Q-Chem features a number of methods to apply pressure to a chemical system
during a geometry optimization or an AIMD simulation.
1211
Int. J. Quantum Chem.
(2021),
121,
pp. e26208.
The
following methods are implemented:
| Hydrostatic Compression Force Field (HCFF)
1208
ChemPhysChem (2019), 20, pp. 2742. Link |
Section 9.5.2.1 |
| eXtended Hydrostatic Compression Force Field (X-HCFF)
1210
J. Chem. Phys. (2020), 153, pp. 134503. Link |
Section 9.5.2.2 |
| Gaussians On Surface Tesserae Simulate HYdrostatic Pressure (GOSTSHYP)
1126
J. Chem. Theory Comput. (2021), 17, pp. 583. Link |
Section 9.5.2.3 |
To invoke one of these methods, set DISTORT = TRUE in the $rem section. By setting the $rem variable scf_final_print = 1, the energy contribution due to pressure is printed in the output.
DISTORT
DISTORT
Specifies whether to apply pressure or external force to a chemical system
False
False
Do not use pressure or force
True
Use pressure or force
Set to true to apply pressure or force.
The parameters of the jobs are set via options specified in the $distort input section. The format of the $distort section is analogous to the $rem section:
$distort <Keyword> <parameter/option> $end
Note: The following job control variables belong only in the $distort section. Do not place them in the $rem section.
Model
Specifies which model is used to distort the molecule.
INPUT SECTION: $distort
HCFF
1208
ChemPhysChem
(2019),
20,
pp. 2742.
XHCFF
1210
J. Chem. Phys.
(2020),
153,
pp. 134503.
GOSTSHYP
1126
(2021),
17,
pp. 583.
EFEI
External Force is Explicitly Included (Section 9.5.1)
Please refer to the following subsections for recommendations on which
model to use.
Pressure
Specifies the pressure (in MPa) used to compress the molecule.
DOUBLE
User defined
NPoints_Heavy
Specifies the number of tessellation points per non-hydrogen atom.
110
User defined
Use the default.
NPoints_Hydrogen
Specifies the number of tessellation points per hydrogen atom.
110
User defined
Use the default.
Scaling
Specifies the scaling factor of the atomic van der Waals radii used
in the tessellation of the molecular surface, which is used in the pressure models.
DOUBLE
1.2
User defined
Increase when modeling a chemical complex to make sure that the complex is
placed inside a single cavity.
1126
(2021),
17,
pp. 583.
A value of 1.0 was suggested
to be used in the X-HCFF model.
1210
J. Chem. Phys.
(2020),
153,
pp. 134503.
Screener
Enables/disables Integral screening for gostshyp calculations.
BOOL
True
True
Enable integral screening for gostshyp
False
Disable integral screening for gostshyp
Use default. Disabling integral screening will lead to much higher memory usage
and severe performance drops.
The Hydrostatic Compression Force Field (HCFF) model was introduced by Stauch,
Chakraborty and Head-Gordon.
1208
ChemPhysChem
(2019),
20,
pp. 2742.
In HCFF, mechanical forces that
point towards the non-mass-weighted molecular centroid are used to compress a
molecule. Care must be exercised when modeling extended molecules due to the
tendency of HCFF to generate spherical geometries under very high
pressure.
1211
(2021),
121,
pp. e26208.
Also, the pressure input by the user is only a
guess for the pressure that is applied to the molecule. The latter is
calculated a posteriori based on the generated geometry and the
molecular surface and is output as HCFF Macroscopic Pressure. Typically,
the applied pressure is lower than the input pressure. It should be noted that
the dependence on the nuclear gradient precludes the application of pressure to
single atoms in HCFF. Moreover, the increase in electronic energy when
compressing a molecule is typically underestimated by HCFF, since the pressure
acts only on the nuclei, whereas the compression of electron density is not
modeled directly. HCFF works with any electronic structure method for which a
nuclear gradient is available.
Example 9.15 Geometry optimization of diborane under pressure using the HCFF model with an input pressure of 3808 MPa
$molecule 0 1 B 0.0000000000 0.0000000000 0.8917854534 B 0.0000000000 0.0000000000 -0.8917854534 H -0.5244343500 0.9105724300 1.4720415209 H 0.5244343500 -0.9105724300 1.4720415209 H -0.5244343500 0.9105724300 -1.4720415209 H 0.5244343500 -0.9105724300 -1.4720415209 H 0.8561835151 0.4929549655 0.0000000000 H -0.8561835151 -0.4929549655 0.0000000000 $end $rem JOBTYPE opt METHOD m06-2x BASIS 6-311++G(d,p) DISTORT true $end $distort model hcff pressure 3808 scaling 1.0 npoints_heavy 590 npoints_hydrogen 590 $end
The eXtended Hydrostatic Compression Force Field (X-HCFF) approach was introduced
by Stauch to solve the problems associated with HCFF.
