The simplest method within the NEO framework is the Hartree-Fock (NEO-HF) method, where the total nuclear-electronic wavefunction is approximated as a product of electronic () and nuclear () Slater determinants composed of electronic and protonic spin orbitals, respectively:
| (13.33) |
Here, and are collective spatial and spin coordinates of the quantum electrons and protons. The NEO-HF energy for a restricted Hartree-Fock (RHF) treatment of the electrons and a high-spin open-shell treatment of the quantum protons is
| (13.34) |
The , indices denote occupied spatial electronic orbitals, and the , indices correspond to occupied spatial protonic orbitals. In Eq. (13.34), and are conventional electronic core Hamiltonian and two-electron integrals, respectively, and the corresponding terms for quantum protons are defined analogously. The last term in Eq. (13.34) is the Coulomb interaction between the electrons and the quantum protons. The spatial electronic and protonic orbitals [ and ] are expanded as linear combinations of electronic or protonic Gaussian basis functions [ or ]:
| (13.35a) | ||||
| (13.35b) | ||||
The lower-case Greek letters without and with primes denote basis functions for electrons and protons, respectively, and and are electronic and protonic MO expansion coefficients, respectively.
Analogous to the conventional electronic Hartree-Fock method, the electronic and protonic coefficients are determined by variationally minimizing the energy in Eq. (13.34) via the self-consistent field (SCF) procedure. This procedure leads to a set of coupled electronic and protonic Roothaan equations:
| (13.36a) | ||||
| (13.36b) | ||||
where and are electronic and protonic overlap matrices, respectively. The electronic and protonic Fock elements in Eqs. (13.36a) and (13.36b) are given by
| (13.37a) | ||||
| (13.37b) | ||||
The electronic and protonic density matrix elements in Eqs. (13.37a) and (13.37b) are defined as
| (13.38a) | ||||
| (13.38b) | ||||
The generalization to the unrestricted Hartree-Fock (NEO-UHF) treatment of electrons is accomplished by introducing separate spatial orbitals for and electron spins.
The analytical gradients of the NEO-HF energy
1335
J. Chem. Phys.
(2002),
117,
pp. 4106.
with respect to the classical nuclear coordinates (or coordinates of the centers of the quantum proton basis functions) are available. These gradients allow geometry optimizations within the NEO framework. The analytical Hessians of the NEO-HF energy with respect to the classical nuclear coordinates are also available.
1134
J. Chem. Phys.
(2021),
154,
pp. 054108.
The Hessians can identify whether the optimized geometries are minima or transition states on the ground state vibronic potential energy surface.
NEO density functional theory (NEO-DFT)
966
J. Phys. Chem. A
(2007),
111,
pp. 4522.
213
Phys. Rev. Lett.
(2008),
101,
pp. 153001.
214
J. Chem. Phys.
(2009),
131,
pp. 124115.
is an extension of DFT to multicomponent systems within the NEO framework. The Hohenberg-Kohn theorems have been extended to multicomponent systems, where the reference is expressed as the product of electronic and nuclear Slater determinants composed of Kohn-Sham orbitals. The NEO-DFT total energy is
| (13.39) |
In this equation, is the interaction of the electronic and protonic densities with the external potential created by the classical nuclei, and contains the electron–electron, proton–proton, and electron-proton classical Coulomb energies, as well as the noninteracting kinetic energies of the quantum particles. The terms , , and are the electron-electron exchange-correlation functional, the proton-proton exchange-correlation functional, and the electron-proton correlation functional, respectively. The quantities
| (13.40a) | ||||
| (13.40b) | ||||
are the electron and proton densities, respectively, and and are the electronic and protonic Kohn-Sham spatial orbitals, respectively. These orbitals are obtained by solving two sets of coupled Kohn-Sham equations for the electrons and quantum protons:
| (13.41a) | ||||
| (13.41b) | ||||
The effective potentials and are obtained by taking the derivative of the total energy expression in Eq. (13.39) with respect to electron density and proton density, respectively. Analogous to NEO-HF, these electronic and protonic Kohn-Sham orbitals are expanded as linear combinations of electronic or protonic Gaussian basis functions ( and ). The extension to open-shell electron systems is analogous to the NEO-UHF method.
The practical implementation of the NEO-DFT method requires an electron-electron exchange-correlation functional, a proton-proton exchange-correlation functional, and an electron-proton correlation functional. Any conventional electron-electron exchange-correlation functional can be used within the NEO-DFT framework.
150
J. Chem. Phys.
(2018),
149,
pp. 044110.
