11.4 Q-Chem/Charmm Interface
11.4.1 Overview
Q-Chem can be used a QM back-end for QM/MM calculations using the Charmm package. 545 III H. L. Woodcock et al.
(2007), 28, pp. 1485.
In this case, both software packages are required to perform the calculations, but all the code required for communication between the programs is incorporated in the released versions. Stand-alone QM/MM calculations are described in Section 11.3.
QM/MM jobs that use the Charmm interface are controlled using the following $rem keywords:
QM_MM
QM_MM
       Turns on the Q-Chem/Charmm interface.
       TRUE Do QM/MM calculation through the Q-Chem/Charmm interface. FALSE Turn this feature off.
       Use the default unless running calculations with Charmm.
QMMM_PRINT
QMMM_PRINT
       Controls the amount of output printed from a QM/MM job.
       TRUE Limit molecule, point charge, and analysis printing. FALSE Normal printing.
QMMM_CHARGES
QMMM_CHARGES
       Controls the printing of QM charges to file.
       TRUE Writes a charges.dat file with the Mulliken charges from the QM region. FALSE No file written.
       Use the default unless running calculations with Charmm where charges on the QM region need to be saved.
ESP_EFIELD
ESP_EFIELD
       Triggers the calculation of the electrostatic potential (ESP) and/or the electric field at the positions of the MM charges.
       0 Computes ESP only. 1 Computes ESP and electric field. 2 Computes electric field only.
GEOM_PRINT
GEOM_PRINT
       Controls the amount of geometric information printed at each step.
       TRUE Prints out all geometric information; bond distances, angles, torsions. FALSE Normal printing of distance matrix.
       Use if you want to be able to quickly examine geometric parameters at the beginning and end of optimizations. Only prints in the beginning of single point energy calculations.
QMMM_FULL_HESSIAN
QMMM_FULL_HESSIAN
       Trigger the evaluation of the full QM/MM Hessian.
       TRUE Evaluates full Hessian. FALSE Hessian for QM-QM block only.
LINK_ATOM_PROJECTION
       Controls whether to perform a link-atom projection
       TRUE Performs the projection FALSE No projection
       Necessary in a full QM/MM Hessian evaluation on a system with link atoms
HESS_AND_GRAD
HESS_AND_GRAD
       Enables the evaluation of both analytical gradient and Hessian in a single job
       TRUE Evaluates both gradient and Hessian. FALSE Evaluates Hessian only.
       Use only in a frequency (and thus Hessian) evaluation.
GAUSSIAN_BLUR
GAUSSIAN_BLUR
SKIP_CHARGE_SELF_INTERACT
       Ignores the electrostatic interactions among external charges in a QM/MM calculation.
       TRUE No electrostatic interactions among external charges. FALSE Computes the electrostatic interactions among external charges.
Example 11.26  Do a basic QM/MM optimization of the water dimer. You need Charmm to do this but this is the Q-Chem file that is needed to test the QM/MM functionality. These are the bare necessities for a Q-Chem/Charmm QM/MM calculation.
   O    -0.91126   1.09227   1.02007
   H    -1.75684   1.51867   1.28260
   H    -0.55929   1.74495   0.36940
   METHOD        hf        ! HF Exchange
   BASIS         cc-pvdz   ! Correlation Consistent Basis
   QM_MM         true      ! Turn on QM/MM calculation
   JOBTYPE       force     ! Need this for QM/MM optimizations
$external_charges
   1.20426      -0.64330   0.79922  -0.83400
   1.01723      -1.36906   1.39217   0.41700
   0.43830      -0.06644   0.91277   0.41700
The Q-Chem/Charmm interface is unique in that:
    The external point charges can be replaced with Gaussian-delocalized charges with a finite width. 268 Das D. et al.
    (2002), 117, pp. 10534.
    This is an empirical way to include the delocalized character of the electron density of atoms in the MM region. This can be important for the electrostatic interaction of the QM region with nearby atoms in the MM region.
    We allow the evaluation of the full QM/MM Hessian. 1339 Woodcock H. L. et al.
    (2008), 129, pp. 214109.
    When link atoms are inserted to saturate the QM region, all Hessian elements associated with link atoms are automatically projected onto their QM and MM host atoms.
    For systems with a large number of MM atoms, one can define blocks consisting of multiple MM atoms (i.e., mobile blocks) and efficiently evaluate the corresponding mobile-block Hessian (MBH) for normal mode analysis.
