The Coulomb Attenuated Schrödinger Equation (CASE)
approximation
23
Chem. Phys. Lett.
(1996),
254,
pp. 329.
follows from the KWIK
algorithm
328
J. Phys. Chem.
(1996),
100,
pp. 6272.
in which the Coulomb operator is separated into
two pieces using the error function, Eq. (5.12). Whereas in
Section 5.6 this partition of the Coulomb operator was used to
incorporate long-range Hartree-Fock exchange into DFT, within the CASE
approximation it is used to attenuate all occurrences of the Coulomb operator
in Eq. (4.2), by neglecting the long-range portion of the
identity in Eq. (5.12). The parameter in
Eq. (5.12) is used to tune the level of attenuation.
Although the total energies from Coulomb attenuated calculations are
significantly different from non-attenuated energies, it is found that relative
energies, correlation energies and, in particular, wave functions, are not,
provided a reasonable value of is chosen.
By virtue of the exponential decay of the attenuated operator, ERIs can be neglected on a proximity basis yielding a rigorous algorithm for single point energies. CASE may also be applied in geometry optimizations and frequency calculations.
OMEGA
OMEGA
Controls the degree of attenuation of the Coulomb operator.
No default
Corresponding to , in units of bohr
INTEGRAL_2E_OPR
INTEGRAL_2E_OPR
Determines the two-electron operator.
-2
Coulomb Operator.
-1
Apply the CASE approximation.
-2
Coulomb Operator.
Use the default unless the CASE operator is desired.
