7.8 Electron-Affinity Time-Dependent Density Functional Theory (EA-TDDFT)
7.8.1 Job Control
Like NOCIS/STEX/1C-NOCIS, the options for the EA-TDDFT/EA-CIS method are controlled via the $nocis section after NOCIS is set to TRUE in $rem.
NOCIS
NOCIS
       Requests a NOCIS/STEX/1C-NOCIS/EA-TDDFT calculation.
       FALSE Do not run these methods. TRUE Run one of these methods, options controlled in $nocis.
The options below are set within the $nocis section.
NUM_REF
       Sets the number of reference orbitals in a NOCIS/STEX/1C-NOCIS/EA-TDDFT calculation.
INPUT SECTION: $nocis
       n Positive integer
       Set according to the number of consecutive orbitals of interest for the calculation. For example, for the oxygen K-edge in CO2, the number of references would be 2 (two oxygen 1s orbitals), whereas for the carbon K-edge it would be 1 (one carbon 1s).
ORB_OFFSET
       Determines the starting orbital for a NOCIS/STEX/1C-NOCIS/EA-TDDFT calculation.
       n Positive integer
       Set according to the first orbital of interest in the system in question. For example, this would be set to 0 for the oxygen K-edge in CO2 because the two O(1s) orbitals lie below the C(1s), so for the carbon K-edge this would be set to 2.
LOCALIZE_ORBITALS
       Choose which core orbitals to localize with the Boys objective function.
       -1 for NUM_REF = 1 and equal to NUM_REF otherwise.
       n Integer, normally positive.
       Set to -1 to skip Boys localization entirely, or set to a value greater than NUM_REF to include more orbitals in the preliminary localization, otherwise use the default.
SUBSYSTEM_ATOMS
       Choose which atoms to consider for an EA-TDDFT calculation.
       List of integers delimited by spaces: i⁢j⁢k…
       Use only if excitations out of a particular subset of atoms is of interest and the definition of ORB_OFFSET and NUM_REF is nontrivial. This is an expert option, and should only be used in specific situations such as isolating the oxygen K-edge of all water molecules at the air/water interface.
DSCF_ALGORITHM
       Sets the ΔSCF algorithm to be used in the optimization of the core-ionized reference determinants.
       MOM
       MOM, IMOM, STEP, or STEP_MOM
       Use MOM unless convergence issues arise. IMOM occasionally provides improved convergence, but the combination of STEP and MOM used by the STEP_MOM option is particularly robust. In rare cases, STEP may be necessary, but this is not recommended as the number of SCF cycles required is quite large. If STEP_MOM is requested, the option STEP_MOM_START must also be set.
STEP_MOM_START
       Sets the SCF cycle on which the STEP algorithm stops and the MOM algorithm starts.
       5
       n Positive integer.
       For best results, set such that STEP reaches a convergence threshold of at least 10-4 a.u. before switching to MOM, but if MOM continues to collapse or oscillate, then wait until tighter convergence is achieved to switch algorithms.
REF_SCF_ALGORITHM
       Sets the SCF algorithm for the core-ion reference calculations.
       DIIS
       DIIS, GDM, GDM_LS, SGM, or SGM_LS
       Use DIIS for MOM, IMOM, STEP, or STEP_MOM calculations, but if these algorithms are not providing satisfactory convergence to the desired core-ion state, this can be set to SGM or SGM_LS.
REF_SCF_CONVERGENCE
       Sets SCF convergence threshold for the core-ion reference calculations.
       Same as SCF_CONVERGENCE in $rem
       n Positive integer
REF_SCF_GUESS
       Initial guess for core-ion reference calculations.
       Koopman
       Read (the Koopmans guess is automatically used if no option is specified)
       The default core-ion guess is generated by removing an electron from the core orbital using the ground-state MO coefficients (Koopmans guess). Alternatively, when convergence issues arise it may be useful to run an EA-TDDFT job with a different functional (i.e., LDA or GGA), then read the converged core-ion orbitals into a subsequent EA-TDDFT job with the functional of interest (i.e., a range-separated hybrid).
EA_TDA
       Invokes EA-TDDFT within the Tamm-Dancoff approximation.
       The presence of this keyword will activate EA_TDA.
       This is the most cost-effective form of the EA-TDDFT equations and has almost no effect on results for K-edge XAS.
EA_RPA
       Solves the full EA-TDDFT equations.
       The presence of this keyword will activate EA_RPA.
       No recommendation.
SINGLETS
       Compute only singlets.
       The presence of this keyword without the Triplets keyword will compute singlets without computing triplets.
       No recommendation.
TRIPLETS
       Compute only triplets.
       The presence of this keyword without the Singlets keyword will compute triplets without computing singlets.
       No recommendation.
N_ROOTS
       Sets the number of roots to print.
       All
       n where n<mroots
       No recommendation. Beware that unlike CIS/TDDFT jobs this keyword only prints fewer roots, but the entirety of the Hamiltonian is still diagonalized via direct diagonalization.
PRINT_NTOS
       Prints natural transition orbitals to cube files for each root that is printed via the N_ROOTS keyword.
       The presence of this keyword automatically generates all NTOs (default), or N_ROOTS NTOs.
       No recommendation, but one should be sure to also include a $plots section with appropriate details such that the cube files can be generated.
Example 7.32  EA-TDDFT with Tamm-Dancoff approximation for the K-edge of NH3. This job truncates the number of printed (singlet) roots to 10. The core-ion SCF will use the SGM algorithm.
method          rCAM-B3LYP
rel_x2c         true
basis           aug-cc-pCVDZ
nocis           true
scf_convergence 8
thresh          14
integral_symmetry false
point_group_symmetry False
$nocis
n_roots         10
orb_offset      0
num_ref         1
singlets
ea_tda
ref_scf_algorithm sgm
N   0.0000   0.0000   0.1163
H   0.0000   0.9399  -0.2713
H   0.8140  -0.4700  -0.2713
H  -0.8140  -0.4700  -0.2713
Example 7.33  Full EA-TDDFT for the K-edge of NH3. The core-ion SCF will use the default MOM algorithm.
method          rCAM-B3LYP
rel_x2c         true
scf_convergence 8
basis           aug-cc-pCVDZ
nocis           true
thresh          14
$nocis
n_roots         10
orb_offset      0
num_ref         1
singlets
ea_rpa
