAS2 and RAS3 spaces alleviates the computational
cost of the localization procedure. It might also result in improved fragment
orbitals. Only works with RAS-CI.
CALC_SOC
CALC_SOC
Controls whether to calculate the SOC constants for EOM-CC, RAS-CI, TDDFT/TDA and TDDFT.
INTEGER/LOGICAL
Do not perform the SOC calculation.
Perform the SOC calculation.
In addition to TRUE and FALSE, the
EOM-CC code has more variants of SOC evaluation; see Section 7.10.20.4.
RAS_SOC_2E
RAS_SOC_2E
Controls whether to compute two-electron mean-field contribution to RAS-CI SOC.
Do not compute two-electron mean-field contribution.
Compute two-electron mean-field contribution.
RAS_SOC_SYM_DENS
RAS_SOC_SYM_DENS
Controls whether to perform averaging of α and β densities.
Do not average α and β densities .
Average α and β densities.
