4.3 Basic SCF Job Control
4.3.4 Examples
Provided below are examples of Q-Chem input files to run ground state, HF single point energy calculations.
Example 4.2  Example Q-Chem input for a single point energy calculation on water. Note that the declaration of the single point $rem variable is redundant because it is the same as the Q-Chem default.
   H1  O  oh
   H2  O  oh  H1  hoh
   oh  =   1.2
   hoh = 120.0
   JOBTYPE       sp       Single Point energy
   METHOD        hf       Hartree-Fock
   BASIS         sto-3g   Basis set
Example 4.3  UHF/6-311G calculation on the Li atom. Note that correlation and the job type were not indicated because Q-Chem defaults automatically to no correlation and single point energies. Note also that, since the number of α and β electron differ, MOs default to an unrestricted formalism.
   Li
   METHOD     HF       Hartree-Fock
   BASIS      6-311G   Basis set
Example 4.4  ROHF/6-311G calculation on the Lithium atom.
   3
   UNRESTRICTED   false    Restricted MOs
