6.6.8 RI-TRIM MP2 Energies
The triatomics in molecules (TRIM) local correlation approximation to MP2 theory 715 Lee M. S., Maslen P. E., Head-Gordon M.
(2000), 112, pp. 3592.
was described in detail in Section 6.5.1, which also discussed our implementation of this approach based on conventional four-center two-electron integrals. Starting from Q-Chem v. 3.0, an auxiliary basis implementation of the TRIM model is available. The new RI-TRIM MP2 energy algorithm 297 DiStasio, Jr. R. A., Jung Y., Head-Gordon M.
(2005), 1, pp. 862.
greatly accelerates these local correlation calculations (often by an order of magnitude or more for the correlation part), which scale with the 4th power of molecule size. The electron correlation part of the calculation is speeded up over normal RI-MP2 by a factor proportional to the number of atoms in the molecule. For a hexadecapeptide, for instance, the speedup is approximately a factor of 4. 297 DiStasio, Jr. R. A., Jung Y., Head-Gordon M.
(2005), 1, pp. 862.
The TRIM model can also be applied to the scaled opposite spin models discussed above. As for the other RI-based models discussed in this section, we recommend using RI-TRIM MP2 instead of the conventional TRIM MP2 code whenever run-time of the job is a significant issue. As for RI-MP2 itself, TRIM MP2 is invoked by adding AUX_BASIS $rems to the input deck, in addition to requesting CORRELATION = RILMP2.
Example 6.18  Example of RI-TRIM MP2 energy evaluation
   C1
   H1   C1   1.07726
   H2   C1   1.07726   H1   131.60824
   METHOD         rilmp2
   BASIS          cc-pVDZ
   AUX_BASIS      rimp2-cc-pVDZ
   PURECART       1111
   UNRESTRICTED   true
integral_symmetry false
