6.21 Adaptive Sampling Configuration Interaction Method
6.21.3 ASCI Job Control
Active space specification and convergence details are controlled by the $rem variables described in Section 6.19.3. During the course of an ASCI calculation, a file named wf_data is created in the scratch directory containing information on the determinants and weights in the ASCI wavefunction.
ASCI_DIAG
ASCI_DIAG
       Specifies the diagonalization procedure.
       1 Davidson solver 2 Eigen sparse matrix solver
       Use 2 for best trade-off of speed and memory usage. If memory usage becomes to great, switch to 1.
ASCI_NDETS
ASCI_NDETS
       Specifies the number of determinants to include in the ASCI wavefunction.
       N for a wavefunction with N determinants
       Typical ASCI expansions range from 50,000 to 2,000,000 determinants depending on active space size, complexity of problem, and desired accuracy
ASCI_CDETS
ASCI_CDETS
       Specifies the number of determinants to search over during ASCI wavefunction growth steps.
       -5
       N>0 search from the top N determinants N<0 search from the top determinants whose cumulative weight in the wavefunction corresponds to 1-2N
       Using a dynamically determined value (N<0) gives better results.
ASCI_USE_NAT_ORBS
ASCI_USE_NAT_ORBS
       Specifies whether rotation to a natural orbital basis should be carried out between growth steps.
       TRUE rotate to a natural orbital basis between growth wavefunction growth steps FALSE do not rotate to a natural orbital basis
       Natural orbital rotations significantly improve the compactness and therefore accuracy of the ASCI wavefunction.
ASCI_DAVIDSON_GUESS
ASCI_DAVIDSON_GUESS
       Specifies the truncated CI guess used for ASCI’s Davidson solver.
       N Order of the truncated CI to solve explicitly ASCI Davidson guess.
       Accurate excited states and rapid convergence of the ground state benefit from a good zero-order guess for the low energy spectrum. The default is often sufficient.
ASCI_SKIP_PT2
ASCI_SKIP_PT2
       Specifies whether ASCI PT2 correction should be calculated.
       FALSE compute ASCI PT2 contribution TRUE do not compute ASCI PT2 contribution
       The PT2 correction is essential to obtaining converged ASCI energies.
ASCI_RESTART
ASCI_RESTART
       Specifies whether to initialize the ASCI wavefunction with the wf_data file.
       TRUE read CI coefficients from the wf_data file FALSE do not read the CI coefficients from disk
ASCI_SPIN_PURIFY
ASCI_SPIN_PURIFY
       Indicates whether or not the ASCI wavefunction should be augmented with missing determinants to ensure a spin-pure state.
       TRUE augment the wavefunction with determinants to ensure a spin eigenstate FALSE do not augment the wavefunction
Example 6.49  CASCI calculation for the lowest triplet (Ms=1) state of N2. The adaptive sampling method is employed to tackle a large active space (14e, 32o). The PT2 correction is performed on top of the ASCI wavefunction.
   N   0.0   0.0   0.0
   N   0.0   0.0   1.8
   EXCHANGE          hf
   BASIS             cc-pvtz
   CAS_METHOD        1     !1 for CAS-CI, 2 for CASSCF
   CAS_M_S           2     !M_s value*2 (2: triplet)
   ASCI_DIAG         2     !Arma Sparse=0, Davidson=1, Eigen Sparse=2
   CAS_N_ELEC        14    !N_elec
   CAS_N_ORB         32    !N_orb
   CAS_N_ROOTS       1     !N_roots
   CAS_SOLVER        2     !2=ASCI, 1=Olsen, 0=naive
   ASCI_NDETS        28000 !Number of ASCI Determinants
   THRESH            14
   MAX_SCF_CYCLES    400
   SCF_CONVERGENCE   8
   MEM_TOTAL         4000
   MEM_STATIC        1000
   ROSCF             true
integral_symmetry false
point_group_symmetry False
   SCF_ALGORITHM     diis_gdm
Example 6.50  ASCI-SCF (using adaptive sapling for CAS) calculation for the ground state of N2 with a large active space (14e, 32o). The PT2 correction is not performed in this case.
   N   0.0   0.0   0.0
   N   0.0   0.0   1.8
   EXCHANGE          hf
   BASIS             cc-pvtz
   CAS_METHOD        2  !1 for CAS-CI, 2 for CASSCF
   CAS_M_S           0  !M_s value*2
   CAS_N_ORB         32 !N_orb
   ASCI_SKIP_PT2     1
   THRESH            14
   MAX_SCF_CYCLES    400
   SCF_CONVERGENCE   6
   MEM_TOTAL         4000
   MEM_STATIC        1000