Because the proton-proton exchange and correlation are negligible in molecular systems, only the exchange at the NEO-Hartree-Fock level is included to eliminate self-interaction error in the NEO-DFT method. A suitable electron-proton correlation functional is essential for obtaining accurate proton densities and energies, and the epc17-2
1412
J. Chem. Phys.
(2017),
147,
pp. 114113.
151
J. Phys. Chem. Lett.
(2017),
8,
pp. 3488.
and epc19
1258
J. Chem. Phys.
(2019),
151,
pp. 124102.
functionals are designed to achieve this goal. These two functionals are based on the multicomponent extension of the Colle-Salvetti formalism. The epc17-2 functional is of the local density approximation (LDA) type with the functional form:
| (13.42) |
The epc19 functional is its multicomponent generalized gradient approximation (GGA) extension that depends on the electron and proton density gradients and is of the form:
| (13.43) |
In addition to the parameters , , and in the epc17-2 functional,
151
(2017),
8,
pp. 3488.
the epc19 functional
1258
J. Chem. Phys.
(2019),
151,
pp. 124102.
has the and parameters and also depends on the proton mass .
Analogous to the NEO-HF analytical energy gradients, the NEO-DFT analytical gradients
1257
J. Chem. Theory Comput.
(2021),
17,
pp. 5110.
are available for these two functionals,
allowing geometry optimizations on the ground state vibronic potential energy surface. The NEO-DFT analytical Hessians
1257
(2021),
17,
pp. 5110.
are available for the epc17-2 functional or when no electron-proton correlation functional is used and allow characterization of the stationary points.
The NEO multistate DFT (NEO-MSDFT) method was developed to describe hydrogen transfer and hydrogen tunneling systems within the NEO
framework.
1424
(2020),
11,
pp. 10106.
307
(2023),
14,
pp. 6170.
Analogous to the conventional electronic MSDFT method,
894
Phys. Chem. Chem. Phys.
(2011),
13,
pp. 6760.
396
(2016),
7,
pp. 5143.
461
(2017),
13,
pp. 1176.
815
(2022),
13,
pp. 7762.
the NEO-MSDFT method linearly combines localized NEO-DFT states in a nonorthogonal configuration interaction (NOCI) scheme.
1177
J. Chem. Phys.
(2005),
123,
pp. 134108.
This approach captures the delocalized, bilobal proton densities needed to describe hydrogen tunneling and avoids complications of local minima in orbital space.
Consider a system with transferring protons, where each proton moves in a double-well potential in the Born-Oppenheimer picture. In NEO-DFT calculations, the protonic density tends to localize in one well of a symmetric or nearly symmetric double-well potential instead of delocalizing over both wells. Quantizing each transferring proton with the NEO approach leads to diabatic NEO-DFT states. Each diabatic state has the protonic density of each transferring proton localized in one of the two wells of its corresponding double-well potential. In practice, higher-energy diabatic states can be excluded from the NOCI expansion. The set of all diabatic NEO-DFT states is , where . Each diabatic state is the product of a Kohn-Sham electronic and protonic determinant, as discussed in Section 13.5.2.2.
The adiabatic NEO-MSDFT states are linear combinations of all diabatic NEO-DFT states:
| (13.44) | ||||
The coefficients in Eq. (13.44) are determined by solving the matrix eigenvalue problem
| (13.45) |
The overlap matrix and effective Hamiltonian matrix contain the overlap and couplings, respectively, between pairs of
localized diabatic states. Note that the diagonal elements of are unity, and the diagonal elements of are the NEO-DFT
energies of the diabatic states. For the sake of brevity, the analytical forms of the off-diagonal terms of these matrices are excluded here but are
given in previous work.
307
(2023),
14,
pp. 6170.
The limitations of the epc functionals and the resulting inaccuracies of the overlap between two localized NEO-DFT states, as well as the approximate form of the off-diagonal Hamiltonian matrix elements, can be accounted for by applying a simple correction function to the off-diagonal elements of the matrix:
| (13.46) |
Users can control the values of and used in NEO-MSDFT calculations, and their default values were determined though a fitting process discussed in our previous work.
1424
(2020),
11,
pp. 10106.
Setting both these parameters to unity produces the original overlap matrix. However, in general the alpha and beta parameters should be kept at their default values unless another parameterization procedure is performed to determine alternative values.
A NEO-MSDFT calculation can be enabled by setting the $rem variable NEO_MSDFT = 1. Analytical gradients have also been
implemented,
1426
J. Chem. Phys.
(2022),
156,
pp. 114115.
allowing users to optimize geometries on specified NEO-MSDFT surfaces by setting JOBTYPE =
OPT. By default, analytical derivative couplings between NEO-MSDFT states are computed directly following an analytical gradient
calculation,
1425
(2022),
18,
pp. 7132.
but this calculation can be disabled. Note that the only gradients and derivative couplings printed out are those pertaining to the ground and
first-excited NEO-MSDFT states, as these are the only states of physical relevance (as explained elsewhere
307
(2023),
14,
pp. 6170.
