9.9 Nonadiabatic Couplings and Optimization of Minimum-Energy Crossing Points
9.9.4 Job Control and Examples
For MECP optimization, set MECP_OPT = TRUE in the $rem section, and note that the $derivative_coupling input section discussed in Section 9.9.2 is not necessary in this case.
MECP_OPT
MECP_OPT
       Determines whether we are doing MECP optimizations.
       TRUE Do MECP optimization. FALSE Do not do MECP optimization.
MECP_METHODS
MECP_METHODS
       Determines which method to be used.
       BRANCHING_PLANE
       BRANCHING_PLANE Use the branching-plane updating method. MECP_DIRECT Use the direct method. PENALTY_FUNCTION Use the penalty-constrained method.
       The direct method is stable for small molecules or molecules with high symmetry. The branching-plane updating method is more efficient for larger molecules but does not work if the two states have different symmetries. If using the branching-plane updating method, GEOM_OPT_COORDS must be set to 0 in the $rem section, as this algorithm is available in Cartesian coordinates only. The penalty-constrained method converges slowly and is suggested only if other methods fail.
MECP_STATE1
MECP_STATE1
       Sets the first Born-Oppenheimer state for MECP optimization.
       INTEGER/INTEGER ARRAY
       [i,j] Find the jth excited state with the total spin i; j=0 means the SCF ground state.
       i is ignored for restricted calculations; for unrestricted calculations, i can only be 0 or 1.
MECP_STATE2
MECP_STATE2
       Sets the second Born-Oppenheimer state for MECP optimization.
CIS_S2_THRESH
CIS_S2_THRESH
       Determines whether a state is a singlet or triplet in unrestricted calculations.
       120
       n Sets the ⟨S^2⟩ threshold to n/100
       For the default case, states with ⟨S^2⟩>1.2 are treated as triplet states and other states are treated as singlets.
MECP_PROJ_HESS
MECP_PROJ_HESS
       Determines whether to project out the coupling vector from the Hessian when using branching plane updating method.
       TRUE FALSE
       Use the default.
Example 9.26  MECP optimization of an intersection between the S2 and S3 states of NO-2, using the direct method at the SOS-CIS(D0) level.
   N1
   O2  N1  RNO
   O3  N1  RNO  O2  AONO
   RNO  = 1.50
   AONO = 100
   JOBTYPE         = opt
   METHOD          = soscis(d0)
   BASIS           = aug-cc-pVDZ
   AUX_BASIS       = rimp2-aug-cc-pVDZ
   PURECART        = 1111
   CIS_N_ROOTS     = 4
   CIS_TRIPLETS    = false
   CIS_SINGLETS    = true
   MEM_STATIC      = 900
   MEM_TOTAL       = 1950
   MECP_OPT        = true
   MECP_STATE1     = [0,2]
   MECP_STATE2     = [0,3]
   MECP_METHODS    = mecp_direct
Example 9.27  Optimization of the ethylidene MECP between S0 and S1 at the SF-TDDFT level using the branching-plane updating method.
   C   0.044626  -0.2419240   0.357157
   C   0.008905   0.6727548   1.460500
   H   0.928425  -0.1459163  -0.272095
   H  -0.831032  -0.1926895  -0.288529
   H  -0.009238   0.9611331   2.479936
   H   0.068314  -1.2533580   0.778847
   JOBTYPE           opt
   METHOD            bhhlyp
   BASIS             6-31G(d,p)
   MECP_OPT          true
   MECP_METHODS      branching_plane
   MECP_PROJ_HESS    true  ! project out y vector from the hessian
   GEOM_OPT_COORDS   0     ! currently only works for Cartesian coordinate
   SPIN_FLIP         true
   UNRESTRICTED      true
   CIS_N_ROOTS       4
   MECP_STATE1       [0,1]
   MECP_STATE2       [0,2]
   CIS_S2_THRESH     120
Example 9.28  Optimization of the twisted-pyramidalized ethylene MECP between S0 and S1 at the SF-TDDFT level using the penalty-constrained updating method.
   C  -0.015889   0.073532  -0.059559
   C   0.012427  -0.002468   1.315694
   H   0.857876   0.147014  -0.710529
   H  -0.936470  -0.011696  -0.626761
   H   0.764557   0.663381   1.762573
   H   0.740773  -0.869764   1.328583
   JOBTYPE         opt
   MECP_OPT        true
   MECP_METHODS    penalty_function
   METHOD          bhhlyp
   SPIN_FLIP       true
   UNRESTRICTED    true
   BASIS           6-31G(d,p)
   CIS_N_ROOTS     4
   MECP_STATE1     [0,1]
   MECP_STATE2     [0,2]
   CIS_S2_THRESH   120
Example 9.29  Optimization of the B~1⁢A2 and A~1⁢B2 states of N+3 at the EOM-EE-CCSD level using the direct method. See Section 7.11.27 for the specifics of performing MECP optimization with coupled cluster.
   N1
   N2 N1 rNN
   N3 N2 rNN N1 aNNN
   rNN  =  1.54
   aNNN = 50.0
   JOBTYPE                opt
   MECP_OPT               true
   MECP_METHODS           mecp_direct
   BASIS                  6-31g
   EE_SINGLETS            [0,2,0,2]
   XOPT_STATE_1           [0,2,2]
   XOPT_STATE_2           [0,4,1]
   CCMAN2                 false
   GEOM_OPT_TOL_GRADIENT  30
Example 9.30  Optimization of the ethylidene MECP between S0 and S1 at the SF-TDDFT level with analytic derivative couplings.
   C   0.044626  -0.241924   0.357157
   C   0.008905   0.672754   1.460500
   H   0.928425  -0.145916  -0.272095
   H  -0.831032  -0.192689  -0.288529
   H  -0.009238   0.961133   2.479936
   H   0.068314  -1.253358   0.778847
   JOBTYPE            opt
   MECP_OPT           true
   MECP_PROJ_HESS     true
   GEOM_OPT_COORDS    0
   MECP_STATE1        [0,1]
   MECP_STATE2        [0,2]
   UNRESTRICTED       true
   SPIN_FLIP          true
   CIS_N_ROOTS        4
   CALC_NAC           true
   CIS_DER_NUMSTATE   2
   SET_ITER           50
   EXCHANGE           bhhlyp
   BASIS              6-31G(d,p)
integral_symmetry true
