6.11 Non-Iterative Corrections to Coupled Cluster Energies
6.11.1 (T) Triples Corrections
To approach chemical accuracy in reaction energies and related properties, it is necessary to account for electron correlation effects that involve three electrons simultaneously, as represented by triple substitutions relative to the mean field single determinant reference, which arise in MP4. The best standard methods for including triple substitutions are the CCSD(T) 1028 Raghavachari K. et al.
(1989), 157, pp. 479.
and QCISD(T) methods. 1000 Pople J. A., Head-Gordon M., Raghavachari K.
(1987), 87, pp. 5968.
The accuracy of these methods is well-documented for many cases, and in general is a very significant improvement relative to the starting point (either CCSD or QCISD). The cost of these corrections scales with the 7th power of molecule size (or the 4th power of the number of basis functions, for a fixed molecule size), although no additional disk resources are required relative to the starting coupled-cluster calculation. Q-Chem supports the evaluation of CCSD(T) and QCISD(T) energies, as well as the corresponding OD(T) correction to the optimized doubles method discussed in the previous subsection. Gradients and properties are not yet available for any of these (T) corrections.
