13.5.5 NEO-TDDFT
The NEO-TDDFT method 1361 Yang Y., Culpitt T., Hammes-Schiffer S.
J. Phys. Chem. Lett.
(2018), 9, pp. 1765.
is a multicomponent extension of the TDDFT method within the NEO framework. It allows the simultaneous calculation of the electronic and proton vibrational excitation energies. In the NEO-TDDFT method, the linear response of the NEO Kohn-Sham system to perturbative external fields is computed. The NEO-TDDFT working equation is
[𝐀e𝐁e𝐂𝐂𝐁e𝐀e𝐂𝐂𝐂T𝐂T𝐀p𝐁p𝐂T𝐂T𝐁p𝐀p]⁢[𝐗e𝐘e𝐗p𝐘p]=ω⁢[𝐈0000-𝐈0000𝐈0000-𝐈]⁢[𝐗e𝐘e𝐗p𝐘p] (13.46)
where
Ai⁢a,j⁢be =(ϵa-ϵi)⁢δa⁢b⁢δi⁢j+⟨a⁢j|i⁢b⟩+δ2⁢Eexcδ⁢Pj⁢be⁢δ⁢Pa⁢ie+δ2⁢Eepcδ⁢Pj⁢be⁢δ⁢Pa⁢ie (13.47)
Bi⁢a,j⁢be =⟨a⁢b|i⁢j⟩+δ2⁢Eexcδ⁢Pj⁢be⁢δ⁢Pi⁢ae+δ2⁢Eepcδ⁢Pj⁢be⁢δ⁢Pi⁢ae (13.48)
AI⁢A,J⁢Bp =(ϵA-ϵI)⁢δA⁢B⁢δI⁢J+⟨A⁢J|I⁢B⟩+δ2⁢Epxcδ⁢PJ⁢Bp⁢δ⁢PA⁢Ip+δ2⁢Eepcδ⁢PJ⁢Bp⁢δ⁢PA⁢Ip (13.49)
BI⁢A,J⁢Bp =⟨A⁢B|I⁢J⟩+δ2⁢Epxcδ⁢PJ⁢Bp⁢δ⁢PI⁢Ap+δ2⁢Eepcδ⁢PJ⁢Bp⁢δ⁢PI⁢Ap (13.50)
Ci⁢a,J⁢B =-⟨a⁢B|i⁢J⟩+δ2⁢Eepcδ⁢PJ⁢Bp⁢δ⁢Pa⁢ie (13.51)
Here, the occupied electronic orbitals are denoted with indices i and j, whereas the unoccupied electronic orbitals are denoted with indices a and b. The analogous upper case indices denote protonic orbitals. The solution of Eq. (13.46) provides the electronic and proton vibrational excitation energies ω, as well as the transition excitation and de-excitation amplitudes, 𝐗 and 𝐘, respectively. Analogous to the TDDFT method, the Tamm-Dancoff approximation (TDA) can be imposed within the NEO framework, defining the NEO-TDDFT-TDA method that is represented by
[𝐀e𝐂𝐂T𝐀p]⁢[𝐗e𝐗p]=ω⁢[𝐗e𝐗p]. (13.52)
The extension of the NEO-TDDFT and NEO-TDDFT-TDA approaches to open-shell electron systems is straightforward. 257 Culpitt T. et al.
(2019), 150, pp. 201101.
NEO-TDHF and NEO-CIS have similar forms as NEO-TDDFT and NEO-TDA without electron-proton, electron-electron, or proton-proton correlation. The analytical gradients for NEO-CIS/NEO-TDA/NEO-TDHF/NEO-TDDFT are available, 1212 Tao Z. et al.
(2021), 17, pp. 5110.
enabling geometry optimizations on the excited state vibronic potential energy surfaces. For NEO-TDA and NEO-TDDFT, analytical gradients are available for the epc17-2 functional or when no electron-proton correlation functional is used. The transition densities can be analyzed to determine the percentages of electronic and protonic character for each vibronic excited state.
