The BW-s2 approach has been implemented with the resolution-of-the-identity approximation and is invoked with METHOD = RIBWS2. The BW-s2 equation is iterative much like BW2, and keywords that give more precise control over the self-consistent determination of the BW-s2 energy are housed within a separate $bws2 section. Finally, the underlying algorithm that is used to solve the BW-s2 equation can be used to solve for other forms of the correlation energy such as MP2, BW2, size-extensive xBW2 (which is not size-consistent), or second-order Bethe-Goldstone (BGE2)/independent electron pair approximation (IEPA). While these methods are available for academic purposes, it is advised to only use the BW2, xBW2, and BGE2/IEPA codes for comparison as the first two are not size-consistent and the latter is not orbital invariant. For MP2 calculations, the standard RI-MP2 code should be used.
METHOD
Defines the correlation energy expression to be used.
INPUT SECTION: $bws2
BWS2
BWS2, BW2, xBW2, BGE2, IEPA, or MP2
BW-s2 is the recommended method, but if comparisons
with non-size-consistent methods like BW2 or xBW2
or non-orbital-invariant methods like BGE2/IEPA
are desired, those options are available.
ALPHA
Controls the extent of BW-s2() regularization.
100
where is the value of .
The default is set to the original BW-s2 theory
where (corresponding to )
is exact for a two-electron, two-orbital problem.
For general applications ()
is a broadly successful choice.
Other values can be set based on the chemical problem
at hand.
ENERGY_CONVERGENCE
Defines the convergence threshold for the correlation energy.
= SCF_CONVERGENCE
where the convergence threshold is set to
Use the default unless the cost of the calculation
becomes prohibitive, then consider reducing
to a slightly lower value.
MAX_CYCLES
Defines maximum number of iterations to be used in determining the correlation energy.
= SCF_MAX_CYCLES
Use the default unless convergence is particularly
slow, then increase the number of iterations accordingly.
$molecule 0 1 N -0.083032490 0.000714589 1.055199987 C -0.202853764 -1.141725850 0.364933690 H -0.098485626 -2.055097952 0.937432624 C -0.446781438 -1.191763671 -1.004512261 H -0.533649208 -2.145855109 -1.504171553 C -0.574682087 0.003439534 -1.704309480 H -0.763683910 0.004480103 -2.768726700 C -0.453456753 1.197242545 -1.000916473 H -0.545630798 2.152272643 -1.497795085 C -0.209311108 1.144507590 0.368367296 H -0.110167072 2.056697259 0.943573961 C 0.471836022 -0.006058187 5.541718960 H 0.587246066 -0.005483995 6.596732782 C 0.339766259 -0.006607922 4.335471660 H 0.221618143 -0.006345494 3.270966186 $end $rem method ribws2 basis aug-cc-pvdz aux_basis rimp2-aug-cc-pvdz scf_convergence 8 thresh 14 integral_symmetry false $end ! METHOD keyword is not required for BW-s2 ! MAX_CYCLES keyword is manually set to the default here $bws2 alpha 400 max_cycles 50 $end
