7.13.13 Job Control Options for casman
In casman, the built-in methods can be run by simply setting the value of CORRELATION accordingly:
CORRELATION
CORRELATION
       Sets the pre-defined method to use for casman.
       SF-CAS CAS-SF with no perturbative corrections (or a custom method) SF-CAS(h,p) CAS-SF with perturbative corrections for hole (h) and particle (p) excitations SF-CAS(S) CAS-SF with perturbative corrections for single (h,p,hp) excitations SF-CAS(2x) CAS-SF with perturbative corrections for 2x (h,p,hp,hh,pp) excitations SF-CAS(3x) CAS-SF with perturbative corrections for 3x (h,p,hp,hh,pp,hhp,hpp) excitations SF-CAS(3x)+D CAS-SF with perturbative corrections for (h,p,hp,hh,pp,hhp,hpp) + MP2 RAS1→ RAS3 double excitations
If a custom excitation scheme is required, one can set CORRELATION = SF-CAS and set the following variables manually. (If you are using one of the built-in methods, setting these variables manually should be avoided, since they are automatically set up appropriately by Q-Chem if CORRELATION is not SF-CAS.)
RAS_N_SPIN_FLIP
RAS_N_SPIN_FLIP
       Sets the number of spin-flips.
       Maximum number of spin-flips (n=(α-β)/2)
       n Do n spin-flips
CAS_DO_NDPT
CAS_DO_NDPT
       Do non-degenerate perturbation theory?
       TRUE Do non-degenerate perturbation theory. FALSE Do not use non-degenerate perturbation theory.
CAS_QDPT_ORDER
CAS_QDPT_ORDER
       Order of terms kept in the quasi-degenerate perturbation theory denominator expansion.
       n Keep terms of order n in the denominator expansion.
CAS_DO_1X
CAS_DO_1X
       Do perturbative hole (h) and particle (p) correction?
       TRUE Do perturbative hole (h) and particle (p) correction FALSE Do not do perturbative hole (h) and particle (p) correction
CAS_DO_SINGLES
CAS_DO_SINGLES
       Do perturbative singles (h,p,hp) correction?
       TRUE Do perturbative singles correction FALSE Do not do perturbative singles correction
CAS_DO_2x
CAS_DO_2x
       Do perturbative 2x (h,p,hp,hh,pp) correction?
       TRUE Do perturbative 2x correction FALSE Do not do perturbative 2x correction
CAS_DO_3x
CAS_DO_3x
       Do perturbative 3x (h,p,hp,hh,pp,hhp,hpp) correction?
       TRUE Do perturbative 3x correction FALSE Do not do perturbative 3x correction
CAS_DO_DOUBLES
CAS_DO_DOUBLES
       Do perturbative (h,p,hp,hh,pp,hhp,hpp) correction + MP2 RAS1 → RAS3 doubles?
       TRUE Do perturbative (h,p,hp,hh,pp,hhp,hpp) + MP2 RAS1→ RAS3 doubles correction FALSE Do not do the correction
CAS_LEVEL_SHIFT
CAS_LEVEL_SHIFT
       Use a denominator level-shift?
       TRUE Use the denominator level-shift FALSE Do not use the denominator level-shift
CAS_SPARSE
CAS_SPARSE
       Use a sparse matrix multiply when forming the effective Hamiltonian?
       TRUE Use sparse matrix multiply in forming effective Hamiltonian FALSE Do not use sparse matrix multiply in forming effective Hamiltonian
       None. Can be useful for larger numbers of spin-flips.