1210
J. Chem. Phys.
(2020),
153,
pp. 134503.
In X-HCFF,
mechanical forces are used to compress the molecule as well, but, in contrast to
HCFF, these forces are strictly perpendicular to the tessellated molecular surface,
thus simulating truly hydrostatic conditions. As a result, chemically feasible
geometries are retained even at high pressures. In addition, the user is able to
input the precise pressure that is applied to the molecule during the simulation.
It was suggested to use the unscaled atomic van der Waals radii in the tessellation
routine.
1210
J. Chem. Phys.
(2020),
153,
pp. 134503.
X-HCFF works with any electronic structure method for
which a nuclear gradient is available.
It is also possible to perform an analytic Hessian
calculation with X-HCFF using JOBTYPE = FREQ, to obtain related
structural properties such as IR and Raman frequencies.
As in HCFF, the application of pressure to atoms cannot be modeled realistically with X-HCFF, and the observed pressure-induced increase in electronic energy is typically too low.
Example 9.16 Geometry optimization of the CO dimer under a pressure of 100 GPa using the X-HCFF model
$molecule 0 1 O 2.6192991230 -0.0571311942 0.0000000000 C 1.6782610262 0.6502025480 0.0000000000 O 0.7413912820 1.3674070371 0.0000000000 C -1.6782610262 -0.6502025480 0.0000000000 O -2.6192991230 0.0571311942 0.0000000000 O -0.7413912820 -1.3674070371 0.0000000000 $end $rem JOBTYPE opt METHOD pbe BASIS cc-pvdz DISTORT true $end $distort model xhcff pressure 100000 scaling 1.0 npoints_heavy 302 npoints_hydrogen 302 $end
The Gaussians On Surface Tesserae Simulate HYdrostatic Pressure (GOSTSHYP)
method, which was introduced by Scheurer and co-workers,
1126
(2021),
17,
pp. 583.
overcomes the problems associated with the mechanochemical models of pressure,
i.e. HCFF and X-HCFF. GOSTSHYP uses a uniform field of Gaussian potentials
that is placed on the tessellated molecular surface and that compresses the
electron density. Each Gaussian potential G has the form
| (9.43) |
During the GOSTSHYP routine, the parameters of the Gaussian potentials, and , are adjusted such that a user-defined pressure is applied. Atoms and molecules can be treated, and the pressure-induced increase in the electronic energy is physically sound. During the SCF, the energy expression takes the form
| (9.44) |
Due to the availability of nuclear gradients, geometry optimizations under pressure using the GOSTSHYP model are possible. At present, GOSTSHYP is implemented at the SCF level, allowing calculations with Hartree-Fock and Density Functional Theory.
For good performance GOSTSHYP needs relatively large amounts of available RAM. If not enough available RAM is detected, GOSTSHYP will switch to a memory efficient algorithm at the cost of performance, a warning containing the required amount of memory for better performance will be printed in the output.
We found, that at the edges between the tessellation spheres of two atoms "negative amplitudes" may appear. Since those would lead to nonphysical attractive pressure potentials they are generally blacklisted in GOSTSHYP calculations. This however leads to instabilities within SCF calculations. We found that negative amplitudes appear very rarely for VDW-scaling factors larger than but become more likely to appear for smaller scaling factors. Thus we recommend to use a scaling factor of at least in GOSTSHYP calculations.
Example 9.17 Geometry optimization of cyclopentadiene and ethylene under a pressure of 40 GPa using the GOSTSHYP model
$molecule 0 1 C 1.1148422354 -0.6418674001 0.7279292386 C 1.1148422354 -0.6418674001 -0.7279292386 C 0.5936432126 0.5363396649 1.1772168767 C -2.0464511598 -0.6129291257 0.6711240568 C -2.0464511598 -0.6129291257 -0.6711240568 C 0.5936432126 0.5363396649 -1.1772168767 C 0.2915208637 1.4128825196 0.0000000000 H 0.9756522868 2.2894492537 0.0000000000 H -0.7374232239 1.8214336422 0.0000000000 H 1.4681344173 -1.4690333337 -1.3527755131 H 1.4681344173 -1.4690333337 1.3527755131 H -2.3879086093 0.2541525765 1.2531118994 H -1.7231567891 -1.4887031107 1.2461940178 H -1.7231567891 -1.4887031107 -1.2461940178 H -2.3879086093 0.2541525765 -1.2531118994 H 0.4773764265 0.8454441265 2.2200767812 H 0.4773764265 0.8454441265 -2.2200767812 $end $rem JOBTYPE opt METHOD pbe BASIS cc-pvdz GEOM_OPT_MAX_CYCLES 150 SCF_ALGORITHM diis_gdm MAX_SCF_CYCLES 150 USE_LIBQINTS 1 GEN_SCFMAN 1 DISTORT 1 $end $distort model gostshyp pressure 40000 npoints_heavy 302 npoints_hydrogen 302 scaling 1.8 $end