Users can also request a semi-numerical Hessian calculation by setting IDERIV = 2. Further control of a NEO-MSDFT calculation is given by the $neo_msdft section,
whose job-control options are given below:
OPT_STATE
Controls which NEO-MSDFT state is geometry-optimized when JOBTYPE = OPT
or which NEO-MSDFT surface the semi-numerical Hessian will be calculated on when IDERIV = 2.
INPUT SECTION: $neo_msdft
Ground-State
Indicates optimization/semi-numerical Hessian calculation will occur on the th NEO-MSDFT surface.
Ensure that is strictly less than the number of diabatic states included in the adiabatic state expansion of Eq. (13.44).
ALPHA
Sets the parameter used for the overlap correction of Eq. (13.46).
FLOAT
0.0604
User-defined.
Keep default value unless another parameterization procedure is performed.
BETA
FLOAT
0.492
User-defined.
NACV
Controls if analytical derivative couplings are calculated following an analytical gradient calculation.
Enables derivative coupling calculation.
Disables derivative coupling calculation.
DENPLT
Controls the generation of proton density cube files for NEO-MSDFT states.
-1
Disables generation of proton density cube files.
Enables generation of proton density cube files for NEO-MSDFT states .
Users can also generate electron density cube files for each of the specified NEO-MSDFT states via the $plots section
(refer to Section 10.5.4.1 for details). Also note that if , a directory neo_msdft_denplt
will be created in the current working directory where all the generated cube files will be written.
CPSCF_THRESH
Controls the convergence criteria for the NEO-CPSCF routine. Solving the NEO-CPSCF equations is required for calculating
the analytical gradients of the NEO-MSDFT energies.
1426
J. Chem. Phys.
(2022),
156,
pp. 114115.
The NEO-CPSCF routine is considered converged when the error is less than .
8
User-defined.
Tightening the NEO-CPSCF convergence will improve the reliability of the analytical gradients.
CPSCF_NSTEPS
Controls the maximum number of NEO-CPSCF iterations permitted. Solving the NEO-CPSCF equations is required for calculating the
1426
J. Chem. Phys.
(2022),
156,
pp. 114115.
The NEO-CPSCF routine will fail if it does not converge within a CPSCF_NSTEPS number of steps.
300
User-defined.
If CPSCF_THRESH is higher than the default, increasing the number of iterations permitted in the NEO-CPSCF routine may be needed.
FDIFF_STEP
Sets the distance each center is perturbed if a semi-numerical Hessian calculation is requested.
FLOAT
Å
User-defined.
If INPUT_BOHR = FALSE, then the step size input by the user will be measured in Å. If INPUT_BOHR =
TRUE, then the step size input by the user will be measured in bohr.
As discussed in previous work,
1424
(2020),
11,
pp. 10106.
307
(2023),
14,
pp. 6170.
each quantum transferring proton in NEO-MSDFT is given two basis function centers:
one center localized near the donor and another center localized near the acceptor. When requesting a NEO-MSDFT calculation, in the $molecule
section, each quantum transferring proton must have one center input as a standard H atom center and its other center input as a ghost H atom center.
These centers must be listed consecutively in the $molecule section. Additionally, it is assumed that all ghost H atom centers in the $molecule section
of a NEO-MSDFT calculation belong to a quantum transferring proton.
By default, all possible NEO-DFT diabatic states are included in the adiabatic state expansion of Eq. (13.44). If this is not desired, users can provide an input to the $neo_msdft_diabat_control section to specify which diabatic states to include. This input section takes in an array of Boolean values (input as ones or zeros), where each row is a unique string corresponding to a particular diabatic state. These Booleans refer to whether or not a quantum transferring proton is localized on each proton basis function center in the order in which they appear in the $molecule section. Thus, if the number of diabatic states the user wants to include is and the number of quantum transferring protons is , the $neo_msdft_diabat_control section should contain an array with rows and columns, where the -th row specifies which proton basis function centers have a localized quantum proton in the -th diabatic state. Note that other protons can be quantized with NEO that do not correspond to a transferring proton and therefore are represented by a single proton basis function center; these protons should not be included in the $neo_msdft_diabat_control section. Examples showing how to set up NEO-MSDFT calculations/input files with both one and multiple transferring protons can be found in Section 13.5.4.
The overlap correction of Eq. (13.46) is parameterized to produce accurate proton densities and tunneling splittings when the proton basis function centers are optimized for separate NEO-DFT diabatic states (see the procedures explained in our previous
work).
