A MBE() calculation is requested by setting MANY_BODY_INT =
TRUE in the $rem section. The level of theory used for the
fragments will be whatever is specified in the $rem section. Researchers who
use Q-Chem’s MBE code are asked to cite
Ref.
1096
J. Chem. Phys.
(2014),
141,
pp. 014108.
726
J. Chem. Phys.
(2016),
144,
pp. 164105.
. In addition, please cite
Ref.
1094
J. Phys. Chem. Lett.
(2013),
4,
pp. 2674.
for the MBCP() method.
A MBE() calculation is requested by setting MANY_BODY_INT = TRUE
in the $rem section. The level of theory used for the fragments will be whatever is specified in the $rem section.
Researchers who use Q-Chem’s MBE code are asked to cite Ref.
1096
J. Chem. Phys.
(2014),
141,
pp. 014108.
726
J. Chem. Phys.
(2016),
144,
pp. 164105.
In addition, please cite Ref.
1094
(2013),
4,
pp. 2674.
MANY_BODY_INT
MANY_BODY_INT
Perform a MBE calculation.
Do not perform a MBE calculation.
Additional MBE-specific options, such as the order of the expansion (), are specified in a $mbe input section, as described below.
Order
Specifies the order of the many-body expansion.
INPUT SECTION: $mbe
Perform an MBE() calculation.
Orders are available.
Embed
Specifies the embedding method for EE-MBE().
INPUT SECTION: $mbe
Do not use embedding.
Charges
Use atomic point charges.
Density
Full Coulomb embedding using monomer densities.
Use of atomic point charges requires a $mbe_charges section to specify the charges.
Q-Chem’s implementation of EE-MBE() with atomic point charges is designed
to use with a $mbe_charges input section to specify fixed embedding charges.
(Use of these charges is intended to accelerate convergence of the MBE by
capturing many-body polarization effects and thus making the higher-order
-body terms smaller, although three- and four-body terms remain
non-negligible even with embedding charges.
1097
Acc. Chem. Res.
(2014),
47,
pp. 2828.
726
J. Chem. Phys.
(2016),
144,
pp. 164105.
800
J. Chem. Phys.
(2017),
147,
pp. 161729.
The format of the $mbe_charges section is simply a list of charges in the same
order as the atoms in the $molecule section. An example is provided below.
Many-body counterpoise corrections are requested with two keywords in the
$mbe input section: BSSE_Type and BSSE_Order. These
have only been implemented up to , as the terms make by far the most
significant contribution.
800
J. Chem. Phys.
(2017),
147,
pp. 161729.
BSSE_Order
Perform a many-body counterpoise correction of the MBCP() or VMFC() variety.
INPUT SECTION: $mbe
Do not perform a counterpoise correction.
Perform a counterpoise correction truncated at order .
Orders are available. Use the keyword BSSE_Type to choose
between MBCP and VMFC.
BSSE_Type
Select the type of many-body counterpoise correction, MBCP( or VMFC().
INPUT SECTION: $mbe
MBCP
MBCP
Use MBCP().
VMFC
Use VMFC().
The two methods are equivalent for but different for .
MBCP() contains fewer terms but generally provides comparable results as compared
to the formally more complete VMFC() approach.
Example 12.44 Example showing a EE-MBE(3) calculation using TIP3P charges.
$molecule 0 1 -- 0 1 O -1.126149 -1.748387 -0.423240 H -0.234788 -1.493897 -0.661862 H -1.062789 -2.681331 -0.218819 -- 0 1 O -0.254210 1.611495 -1.293845 H -1.001520 1.163510 -1.690129 H -0.153399 2.411746 -1.809248 -- 0 1 O 1.694541 -0.226287 1.705739 H 0.785920 0.073487 1.677909 H 2.047134 0.150917 2.511706 -- 0 1 O -0.864533 0.522472 1.218817 H -0.694120 1.093542 0.469789 H -1.131418 -0.310426 0.829702 $end $rem point_group_symmetry False METHOD B3LYP BASIS cc-pVDZ MANY_BODY_INT true THRESH 14 SCF_CONVERGENCE 7 $end $mbe order 3 embed charges $end $mbe_charges -0.834 0.417 0.417 -0.834 0.417 0.417 -0.834 0.417 0.417 -0.834 0.417 0.417 $end
Example 12.45 Example of a MBCP(3) calculation.
$molecule 0 1 -- 0 1 O -1.126149 -1.748387 -0.423240 H -0.234788 -1.493897 -0.661862 H -1.062789 -2.681331 -0.218819 -- 0 1 O -0.254210 1.611495 -1.293845 H -1.001520 1.163510 -1.690129 H -0.153399 2.411746 -1.809248 -- 0 1 O 1.694541 -0.226287 1.705739 H 0.785920 0.073487 1.677909 H 2.047134 0.150917 2.511706 -- 0 1 O -0.864533 0.522472 1.218817 H -0.694120 1.093542 0.469789 H -1.131418 -0.310426 0.829702 $end $rem MANY_BODY_INT TRUE METHOD B3LYP BASIS cc-pVDZ THRESH 12 SCF_CONVERGENCE 6 $end $mbe BSSE_Order 3 BSSE_Type MBCP ! this is the default $end
