13.2 Intracules
13.2.3 Momentum Intracules
Analogous quantities can be defined in momentum space; I¯⁢(𝐯), for example, represents the probability density for the relative momentum 𝐯=𝐩1-𝐩2:
I¯⁢(𝐯)=∫π⁢(𝐩1,𝐩2)⁢δ⁢(𝐩12-𝐯)⁢𝑑𝐩1⁢𝑑𝐩2 (13.14)
where π⁢(𝐩1,𝐩2) momentum two-electron density. Similarly, the spherically averaged intracule
M⁢(v)=∫I¯⁢(𝐯)⁢d⁢Ω𝐯 (13.15)
where Ω𝐯 is the angular part of 𝐯, is a measure of relative momentum v=|𝐯| and is called the momentum intracule. The quantity M⁢(v) can be written as
M⁢(v)=∑μ⁢ν⁢λ⁢σΓμ⁢ν⁢λ⁢σ⁢(μ⁢ν⁢λ⁢σ)M (13.16)
where Γμ⁢ν⁢λ⁢σ is the two-particle density matrix and (μ⁢ν⁢λ⁢σ)M is the momentum integral 105 Besley N. A., Lee A. M., Gill P. M. W.
Mol. Phys.
(2002), 100, pp. 1763.
(μ⁢ν⁢λ⁢σ)M=v22⁢π2⁢∫ϕμ∗⁢(𝐫)⁢ϕν⁢(𝐫+𝐪)⁢ϕλ∗⁢(𝐮+𝐪)⁢ϕσ⁢(𝐮)⁢j0⁢(q⁢v)⁢𝑑𝐫⁢𝑑𝐪⁢𝑑𝐮 (13.17)
The momentum integrals only possess four-fold permutational symmetry, i.e.,
(μ⁢ν⁢λ⁢σ)M=(ν⁢μ⁢λ⁢σ)M=(σ⁢λ⁢ν⁢μ)M=(λ⁢σ⁢μ⁢ν)M (13.18)
(ν⁢μ⁢λ⁢σ)M=(μ⁢ν⁢σ⁢λ)M=(λ⁢σ⁢ν⁢μ)M=(σ⁢λ⁢μ⁢ν)M (13.19)
and therefore generation of M⁢(v) is roughly twice as expensive as P⁢(u). Momentum intracules can also be decomposed into Coulomb MJ⁢(v) and exchange MK⁢(v) components:
MJ⁢(v)=12⁢∑μ⁢ν⁢λ⁢σDμ⁢ν⁢Dλ⁢σ⁢(μ⁢ν⁢λ⁢σ)M (13.20)
MK⁢(v)=-12⁢∑μ⁢ν⁢λ⁢σ[Dμ⁢λα⁢Dν⁢σα+Dμ⁢λβ⁢Dν⁢σβ]⁢(μ⁢ν⁢λ⁢σ)M (13.21)
Again, the even-order moments are physically significant: 105 Besley N. A., Lee A. M., Gill P. M. W.
Mol. Phys.
∫0∞v0⁢M⁢(v)⁢𝑑v=n⁢(n-1)2 (13.22)
∫0∞u0⁢MJ⁢(v)⁢𝑑v=n22 (13.23)
∫0∞v2⁢PJ⁢(v)⁢𝑑v=2⁢n⁢ET (13.24)
∫0∞v0⁢MK⁢(v)⁢𝑑v=-n2 (13.25)
where n is the number of electrons and ET is the total electronic kinetic energy. Currently, Q-Chem can compute M⁢(v), MJ⁢(v) and MK⁢(v) using s and p basis functions only. Moments are generated using quadrature and consequently for accurate results M⁢(v) must be computed over a large and closely spaced v range.