1424
(2020),
11,
pp. 10106.
307
(2023),
14,
pp. 6170.
However, users may wish to perform geometry optimizations on NEO-MSDFT surfaces instead.
One can either optimize the positions of just the proton basis function centers for fixed geometries of classical nuclei or optimize the positions of both
the classical nuclei and proton basis function centers simultaneously. Both cases require the user to set JOBTYPE = OPT,
but in the former case, the $opt section must be used to freeze the classical nuclei during the optimization (see Section 9.4.3
for details). In either case, the input of the $molecule section serves as an initial guess for the optimization, so users must make an informed guess as
to where to initially place each of the two proton basis function centers for each quantum transferring proton.
Bulk solvent effects can be directly incorporated into NEO calculations
through the application of various implicit solvation models (Section 11.2) within the NEO framework.
1367
(2022),
18,
pp. 1340.
The polarizable continuum model (PCM) constitutes one family of implicit solvation models and itself encompasses
several different formulations:
716
Chem. Phys. Lett.
(2011),
509,
pp. 77.
529
Wiley Interdiscip. Rev.: Comput. Mol. Sci.
(2021),
11,
pp. e1519.
C-PCM,
1282
Chem. Phys. Lett.
(1995),
240,
pp. 253.
72
J. Phys. Chem. A
(1998),
102,
pp. 1995.
IEF-PCM,
228
J. Chem. Phys.
(2000),
112,
pp. 5558.
171
J. Chem. Phys.
(2001),
114,
pp. 4744.
SS(V)PE,
228
J. Chem. Phys.
(2000),
112,
pp. 5558.
etc.
529
(2021),
11,
pp. e1519.
In the PCM approach, the solute molecule is placed in a cavity that is embedded in dielectric continuum solvent, and the cavity surface
is discretized into tesserae grid points. The solvent response is represented by a partial charge centered at
each tesserae grid point .
1270
Chem. Rev.
(2005),
106,
pp. 2999.
529
(2021),
11,
pp. e1519.
For each SCF iteration, the current electronic and protonic densities, together with the fixed classical nuclei, define the solute’s charge distribution. This charge distribution gives rise to the solute’s electrostatic potential at each tesserae grid point:
| (13.47) |
The solute electrostatic potential is then used to compute using standard PCM methods. Once obtained, the set of tesserae charges is included as an additional one-electron (one-proton) contribution to the electronic (protonic) Fock or analogous Kohn-Sham matrix:
| (13.48a) | ||||
| (13.48b) | ||||
where and refer to the gas-phase, electronic [Eq. (13.37a)] and protonic [Eq. (13.37b)] Fock or analogous Kohn-Sham matrix elements, respectively.
NEO-PCM calculations involve iterative, self-consistent convergence of the nuclear-electronic wavefunction in the presence of the dielectric continuum solvent. Both NEO-HF and NEO-DFT PCM energies and analytic gradients are implemented. The calculation can be invoked by setting SOLVENT_METHOD = PCM in the $rem input section, alongside variables for NEO-SCF as described in Section 13.5.3.
In the simplest approach, the cavity surface is discretized into point charges. However, a more sophisticated approach utilizing Gaussian-smeared
charges is also supported.
713
(2010),
1,
pp. 556.
714
J. Chem. Phys.
(2010),
133,
pp. 244111.
711
Mol. Phys.
(2020),
118,
pp. e1644384.
529
(2021),
11,
pp. e1519.
Selection of these various PCM schemes and related variables can be set in the $pcm and/or $solvent input sections.
An example on how to set up a solvated NEO calculation can be found in Section 13.5.4.
In NEO-SCF calculations, the nuclear solution corresponds to the variational nuclear wavefunction (density) for the specific method and basis sets.
The nuclear orbitals in molecular systems
are localized, and therefore the quantized nuclei can be treated as distinguishable when analyzing their position expectation values.
These expectation values are generally not equal to the input coordinates of the NEO nuclear basis function centers.
Control over the position expectation values of the nuclei can be achieved with the constrained (C)NEO approach,
1402
J. Chem. Phys.
(2020),
152,
pp. 084107.
based on the original NEO method
1335
J. Chem. Phys.
(2002),
117,
pp. 4106.
and in analogy to the conventional constrained DFT (Section 5.11).
This is accomplished by imposing the following constraint:
| (13.49) |
where is the chosen value for the position expectation value for nucleus . For geometry optimizations and vibrational frequency calculations, typically is the position of the NEO nuclear basis function center, as defined by the input coordinates. The constraint is imposed by using Lagrange multipliers. In this case, the protonic part of the coupled Kohn-Sham equations of NEO-DFT (Eq. (13.41b)) becomes:
| (13.50) |
where is the Lagrange multiplier. In practice, the value of is optimized numerically to satisfy the constraint in Eq. (13.49).
