5.3.6 Specialized Functionals
  • SRC1-R1: TDDFT short-range corrected functional [Eq. (1) in Ref.  116 Besley N. A., Peach M. J. G., Tozer D. J.
    (2009), 11, pp. 10350.
    , 1st row atoms]
  • SRC1-R2: TDDFT short-range corrected functional [Eq. (1) in Ref.  116 Besley N. A., Peach M. J. G., Tozer D. J.
    , 2nd row atoms]
  • SRC2-R1: TDDFT short-range corrected functional [Eq. (2) in Ref.  116 Besley N. A., Peach M. J. G., Tozer D. J.
    , 1st row atoms]
  • SRC2-R2: TDDFT short-range corrected functional [Eq. (2) in Ref.  116 Besley N. A., Peach M. J. G., Tozer D. J.
    , 2nd row atoms]
  • BR89: Becke-Roussel meta-GGA exchange functional modeled after the hydrogen atom 84 Becke A. D., Roussel M. R.
    Phys. Rev. A
    (1989), 39, pp. 3761.
  • B94: meta-GGA correlation functional by Becke that uses the BR89 exchange functional to compute the Coulomb potential 90 Becke A. D.
    Int. J. Quantum Chem. Symp.
    (1994), 28, pp. 625.
  • B94hyb: modified version of the B94 correlation functional for use with the BR89B94hyb exchange-correlation functional 90 Becke A. D.
  • BR89B94h: 15.4% HF exchange + 84.6% BR89 meta-GGA exchange + BR89hyb meta-GGA correlation 90 Becke A. D.
  • BRSC: Exchange component of the original B05 exchange-correlation functional 94 Becke A. D.
    (2005), 122, pp. 064101.
  • MB05: Exchange component of the modified B05 (BM05) exchange-correlation functional 1053 Proynov E., Liu F., Kong J.
    (2012), 525, pp. 150.
  • B05: A full exact-exchange Kohn-Sham scheme of Becke that uses the exact-exchange energy density (RI) and accounts for static correlation 94 Becke A. D.
    , 1056 Proynov E., Shao Y., Kong J.
    (2010), 493, pp. 381.
    , 1055 Proynov E. et al.
    (2012), 136, pp. 034102.
  • BM05 (XC): Modified B05 hyper-GGA scheme that uses MB05 instead of BRSC as the exchange functional 1053 Proynov E., Liu F., Kong J.
  • PSTS: Hyper-GGA (100% HF exchange) exchange-correlation functional of Perdew, Staroverov, Tao, and Scuseria 998 Perdew J. P. et al.
    Phys. Rev. A
    (2008), 78, pp. 052513.
  • MCY2: Mori-Sánchez-Cohen-Yang adiabatic connection-based hyper-GGA exchange-correlation functional 897 Mori-Sánchez P., Cohen A. J., Yang W.
    (2006), 124, pp. 091102.
    , 242 Cohen A. J., Mori-Sánchez P., Yang W.
    (2007), 127, pp. 034101.
    , 793 Liu F. et al.
    (2012), 137, pp. 114104.
This example illustrate the use of the RI-B05 and RI-PSTS functionals. These are presently available only for single-point calculations, and convergence is greatly facilitated by obtaining converged SCF orbitals from, e.g., an LDA or HF calculation first. (LDA is used in the example below but HF can be substituted.) Use of the RI approximation (Section 6.6) requires specification of an auxiliary basis set.
Example 5.1  Q-Chem input of H2 using RI-B05.
   H2, example of SP RI-B05.  First do a well-converged LSD, G3LARGE is the
   basis of choice for good accuracy.
   H   0.  0.   0.0
   H   0.  0.   0.7414
   METHOD           lda
   BASIS            g3large
   SCF_GUESS        core     ! required
   PURECART         2222     ! required
   THRESH           14
   INCDFT           false
   SCF_CONVERGENCE  9
   POINT_GROUP_SYMMETRY false
   INTEGRAL_SYMMETRY    false
   EXCHANGE        b05            ! or set to psts for ri-psts
   BASIS           g3large
   AUX_BASIS       rib05-cc-pvtz  ! the aux basis for both RI-B05 and RI-PSTS
   SCF_GUESS       read
   THRESH          4
   PRINT_INPUT     true
   INCDFT          false
   MAX_SCF_CYCLES  0              ! required
   DFT_CUTOFFS     0              ! required
