9.4 Constrained Optimization
9.4.3 Frozen Atoms
Absolute atom positions can be frozen with the FIXED section. The section starts with the FIXED keyword as the first line and ends with the ENDFIXED keyword on the last. The format to fix a coordinate or coordinates of an atom is:
atom    coordinate_reference
coordinate_reference can be any combination of up to three characters X, Y and Z to specify the coordinate(s) to be fixed: X, Y, Z, XY, XZ, YZ, XYZ. The fixing characters must be next to each other. e.g.,
FIXED
2 XY
ENDFIXED
means the x-coordinate and y-coordinate of atom 2 are fixed, whereas
FIXED
2 X Y
ENDFIXED
will yield erroneous results.
Note:  When the FIXED section is specified within $opt, the optimization will proceed in Cartesian coordinates.
Note that frequency calculations for a system with frozen atom constraints will generally produce imaginary frequencies. These arise because the Hessian computed for the frequency calculation has different physics compared to the gradient computed during the fixed-atom optimization. One possible workaround is simply to zero out the elements of the Hessian associated with the frozen atoms. This removes the contribution of the frozen atoms to the normal modes and reduces the number of frequencies computed. For a system with N atoms, where n atoms are frozen, there will be 3⁢(N-n)-6 normal modes, or 3⁢(N-n)-5 if the system is linear. This “zeroing out” approach can be requested with a pair of $rem variables, FRZN_OPT and FRZ_ATOMS, as described below. A more elegant approach is to replace the strictly fixed atomic positions with soft harmonic confining potentials, which achieves effectively the same result but allows for relaxation (i.e., optimization) of all atomic coordinates, so that a proper vibrational frequency calculation can be performed. The use of harmonic confining potentials as a replacement for fixed atom constraints is described in Section 9.4.7.
FRZN_OPT
FRZN_OPT
       Controls whether the job uses zeroed Hessian technique in the frequency calculations
       False
       False Do not use the zeroed out Hessian True Use the zeroed out Hessian
       False
FRZ_ATOMS
FRZ_ATOMS
       Controls the number of frozen atoms
       No default
       User defined
Note:  The above two $rem variables are only relevant to frequency calculations; they are not required in geometry optimization with fixed atoms.
Example 9.12  Optimization of the water dimer structure with the structure of the first water frozen
 O   -1.551007  -0.114520   0.000000
 H   -1.934259   0.762503   0.000000
 H   -0.599677   0.040712   0.000000
 O    1.350625   0.111469   0.000000
 H    1.680398  -0.373741  -0.758561
 H    1.680398  -0.373741   0.758561
 JOBTYPE          OPT
 METHOD           B3LYP
 BASIS            6-31G(D)
 SCF_CONVERGENCE  8
$opt
 FIXED
 1:3  XYZ
 ENDFIXED
Example 9.13  Frequency calculations using zeroed out Hessian technique. Note the frozen atom indices are specified in the $frozen_opt section.
   C        -0.0014570824    1.4001468208    0.0000000000
   H        -0.0030029737    2.4867609686    0.0000000000
   C        -1.2093554750    0.6986986619    0.0000000000
   H        -2.1525287416    1.2392252926    0.0000000000
   C        -1.2094237515   -0.6985901650    0.0000000000
   H        -2.1508487680   -1.2427180000    0.0000000000
   C        -0.0003285453   -1.3965954363    0.0000000000
   H        -0.0006460438   -2.4839940415    0.0000000000
   C         1.2098250013   -0.6978846084    0.0000000000
   H         2.1493830451   -1.2446769146    0.0000000000
   C         1.2133329176    0.6987868208    0.0000000000
   H         2.1550504173    1.2408406009    0.0000000000
   JOBTYPE      freq
   METHOD       b3lyp
   BASIS        6-31G*
   FRZN_OPT     1  ! Turns on the freq calculation with frozen Hessians
   FRZ_ATOMS    2  ! No. of frozen atoms
point_group_symmetry False
integral_symmetry false
$frozen_opt
1 11