CNEO calculations can be invoked by setting CNEO = TRUE, and NEO = TRUE must also be set.
Analytical CNEO gradients
1403
J. Chem. Phys.
(2020),
153,
pp. 074106.
and Hessians
1404
J. Chem. Phys.
(2021),
154,
pp. 244110.
are available, allowing geometry optimizations with
JOBTYPE = OPT and vibrational frequency calculations with JOBTYPE = FREQ.
CNEO can be used with Hartree-Fock or with DFT in conjunction with the epc17-2 or epc19 electron-proton correlation functional and the
electron exchange-correlation functionals available in Q-Chem. CNEO is currently implemented with only one quantum nucleus.
The LR-NEO-TDDFT method
1413
(2018),
9,
pp. 1765.
is a multicomponent extension of the linear response TDDFT method within the NEO framework.
It allows the simultaneous calculation of the electronic and proton vibrational excitation energies. In the (LR)-NEO-TDDFT method,
the linear response of the NEO Kohn-Sham system to perturbative external fields is computed. The NEO-TDDFT working equation is
| (13.51) |
where
| (13.52) | ||||
| (13.53) | ||||
| (13.54) | ||||
| (13.55) | ||||
| (13.56) |
Here, the occupied electronic orbitals are denoted with indices and , whereas the unoccupied electronic orbitals are denoted with indices and . The analogous upper case indices denote protonic orbitals. The solution of Eq. (13.51) provides the electronic and proton vibrational excitation energies , as well as the transition excitation and de-excitation amplitudes, and , respectively. Analogous to the TDDFT method, the Tamm-Dancoff approximation (TDA) can be imposed within the NEO framework, defining the NEO-TDDFT-TDA method that is represented by
| (13.57) |
The extension of the NEO-TDDFT and NEO-TDDFT-TDA approaches to open-shell electron systems is straightforward.
271
J. Chem. Phys.
(2019),
150,
pp. 201101.
NEO-TDHF and NEO-CIS have similar forms as NEO-TDDFT and NEO-TDA without electron-proton, electron-electron, or proton-proton correlation.
The analytical gradients for NEO-CIS/NEO-TDA/NEO-TDHF/NEO-TDDFT are available,
1257
(2021),
17,
pp. 5110.
enabling geometry optimizations on the excited state vibronic potential energy surfaces. For NEO-TDA and NEO-TDDFT,
analytical gradients are available for the epc17-2 functional or when no electron-proton correlation functional is used.
The transition densities can be analyzed to determine the percentages of electronic and protonic character for each vibronic excited state.
Real-time NEO time-dependent density functional theory (RT-NEO-TDDFT, or RT-NEO for brevity)
is a multicomponent extension of conventional electronic RT-TDDFT
1440
(2020),
11,
pp. 4052.
and is an approach that enables the modeling of
nonequilibrium, non-Born-Oppenheimer nuclear-electronic quantum dynamics. This approach assumes the form of the single Slater determinant
product ansatz of the NEO-DFT reference system,
where and are collective spatial and spin coordinates of the quantum electrons and protons,
(or ) is the single particle density matrix and (or )
is the Kohn-Sham matrix for the electrons (or protons), and is the time. The time-dependent Schrödinger equation
| (13.58) |
can be propagated according to the set of multicomponent von Neumann equations:
| (13.59a) | |||
| (13.59b) | |||
Note that these equations are not propagated independently, but are actually coupled through Fock terms that depend on both particle densities. The electron and proton densities are evolved together in time. The resulting electronic and protonic dipole moments can be obtained at every time step and analyzed via post-processing to provide relevant spectral features. Fourier transformation of these signals from the corresponding time-domain to the frequency-domain can yield both electronic and vibrational spectra that have been shown to agree well with LR-NEO-TDDFT. In addition, this approach provides the nonequilbrium, real-time dynamics of the electronic and protonic densities.
Up to this point, the equations of motion presented above
[Eq. (13.59a) and Eq. (13.59b) assume that the classical nuclei
are held at a fixed geometry throughout the entire simulation.
To combine the real-time dynamics of the electrons and protons together with the mean-field motion of the
classical nuclei, the RT-NEO-TDDFT-Ehrenfest approach has been formulated.
1441
J. Chem. Phys.
(2020),
153,
pp. 224111.
