Example 7.164 Input for a RAS-2SF-CI calculation of three states of the DDMX tetraradical using RASCI1. The active space (RAS2) contains 4 electrons in the 4 singly occupied orbitals in the ROHF quintet reference. Natural orbital occupancies are requested.
$molecule 0 5 C 0.000000 0.000000 1.092150 C -1.222482 0.000000 0.303960 C -2.390248 0.000000 1.015958 H -2.344570 0.000000 2.095067 H -3.363161 0.000000 0.537932 C -1.215393 0.000000 -1.155471 H -2.150471 0.000000 -1.702536 C 0.000000 0.000000 -1.769131 C 1.215393 0.000000 -1.155471 H 2.150471 0.000000 -1.702536 C 1.222482 0.000000 0.303960 C 2.390248 0.000000 1.015958 H 2.344570 0.000000 2.095067 H 3.363161 0.000000 0.537932 $end $rem EXCHANGE hf CORRELATION rasci BASIS 6-31g UNRESTRICTED false MEM_TOTAL 4000 MEM_STATIC 100 RAS_ROOTS 3 RAS_ACT 4 RAS_ELEC 4 RAS_OCC 25 RAS_SPIN_MULT 0 RAS_NATORB true SYMMETRY true $end
Example 7.165 Input for a RAS-2IP-CI calculation of triplet states of F2 molecule using the dianion closed shell F2-2 as the reference determinant. RASCI1 code is used
$molecule -2 1 F F 1 1.4136 $end $rem EXCHANGE hf CORRELATION rasci BASIS cc-pVTZ MEM_TOTAL 4000 MEM_STATIC 100 RAS_ROOTS 2 RAS_ACT 6 RAS_ELEC 10 RAS_OCC 4 RAS_SPIN_MULT 3 $end
Example 7.166 Input for a FCI/STO-3G calculation of water molecule expanding the RAS2 space to the entire molecular orbital set. RAS-CI code is used.
$molecule 0 1 O 0.000 0.000 0.120 H -0.762 0.000 -0.479 H 0.762 0.000 -0.479 $end $rem EXCHANGE hf CORRELATION rasci BASIS sto-3g MEM_TOTAL 4000 MEM_STATIC 100 RAS_ROOTS 1 RAS_ACT 7 RAS_ELEC 10 RAS_OCC 0 RAS_SPIN_MULT 1 RAS_DO_HOLE false RAS_DO_PART false $end
Example 7.167 Methylene single spin-flip calculation using RASCI2
$molecule 0 3 C 0.0000000 0.0000000 0.0000000 H -0.8611113 0.0000000 0.6986839 H 0.8611113 0.0000000 0.6986839 $end $rem EXCHANGE HF CORRELATION RASCI2 BASIS cc-pVDZ AUX_BASIS rimp2-cc-pVDZ UNRESTRICTED false RAS_ACT_OCC 1 ! # alpha electrons RAS_ACT_VIR 1 ! # virtuals in active space RAS_ACT_DIFF 0 ! # set to 1 for odd # of e-s RAS_N_ROOTS 4 MAX_CIS_CYCLES 25 ! number of iterations in RASCI $end
Example 7.168 Two methylene separated by 10 Å; double spin-flip calculation using RASCI2. Note that the ⟨ˆS2⟩ values for this case will not be uniquely defined at the triply-degenerate ground state.
$molecule 0 5 C 0.0000000 0.0000000 0.0000000 H -0.8611113 0.0000000 0.6986839 H 0.8611113 0.0000000 0.6986839 C 0.0000000 10.0000000 0.0000000 H -0.8611113 10.0000000 0.6986839 H 0.8611113 10.0000000 0.6986839 $end $rem EXCHANGE HF CORRELATION RASCI2 BASIS cc-pVDZ AUX_BASIS rimp2-cc-pVDZ RAS_ACT_OCC 2 ! # alpha electrons RAS_ACT_VIR 2 ! # virtuals in active space RAS_ACT_DIFF 0 ! # set to 1 for odd # of e-s UNRESTRICTED false RAS_N_ROOTS 8 MAX_CIS_CYCLES 25 $end
Example 7.169 RASCI2 calculation of the nitrogen cation using double spin-flip.
