11.3.4 Additional Job Control Variables
A QM/MM job is requested by setting the $rem variables QM_MM_INTERFACE and FORCE_FIELD. Also required are a $qm_atoms input section and appropriate modifications to the $molecule section, as described above. Additional job control variables are detailed here.
QM_MM_INTERFACE
QM_MM_INTERFACE
       Enables internal QM/MM calculations.
       MM Molecular mechanics calculation (i.e., no QM region) ONIOM QM/MM calculation using two-layer mechanical embedding JANUS QM/MM calculation using electronic embedding
       The ONIOM model and Janus models are described above. Choosing MM leads to no electronic structure calculation. However, when using MM, one still needs to define the $rem variables BASIS and EXCHANGE in order for Q-Chem to proceed smoothly.
FORCE_FIELD
FORCE_FIELD
       Specifies the force field for MM energies in QM/MM calculations.
       AMBER99 AMBER99 force field CHARMM27 CHARMM27 force field OPLSAA OPLSAA force field
CHARGE_CHARGE_REPULSION
       The repulsive Coulomb interaction parameter for YinYang atoms.
       550
       n Use Q = n×10-3
       The repulsive Coulomb potential maintains bond lengths involving YinYang atoms with the potential V⁢(r)=Q/r. The default is parameterized for carbon atoms.
GAUSSIAN_BLUR
GAUSSIAN_BLUR
GAUSS_BLUR_WIDTH
GAUSS_BLUR_WIDTH
       Delocalization width for external MM Gaussian charges in a Janus calculations.
       n Use a width of n×10-4 Å.
       Blur all MM external charges in a QM/MM calculation with the specified width. Gaussian blurring is currently incompatible with PCM calculations. Values of 1.0–2.0 Å are recommended in Ref.  268 Das D. et al.
(2002), 117, pp. 10534.
MODEL_SYSTEM_CHARGE
MODEL_SYSTEM_CHARGE
       Specifies the QM subsystem charge if different from the $molecule section.
       n The charge of the QM subsystem.
       This option only needs to be used if the QM subsystem (model system) has a charge that is different from the total system charge.
MODEL_SYSTEM_MULT
MODEL_SYSTEM_MULT
       Specifies the QM subsystem multiplicity if different from the $molecule section.
       n The multiplicity of the QM subsystem.
       This option only needs to be used if the QM subsystem (model system) has a multiplicity that is different from the total system multiplicity. ONIOM calculations must be closed shell.
USER_CONNECT
USER_CONNECT
       Enables explicitly defined bonds.
       TRUE Bond connectivity is read from the $molecule section FALSE Bond connectivity is determined by atom proximity
       Set to TRUE if bond connectivity is known, in which case this connectivity must be specified in the $molecule section. This greatly accelerates MM calculations.
MM_SUBTRACTIVE
MM_SUBTRACTIVE
       Specifies whether a subtractive scheme is used in the ECoul, Eq. (11.50), portion of the calculation.
       FALSE Only pairs that are not 1-2, 1-3, or 1-4 pairs are used. TRUE All pairs are calculated, and then the pairs that are double counted (1-2, 1-3, and 1-4) are subtracted out.
       When running QM/MM or MM calculations there is not recommendation. When running a QM/MM-Ewald calculation the value must be set to TRUE.
FORCEMAN_PRINT
FORCEMAN_PRINT
       Controls printing level for MM (and thus QM/MM) jobs.
       0 Minimal printing, as befits a large MM job that runs for many steps. 1 Additional information including MM gradient. 2 Print individual terms in the MM energy expression. 3 Print connectivity information. 4 Print individual terms in the MM gradient.
       Use the default unless trying to diagnose a problem.