In this approach, the classical nuclei are evolved according to Newtonian dynamics,
while the nonequilibrium electrons and protons are still being propagated according to Eq. (13.59a) and
Eq. (13.59b), respectively:
| (13.60) |
Here we denote and to be the mass and the position, respectively, of the th classical nucleus, and is the abbreviated form of the total nuclear gradient expression. We support both of these approaches, i.e., RT-NEO with fixed classical nuclei and RT-NEO with moving classical nuclei, and we have designated those methods as METHOD = REALTIME and METHOD = EHRENFEST, respectively.
In addition to electrons, it is important that the proton dynamics is adequately described throughout the course of a given trajectory.
This is especially important in cases where proton delocalization may start to occur, such as during a proton transfer reaction or when the
geometry of the classical nuclei is no longer held fixed.
To provide the flexibility for describing proton delocalization, one may use a larger protonic basis set and/or utilize multiple fixed proton basis (FPB) function centers placed at pre-designated positions.
Alternatively, a traveling proton basis (TPB) approach has been formulated and will be made available in a future release.
1441
J. Chem. Phys.
(2020),
153,
pp. 224111.
Examples of using either one or multiple FPB function centers can be found in the
examples section of this manual.
In certain applications, the requirement of using a small time step due to the fast electronic dynamics can prohibit long simulation times. For systems that are electronically adiabatic, the electronic Born-Oppenheimer (BO) approximation can be invoked by quenching the electrons to an instantaneous electronic ground state via the standard self-consistent-field (SCF) procedure instead of propagating Eq. (13.59a) at every time step:
| (13.61) |
This approach enables the use of a time step that is several orders of magnitude larger than that required for integrating Eq. (13.59a), therefore rendering longer simulation times more tractable. The electronic BO approximation can be invoked for RT-NEO with fixed classical nuclei or for RT-NEO with moving classical nuclei by toggling the methods METHOD = BO-REALTIME or METHOD = BO-EHRENFEST, respectively.
A RT-NEO calculation can be invoked by setting NEO_TDKS = TRUE in the $rem section, and additional job control is provided in its own input section. The input file for a RT-NEO propagation is illustrated in several examples in Section 13.5.4, however, the available controls are also discussed below. Note that the keywords and field types defined for $tdks (Section 7.4) are not the same parameters as those defined for the $neo_tdks, and vice versa. Only parameters/keywords documented below are supported. The parameters of the jobs are set using options specified in the $neo_tdks input section. The format of the $neo_tdks section is analogous to the $rem section:
$neo_tdks <Keyword> <parameter/option> $end
Note: The following job control variables belong only in the $neo_tdks section. Do not place them in the $rem section.
METHOD
Specifies which RT-NEO dynamics approach will be used to propagate the system.
INPUT SECTION: $neo_tdks
Realtime
Fixed classical nuclei
1440
(2020),
11,
pp. 4052.
Ehrenfest
Moving classical nuclei
1441
J. Chem. Phys.
(2020),
153,
pp. 224111.
BO-Realtime
Fixed classical nuclei with electronic BO approximation
770
J. Chem. Phys.
(2023),
158,
pp. 114118.
BO-Ehrenfest
Moving classical nuclei with electronic BO approximation
770
J. Chem. Phys.
(2023),
158,
pp. 114118.
DT
Specifies the time step , in atomic units.
DOUBLE
0.04
User-selected.
MAXITER
Specifies the maximum number of time steps to simulate.
User-selected.
The total propagation length is .
ELECTRONIC_HOMO_TO_LUMO
Performs a HOMO LUMO excitation for a single electron prior to time propagation.
An unrestricted calculation is performed when this keyword is invoked.
Should not use in conjunction with the electronically adiabatic approximation.
To perturb the system, a time-dependent electric field pulse can be applied via a dipole coupling term added to the electronic and/or protonic Fock matrices,
| (13.62a) | ||||
| (13.62b) | ||||
where (or ) is the unperturbed Kohn-Sham matrix and (or ) is the dipole moment matrix for the electrons (or protons). Note that the dipole moment (i.e., and ) have the opposite sign for electrons and protons. Tunable parameters for FIELD_TYPE are provided in the additional keywords found below. For the supported field types below, note that the electric field vector is a quantity whose magnitude is controlled by FIELD_AMP and whose direction is controlled by FIELD_DIRECTION.
Delta simulates a Dirac -function kick with a field that is turned on only at time :
| (13.63) |
The amplitude of and its direction are set using FIELD_AMP and FIELD_DIRECTION, respectively.
Gaussian simulates the following impulse field that is turned on at all times :
| (13.64) |
The center of the pulse is set using the FIELD_PEAK keyword.
The pulse half-width is set using the FIELD_TAU keyword.
