10.11 Vibrational Circular Dichroism (VCD)
10.11.1 Introduction
The VCD signals in dilute solution in terms of the differential molar extinction coefficient, Δ⁢ϵ=ϵleft-ϵright, is given by
Δ⁢ϵ=4⁢γ⁢ν⁢∑iαg⁢Rg⁢i⁢f⁢(νg⁢i,ν), (10.85)
where
γ=NA⁢π3375⁢ln⁡(10)⁢h⁢c, (10.86)
NA is Avogadro constant, h is Planck’s constant and c is the speed of light, ν is the frequency of the incident light, and αg is the population of the ground state The quantity Rg⁢i is the rotational strength, with indices g and i represent the ground state and the ith vibrational excited state, respectively; f(νg⁢i is the lineshape function; and νg⁢i is the transition frequency between vibrational states g and i. The rotational strength is given by
Rg⁢i=ℑ⁡[𝑷i⋅𝑴i], (10.87)
where ℑ⁡[⋯] means the the imaginary part of a complex number, 𝑴i is the vibrational magnetic transition dipole vector, and 𝑷i is the vibrational electric transition dipole vector. The latter can be expressed as
𝑷i=⟨0|𝝁^e|1⟩i=ℏ4⁢π⁢νi⁢(∂⁡⟨Ψg|𝝁^e|Ψg⟩∂⁡Qi)|R0. (10.88)
Ψg denotes the ground state wave function, Qi is the i-h normal mode, and this derivative is evaluated at the equilibrium geometry R0. The quantity
𝝁^e=1+∑λZλ⁢δ⁢(r-Rλ)⁢e⁢r (10.89)
is the electric transition dipole operator, where Zλ is the atomic number for atom λ, located at position Rλ.
Since the probability of the 1←0 transition of the ith normal mode is proportional to the modulus square of the corresponding electric transition dipole, |𝑷i|2, the quantity 𝑷i is evaluated in the frequency subroutine. Suppose the linear transform relation between the normal modes Qi and the atomic Cartesian displacement iis
Xλ⁢α=∑iSλ⁢α,i⁢Qi (10.90)
where λ is the index for nuclei and α∈{x,y,z}. Matrix elements Sλ⁢α,i define the normal modes and are obtained from a harmonic frequency calculation. We can define the atomic polar tensor (APT) having matrix elements
𝑷λ⁢α,β=(∂⁡⟨Ψg|(𝝁^e)β|Ψg⟩∂⁡𝑿λ⁢α)|R0. (10.91)
Thus,
𝑷~i⁢β=ℏ4⁢π⁢νi⁢∑λ⁢α𝑷λ⁢α,β⁢𝑺λ⁢α,i. (10.92)
The quantity 𝑷λ⁢α,β can be separated into the nuclear and electronic parts,
𝑷λ⁢α,β=𝑵λ⁢α,β+𝑬λ⁢α,β, (10.93)
where
𝑵λ⁢α,β=Zλ⁢e⁢δα⁢β (10.94)
and
𝑷λ⁢α,β=(∂⁡⟨Ψg|e⁢𝒓β|Ψg⟩∂⁡𝑿λ⁢α)|R0=2⁢⟨ψg|e⁢𝒓β|∂⁡Ψg∂⁡Xλ⁢α⟩. (10.95)
Similarly, for the vibrational magnetic transition dipole 𝑴~i, we have
𝑴~i⁢β=⟨0|𝝁^m|1⟩i⁢β=-4⁢π⁢ℏ3⁢νi⁢∑λ⁢α𝑴λ⁢α,β⁢Sλ⁢α,i (10.96)
where
𝝁^m=e2⁢m⁢(r^×p^) (10.97)
and 𝑴α⁢βλ is the atomic axial tensor (AAT). Moreover,
𝑴λ⁢α,β=𝑰λ⁢α,β+𝑱λ⁢α,β (10.98)
where
𝑰λ⁢α,β=⟨(∂⁡Ψg∂⁡Xλ⁢α)R0|(∂⁡Ψg∂⁡Hβ)Hβ=0⟩ (10.99)
and
𝑱λ⁢α,β=i4⁢ℏ⁢c⁢∑γϵα⁢β⁢γ⁢Zλ⁢e⁢Rλ⁢γ. (10.100)
The quantity ϵα⁢β⁢γ is Levi-Civita symbol and Rλ⁢γ is some Cartesian component of Rγ (γ∈{x,y,z}). The derivative of the wavefunction with respect to the external magnetic field Hβ is evaluated with a perturbation H′=-𝝁m⋅Hβ at the limit of Hβ→0. Note that M~i is pure imaginary if real basis functions are used.
