10.7 Harmonic Vibrational Analysis
10.7.1 Introduction
Vibrational analysis is an extremely important tool for the quantum chemist, supplying a molecular fingerprint which is invaluable for aiding identification of molecular species in many experimental studies. Q-Chem includes a vibrational analysis package that can calculate vibrational frequencies and their infrared and Raman activities. 578 Johnson B. G., Florián J.
(1995), 247, pp. 120.
Vibrational frequencies are calculated by either using an analytic Hessian (if available; see Table 9.2) or, numerical finite difference of the gradient. The default setting in Q-Chem is to use the highest analytical derivative order available for the requested theoretical method. The performance of various ab initio theories in determining vibrational frequencies has been well documented; see Refs.  867 Murray C. W. et al.
(1992), 199, pp. 551.
, 1102 Scott A. P., Radom L.
J. Phys. Chem.
(1996), 100, pp. 16502.
, 581 Johnson B. G., Gill P. M. W., Pople J. A.
(1993), 98, pp. 5612.
When calculating analytic frequencies at the HF and DFT levels of theory, the coupled-perturbed SCF equations must be solved. This is the most time-consuming step in the calculation, and also consumes the most memory. The amount of memory required is 𝒪⁢(N2⁢M) where N is the number of basis functions, and M the number of atoms. This is an order more memory than is required for the SCF calculation, and is often the limiting consideration when treating larger systems analytically. Q-Chem incorporates a new approach to this problem that avoids this memory bottleneck by solving the CPSCF equations in segments. 641 Korambath P. P. et al.
Mol. Phys.
(2002), 100, pp. 1755.
Instead of solving for all the perturbations at once, they are divided into several segments, and the CPSCF is applied for one segment at a time, resulting in a memory scaling of 𝒪⁢(N2⁢M/Nseg), where Nseg is the number of segments. This option is invoked automatically by the program.
After a vibrational analysis, Q-Chem computes useful statistical thermodynamic properties at standard temperature and pressure following the rigid-rotor-harmonic-oscillator (RRHO) approach. These include the zero-point vibration energy (ZPVE) and, translational, rotational and vibrational, entropies and enthalpies. Note: in the Q-Chem output the “total enthalpy” actually means the total enthalpy correction to the internal energy. One must add this “total enthalpy” to the internal energy to obtain the total enthalpy in common sense. In addition to these thermal corrections, Q-Chem also prints the interpolated vibrational entropy and enthalpy according to the quasi-RRHO (qRRHO) approach by Head-Gordon and co-workers 743 Li Y.-P. et al.
J. Phys. Chem. C
(2015), 119, pp. 1840.
which extends Grimme’s previous scheme 439 Grimme S.
Chem. Eur. J
(2012), 18, pp. 9955.
to address low-frequency vibrations (see Section 10.7.2).
In order to carry out a frequency analysis users must at a minimum provide a molecule within the $molecule keyword and define an appropriate level of theory within the $rem keyword using the $rem variables EXCHANGE, CORRELATION (if required) (Chapter 4) and BASIS (Chapter 8). Since the default type of job (JOBTYPE) is a single point energy (SP) calculation, the JOBTYPE $rem variable must be set to FREQ.
Users should also be aware that the quality of the quadrature grid used in DFT calculations is more important when calculating second derivatives. The default grid for some atoms has changed in Q-Chem 3.0 (see Section 5.5) and for this reason vibrational frequencies may vary slightly form previous versions. It is recommended that a grid larger than the default grid is used when performing frequency calculations.
    Vibrational frequencies.
    Raman and IR activities and intensities (requires $rem DORAMAN).
    Atomic masses.
    Zero-point vibrational energy.
    Translational, rotational, and vibrational, entropies and enthalpies.
DORAMAN
DORAMAN
       Controls calculation of Raman intensities. Requires JOBTYPE to be set to FREQ
       FALSE Do not calculate Raman intensities. TRUE Do calculate Raman intensities.
VIBMAN_PRINT
VIBMAN_PRINT
       1 Standard full information print out. If VCI is TRUE, overtones and combination bands are also printed. 3 Level 1 plus vibrational frequencies in atomic units. 4 Level 3 plus mass-weighted Hessian matrix, projected mass-weighted Hessian matrix. 6 Level 4 plus vectors for translations and rotations projection matrix.
       Use the default.
CPSCF_NSEG
CPSCF_NSEG
       0 Determine the number of segments based on the memory request and MEM_TOTAL n User-defined. Use n segments when solving the CPSCF equations.
       Use the default.
Example 10.25  An EDF1/6-31+G* optimization, followed by a vibrational analysis. Doing the vibrational analysis at a stationary point is necessary for the results to be valid.
   C  1  co
   F  2  fc  1  fco
   H  2  hc  1  hco  3  180.0
   co  =   1.2
   fc  =   1.4
   hc  =   1.0
   fco = 120.0
   hco = 120.0
   JOBTYPE    opt
   METHOD     edf1
   BASIS      6-31+G*
   JOBTYPE    freq
   METHOD     edf1
   BASIS      6-31+G*
