7.13.14 Job Control Options for librassf
The librassf module can be enabled by setting EXCHANGE = HF, CORRELATION = RASCI2, and LIBRASSF = 1 in the $rem variable section. One should also indicate the number of roots by setting RAS_N_ROOTS appropriately. Although the module is called through RASCI2, most job control options are more similar to those found in RASCI1, with the exception of RAS_N_ROOTS.
The number of spin-flips and IP/EA are determined by the $rem variables RASSF_DELTA_ALPHA (the number of alpha electrons removed) and RASSF_DELTA_BETA (the number of beta electrons added). Hole and particle excitations can be added by setting the RAS_DO_HOLE and RAS_DO_PART keywords. Additionally, text files containing eigenvalues and eigenvectors can be printed via the RASSF_WRITE_EVALS and RASSF_WRITE_EVECS keywords.
RAS_N_ROOTS
RAS_N_ROOTS
       n n>0 Compute n RAS-CI states
RASSF_DELTA_ALPHA
RASSF_DELTA_ALPHA
       Sets the number of alpha electrons to remove relative to the reference.
       0 Remove no alpha electrons (use for EA) 1 Remove one alpha electron (use for 1SF, IP) 2 Remove two alpha electrons (use for 2SF, 1SF-IP)
RASSF_DELTA_BETA
RASSF_DELTA_BETA
       Sets the number of beta electrons to add relative to the reference.
       0 Add no beta electrons (use for IP) 1 Add one beta electron (use for 1SF, EA) 2 Add two beta electrons (use for 2SF, 1SF-EA)
RAS_DO_HOLE
RAS_DO_HOLE
       Enables hole excitations.
       0 No hole excitations (use for CAS or RAS(p)) 1 Single hole excitations (use for RAS(h) or RAS(h,p))
RAS_DO_PART
RAS_DO_PART
       Enables particle excitations.
       0 No particle excitations (use for CAS or RAS(h)) 1 Single particle excitations (use for RAS(p) or RAS(h,p))
N_FROZEN_CORE
N_FROZEN_CORE
       Number of frozen core orbitals.
       SIZE_T
       n n≥0 Number of frozen core orbitals.
N_FROZEN_VIRTUAL
N_FROZEN_VIRTUAL
       Number of frozen virtual orbitals.
       SIZE_T
       n n≥0 Number of frozen virtual orbitals.
RASSF_GUESS
RASSF_GUESS
       Determines which initial set of guess vectors to use for Davidson.
       0 Random orthonormal guess (default for CAS) 1 Identity guess 2 CAS guess (default for RAS)
       Starting from a CAS guess is recommended for larger molecules. If Davidson encounters issues with linearly dependent eigenvectors, consider using identity. The random orthonormal guess requires building a large N⁢x⁢N matrix and is therefore only recommended for calculations with fewer determinants.
RASSF_WRITE_EVALS
RASSF_WRITE_EVALS
       Determines whether to write eigenvalues to an output file.
       0 Do not write eigenvalues to an output file 1 Write eigenvalues to an output file
RASSF_WRITE_EVECS
RASSF_WRITE_EVECS
       Determines whether to write eigenvectors to an output file.
       0 Do not write eigenvectors to an output file 1 Write eigenvectors to an output file
CAS_LOCAL
CAS_LOCAL
       Determines whether to do localization.
       0 No localization 1 Boys localization 2 Pipek-Mezey localization
CAS_LOCAL_ALGO
CAS_LOCAL_ALGO
       Passed into localizer. Set to 1 if doing Boys localization.
RASSF_DO_BLOCH
RASSF_DO_BLOCH
       Determines whether to do effective Hamiltonian analysis.
       0 Skip analysis 1 Do effective Hamiltonian analysis