The pulse frequency is set using the FIELD_FREQUENCY keyword.
FIELD_TYPE
The external applied field
INPUT SECTION: $tdks
DELTA
-function kick
GAUSSIAN
Impulse field (Gaussian envelope)
No field
No recommendation.
FIELD_AMP
The amplitude of the external field, in atomic units.
DOUBLE
0.01
No recommendation.
FIELD_PEAK
The peak position (in atomic units of time) for the Gaussian impulse field.
DOUBLE
0.0
No recommendation.
FIELD_TAU
The value of (in atomic units of time) for the Gaussian impulse field.
DOUBLE
800.0
No recommendation.
FIELD_FREQUENCY
The frequency of the external field, in eV units.
DOUBLE
6.0
No recommendation.
FIELD_DIRECTION
The direction of the external applied field vector.
XYZ
Pulse along the direction {1, 1, 1}
Pulse along the direction {1, 0, 0}
Y
Pulse along the direction {0, 1, 0}
Z
Pulse along the direction {0, 0, 1}
No recommendation.
FIELD_PARTICLE
The subsystem on which to apply the external field perturbation.
BOTH
Electrons and quantized protons
ELECTRONS
PROTONS
No recommendation.
Within the NEO framework, select nuclei are treated quantum mechanically at the same level as the electrons. This removes the Born-Oppenheimer separation
between the quantum nuclei and the electrons and naturally includes nonadiabatic effects between the quantum nuclei and the electrons.
At the same time, quantizing the select nuclei gives rise to a potential energy surface with fewer nuclear degrees of freedom, which prevents a direct
calculation of the vibrational frequencies of the entire molecule. Consequently, diagonalization of a coordinate Hessian in the NEO framework yields
vibrational frequencies and accompanying normal modes of only the classical nuclei, with the quantum nuclei responding instantaneously to the motion
of the classical nuclei.
1134
J. Chem. Phys.
(2021),
154,
pp. 054108.
Although the fundamental anharmonic vibrational frequencies of the quantum nuclei can be accurately
obtained through LR-NEO-TDDFT,
271
J. Chem. Phys.
(2019),
150,
pp. 201101.
the couplings between the vibrations of the classical and quantum nuclei are missing.
To obtain the fully coupled molecular vibrations, an effective strategy denoted NEO-DFT(V) was developed.
1414
(2019),
10,
pp. 1167.
272
(2019),
15,
pp. 6840.
The NEO-DFT(V) method has been shown to incorporate key anharmonic effects in full molecular vibrational analyses and to produce accurate
molecular vibrational frequencies compared to experiments.
1414
(2019),
10,
pp. 1167.
272
(2019),
15,
pp. 6840.
The NEO-DFT(V) method involves diagonalization of an extended NEO Hessian composed of partial second derivatives of the coordinates of the classical nuclei () and the expectation values of the quantum nuclei (). This extended Hessian matrix is composed of three sub-matrices: , , and , where in each case, all other coordinates of the classical nuclei and expectation values of the quantum nuclei are fixed. The extended Hessian has the following structure:
| (13.65) |
where
| (13.66a) | ||||
| (13.66b) | ||||
| (13.66c) | ||||
The quantity and the NEO Hessian matrix is
(without the constraint that the expectation values of the quantum nuclei are fixed).
In the expression for the matrix, is the diagonal mass matrix, and is the diagonal matrix with elements corresponding to the squares of the LR-NEO-TDDFT fundamental vibrational frequencies.
1414
(2019),
10,
pp. 1167.
is a unitary matrix that transforms to the target coordinate system and is approximated with the transition dipole moment vectors afforded by a LR-NEO-TDDFT calculation.
272
(2019),
15,
pp. 6840.
Diagonalization of produces the fully coupled molecular vibrational frequencies including anharmonic effects associated with the quantum protons. The NEO-DFT(V) method is available for use with the epc17-2 functional or when no electron-proton correlation functional is used. The NEO-HF(V) method, which involves building the extended NEO-Hessian based on the NEO-HF Hessian and inputs from NEO-TDHF, is also available.
An alternative route for inclusion of correlation effects between quantum particles (i.e., electrons and protons) is with wave functions methods that
are systematically improvable and parameter-free.
1335
J. Chem. Phys.
(2002),
117,
pp. 4106.
978
Chem. Rev.
(2020),
120,
pp. 4222.
Among the various developed multicomponent wave function methods, the NEO coupled cluster (NEO-CC) methods have been particularly
successful.
977
(2018),
15,
pp. 338.
979
J. Chem. Phys.
(2019),
151,
pp. 074104.
980
(2020),
11,
pp. 1578.
981
(2021),
12,
pp. 1631.