The working equation for rotational strength can be expressed as
Rg⁢i=ℏ2⁢ℑ⁡[∑β(∑λ⁢α𝑷λ⁢α,β⁢Sλ⁢α,i⋅∑λ′⁢α′𝑴λ′⁢α′,β′⁢Sλ′⁢α′,i)] (10.101)
where λ′, α′, and β′ are dummy indices for atoms and Cartesian coordinates, respectively. The 𝑰α⁢βλ tensor can be rewritten as
𝑰λ⁢α,β=∑μ⁢ν(Dμ⁢ν⁢⟨χμXλ⁢α|χνHβ⟩+Dμ⁢νHβ⁢⟨χμXλ⁢α|χν⟩+Dμ⁢νXλ⁢α⁢⟨χμ|χνHβ⟩+Dμ⁢νXλ⁢α,Hβ⁢⟨χμ|χν⟩), (10.102)
defining the intermediate quantities
Dμ⁢ν =∑iocccμ⁢i∗⁢cν⁢i (10.103a)
Dμ⁢νHβ =∑iocccμ⁢i∗⁢cν⁢iHβ (10.103b)
Dμ⁢νXλ⁢α =∑iocccμ⁢iXλ⁢α⁣∗⁢cν⁢i (10.103c)
Dμ⁢νXλ⁢α,Hβ =∑icμ⁢iXλ⁢α⁣∗⁢cν⁢iHβ (10.103d)
and
cν⁢iHβ =∂⁡cν⁢i∂⁡Hβ|Hβ=0 (10.104a)
cμ⁢iXλ⁢α =∂⁡cμ⁢i∂⁡Xλ⁢α|R0=0 (10.104b)
where χμ,ν are AO basis functions and cμ,ν⁢i are MO coefficients. Superscripts of c indicate MO coefficient derivatives with respect to nuclear position and magnetic field. Derivatives of the MO coefficient are obtained by solving CPHF/CPKS equations.
Electric transition dipoles are origin-independent while magnetic transition dipoles are origin-dependent with finite basis sets. In order to obtain origin-independent (gauge-invariant) VCD properties, one can employ the explicit field-dependent GIAO basis functions:
χμ,GIAO⁢(𝑯)=exp⁢[-i2⁢c⁢(𝑯×𝑹μ)⋅𝒓]⁢χμ (10.105)
To extract the VCD properties, one should (at a minimum) carry out a frequency analysis with the system. Several available $rem variables include:
VCD
VCD
       Controls calculation of the VCD signals. Requires JOBTYPE to be set to FREQ
       FALSE Do not calculate the VCD properties. TRUE Do calculate the VCD properties.
VCD_PRINT
VCD_PRINT
       Controls level of extra print out for the VCD calculations.
       1 Standard full information print out. 2 Electronic part of AAT.
       Use the default.
Example 10.49  An PBE/STO-3G optimization, followed by a VCD calculation.
(-)-camphore
 O  -2.5217    0.3747   -0.2628
 C   0.9690    0.2807   -0.4137
 C  -0.2122    0.5268    0.5653
 C   0.5981   -1.2183   -0.5902
 C  -0.0177   -0.5488    1.6588
 C   0.5627   -1.7425    0.8680
 C  -0.8632   -1.1910   -1.1027
 C  -1.3692   -0.0289   -0.2712
 C   0.9102    1.0940   -1.7214
 C   2.3671    0.5229    0.1910
 C  -0.4232    1.9305    1.0788
 H   1.2655   -1.7945   -1.2356
 H  -0.9615   -0.8246    2.1436
 H   0.6774   -0.2257    2.4410
 H   1.5668   -1.9925    1.2263
 H  -0.0563   -2.6395    0.9757
 H  -1.4099   -2.1082   -0.8724
 H  -0.9272   -0.9564   -2.1673
 H   1.1849    2.1396   -1.5401
 H  -0.0766    1.1153   -2.1913
 H   1.6143    0.6876   -2.4563
 H   2.5320    0.0303    1.1519
 H   2.5399    1.5928    0.3537
 H   3.1441    0.1597   -0.4916
 H   0.4499    2.2884    1.6335
 H  -0.6167    2.6304    0.2592
 H  -1.2875    1.9748    1.7507
   JOBTYPE opt
   BASIS sto-3g
   METHOD pbe
point_group_symmetry = False
integral_symmetry = false
   no_reorient true
   JOBTYPE = freq
   BASIS  = sto-3g
   METHOD  =  PBE
   VCD = 1
   VCD_PRINT = 2
   no_reorient true