$molecule 1 6 N N 1 4.5 $end $rem EXCHANGE HF CORRELATION RASCI2 BASIS 6-31G* AUX_BASIS rimp2-VDZ RAS_ACT_OCC 3 ! # alpha electrons RAS_ACT_VIR 3 ! # virtuals in active space RAS_ACT_DIFF 1 ! # for odd # e-s, cation UNRESTRICTED false N_FROZEN_CORE 2 N_FROZEN_VIRTUAL 2 RAS_N_ROOTS 8 MAX_CIS_CYCLES 25 $end
Example 7.170 CAS-1SF calculation of the nitrogen dimer using casman.
$rem exchange hf correlation sf-cas cas_level_shift 0 basis 6-31g* aux_basis rimp2-vdz unrestricted 0 scf_guess core integral_symmetry 0 point_group_symmetry false $end $molecule 0 7 N N,1,R1 R1 2.5 $end
Example 7.171 RAS(3x)+D-1SF calculation of the nitrogen dimer using casman.
$rem exchange hf correlation sf-cas(3x)+D ras_roots 10 basis 6-31g* aux_basis rimp2-vdz unrestricted 0 scf_guess read integral_symmetry 0 point_group_symmetry false $end $molecule 0 7 N N,1,R1 R1 2.5 $end
Example 7.172 Custom SF-CAS(2x)2 calculation of the nitrogen dimer cation using casman.
$rem exchange hf correlation sf-cas cas_do_2x 1 cas_qdpt_order 2 cas_level_shift 107 ras_roots 10 basis 6-31g* aux_basis rimp2-vdz unrestricted 0 scf_guess core integral_symmetry 0 point_group_symmetry false $end $molecule 0 5 O H,1,R1 H,1,R1,2,109.5 R1 2.0 $end
Example 7.173 RAS(h,p)-1SF calculation of the quartet state of the nitrogen dimer using librassf.
$molecule 0 7 N N 1 1.75 $end $rem EXCHANGE HF CORRELATION RASCI2 BASIS cc-pvdz LIBRASSF 1 RASSF_GUESS 1 RASSF_DELTA_ALPHA 1 RASSF_DELTA_BETA 1 RAS_N_ROOTS 4 RAS_DO_HOLE 1 RAS_DO_PART 1 RAS_NATORB 0 $end
Example 7.174 RAS(h)-1SF-IP calculation of the nitrogen cation using librassf.
Example 7.175 SOC calculation of HSiCl molecule using RASCI2 method with double spin-flip. No NTO analysis is requested within this example.
$molecule 0 1 Si 0.00000 0.00000 0.00000 H 1.56100 0.00000 0.00000 Cl -0.45728 2.01271 0.00000 $end $rem EXCHANGE HF CORRELATION RASCI2 BASIS cc-pVDZ AUX_BASIS rimp2-cc-pVDZ UNRESTRICTED false RAS_ACT_OCC 2 ! # alpha electrons RAS_ACT_VIR 2 ! # virtuals in active space RAS_ACT_DIFF 0 ! # set to 1 for odd # of e-s RAS_N_ROOTS 8 MAX_CIS_CYCLES 25 N_FROZEN_CORE fc N_FROZEN_VIRTUAL 0 RAS_CALC_SOC true $end
Example 7.176 SOC calculation followed by NTO analysis of acetophenone molecule using RASCI2 method with double spin-flip.
$molecule 0 1 C -2.517371 0.513126 0.001828 C -1.316451 -0.371636 0.001013 C -1.553894 -1.827349 0.000191 C -2.806559 -2.314044 -0.001563 C -3.962422 -1.432985 -0.002120 C -3.757473 -0.015730 0.000047 C -0.030094 0.202242 0.001108 C 1.208765 -0.658368 -0.000434 O 0.079290 1.457055 0.003022 H 2.079440 -0.009753 -0.004191 H -0.705807 -2.494690 0.000993 H -2.970202 -3.383004 -0.002372 H -4.958256 -1.847303 -0.003648 H -4.620034 0.636483 0.000372 H -2.340078 1.575881 0.003550 H 1.252514 -1.299975 0.880472 H 1.247817 -1.304378 -0.878269 $end $rem EXCHANGE HF CORRELATION RASCI2 BASIS cc-pVDZ AUX_BASIS rimp2-cc-pVDZ UNRESTRICTED false RAS_ACT_OCC 2 ! # alpha electrons RAS_ACT_VIR 2 ! # virtuals in active space RAS_ACT_DIFF 0 ! # set to 1 for odd # of e-s RAS_N_ROOTS 4 MAX_CIS_CYCLES 25 N_FROZEN_CORE fc N_FROZEN_VIRTUAL 0 RAS_CALC_SOC true MOLDEN_FORMAT true NTO_PAIRS 2 $end