The NEO-CC wave function is given by
| (13.67) |
where is the cluster operator that incorporates the correlation effects between quantum particles, and is the NEO-HF reference wave function. In the NEO-CCSD method,
977
(2018),
15,
pp. 338.
the cluster operator is given by
| (13.68) |
where are the excitation operators expressed in terms of
creation/annihilation () fermionic operators, and is the excitation rank. Here, the indices denote occupied
electronic orbitals, the indices denote unoccupied electronic orbitals, and the indices denote general electronic orbitals.
The protonic orbitals are denoted analogously using the capitalized indices. The unknown wave function parameters (amplitudes) are
determined by solving the set of nonlinear equations for each :
977
(2018),
15,
pp. 338.
| (13.69) |
In this equation, is the second-quantized NEO Hamiltonian, where and are conventional electronic core Hamiltonian and two-electron integrals, respectively. The remaining protonic ( and ) and electron-proton () integrals are defined analogously. Lastly, the NEO-CCSD energy is calculated from
| (13.70) |
To increase the computational efficiency and reduce the memory requirements for the NEO-CCSD method, the two-particle integrals can be approximated with the density fitting (DF) approximation,
981
(2021),
12,
pp. 1631.
in which the two-particle four-center integrals are factorized into a sum of products of three-center and two-center two-particle integrals.
In particular, the four-center two-electron integrals are approximated by
| (13.71) |
where and are three-center and two-center two-electron integrals, respectively. In this equation, and indices denote electronic and auxiliary electronic basis functions, respectively. The four-center two-proton integrals are approximated analogously by
| (13.72) |
where primed indices denote protonic basis functions and and are three-center and two-center two-proton integrals, respectively. Finally, the four-center electron-proton integrals are approximated as
| (13.73) |
By employing the DF approximation, the memory requirements for storing four-center two-particle
integrals are reduced from to , where and are the number of electronic or protonic basis functions and auxiliary basis functions, respectively.
981
(2021),
12,
pp. 1631.
Second-order Møller-Plesset perturbation theory provides a useful framework for wave function based correlation effects with lower cost than NEO-CC
1244
Chem. Phys. Lett.
(2005),
404,
pp. 394.
. The NEO-MP2 correlation energy is composed of the electron-electron, proton-proton and electron-proton contributions:
| (13.74) |
where
| (13.75a) | ||||
| (13.75b) | ||||
| (13.75c) | ||||
Here, and are occupied electronic spin orbitals with energies and , and are virtual (unoccupied) electronic spin orbitals with energies and , and uppercase indices indicate the analogous protonic spin orbitals and energies.
To provide accuracy that is competitive with NEO-CCSD, NEO-MP2 has been extended to include orbital optimization and empirical spin-component and electron-proton correlation scaling.
980
(2020),
11,
pp. 1578.
981
(2021),
12,
pp. 1631.
This leads to the NEO equivalents of SOS-OOMP2 (O2)
805
J. Chem. Phys.
(2007),
126,
pp. 164101.
and SOS-MP2
455
J. Chem. Phys.
(2003),
118,
pp. 9095.
619
J. Chem. Phys.
(2004),
121,
pp. 9793.
(Sections 6.6.5 and 6.6.6). The NEO equivalents are referred to as NEO-SOS-OOMP2 and NEO-SOS-MP2 to indicate the inclusion of an electron-proton correlation scaling factor:
| (13.76) |
where and are the same- and opposite-spin parts of the electron-electron correlation energy, which are scaled by and , respectively, and is the electron-proton scaling factor.
Orbital optimization is performed by minimizing the NEO-MP2 energy with respect to the unitary operator formed from the rotation operator , with being the set of unknown electronic and protonic orbital rotation parameters. Optimal orbital rotation parameters are solved for by finding the stationary points of electronic and protonic orbital gradients and , which have elements
| (13.77a) | |||
| and | |||
| (13.77b) | |||
and are solved in an alternating fashion until self-consistency is achieved. For computational efficiency, all NEO-MP2 methods are implemented with the density fitting approximation for two-particle integrals,
359
(2022),
13,
pp. 5563.
as described in more detail in Section 13.5.2.9.
NEO-MP2 methods are invoked with NEO_RIMP2 = 1 to run without orbital optimization and NEO_RIMP2 = 2 to run with orbital optimization. NEO = TRUE must also be set. Spin-component scaling settings are controlled with the SCS variable. Custom and can be set with SSS_FACTOR and SOS_FACTOR, respectively, when SCS = 3 is set (arbitrary scaling). By default, is set to the same value as , but a custom electron-proton scaling factor can be input with the EP_FACTOR variable, which will always override the default set by SCS.
