While atomic orbital standard basis sets are used to expand one-electron functions such as molecular orbitals, auxiliary basis sets are also used in many Q-Chem jobs to efficiently approximate products of one-electron functions, such as arise in electron correlation methods.
For a molecule of fixed size, increasing the number of basis functions
per atom, , leads to growth in the number of significant
four-center two-electron integrals, since the number of non-negligible
product charge distributions, , grows as . As a result,
the use of large (high-quality) basis expansions is computationally costly.
Perhaps the most practical way around this “basis set quality” bottleneck is
the use of auxiliary basis expansions.
360
Chem. Phys. Lett.
(1993),
208,
pp. 359.
331
Phys. Chem. Chem. Phys.
(2000),
2,
pp. 2113.
620
Proc. Natl. Acad. Sci. USA
(2005),
102,
pp. 6692.
The ability to use auxiliary
basis sets to accelerate a variety of electron correlation methods, including
both energies and analytical gradients, is a major feature of Q-Chem.
The auxiliary basis is used to approximate products of Gaussian basis functions:
| (8.2) |
Auxiliary basis expansions were introduced long ago, and are now widely recognized as an effective and powerful approach, which is sometimes synonymously called resolution of the identity (RI) or density fitting (DF). When using auxiliary basis expansions, the rate of growth of computational cost of large-scale electronic structure calculations with is reduced to approximately .
If is fixed and molecule size increases, auxiliary basis expansions reduce the pre-factor associated with the computation, while not altering the scaling. The important point is that the pre-factor can be reduced by 5 or 10 times or more. Such large speedups are possible because the number of auxiliary functions required to obtain reasonable accuracy, , has been shown to be only about 3 or 4 times larger than .
The auxiliary basis expansion coefficients, , are determined by minimizing the deviation between the fitted distribution and the actual distribution, , which leads to the following set of linear equations:
| (8.3) |
| (8.4) |
In the limit where the auxiliary basis is complete (i.e. all products of AOs are included), the fitting procedure described above will be exact. However, the auxiliary basis is invariably incomplete (as mentioned above, because this is essential for obtaining increased computational efficiency.
More details on Q-Chem’s use of RI methods is given in Section 6.6 on RI-MP2 and related methods, Section 6.18 on pairing methods, Section 6.11.8 on coupled cluster methods, Section 4.6.6 on DFT methods, and Section 7.12 on restricted active space methods. In the remainder of this section we focus on documenting the input associated with the auxiliary basis itself.
Q-Chem contains a variety of built-in auxiliary basis sets, that can be specified by the $rem keyword AUX_BASIS. These auxiliary basis sets are listed in Table 8.9 and specified in the $rem input section by means of the job control variables that are listed below. Note that in addition to the built-in auxiliary basis sets (Table 8.9), it is also possible to enter user-defined auxiliary basis sets using an $aux_basis (or $aux_basis_j, $aux_basis_k, $aux_basis_corr) input section, whose syntax generally follows the $basis input section documented above in Section 8.4.
AUX_BASIS
AUX_BASIS
Sets the auxiliary basis set to be used
No default auxiliary basis set
General, Gen
User-defined. As for BASIS
Symbol
Use standard auxiliary basis sets as in the table below
Mixed
Use a combination of different basis sets
Consult literature and Basis Set Exchange to aid your selection.
AUX_BASIS_J
AUX_BASIS_J
Sets the auxiliary basis set for RI-J to be used or invokes RI-J
General, Gen
Symbol
Mixed
AUX_BASIS_K
AUX_BASIS_K
Sets the auxiliary basis set for RI-K or occ-RI-K to be used or invokes occ-RI-K
General, Gen
Symbol
Mixed
AUX_BASIS_CORR
AUX_BASIS_CORR
Sets the auxiliary basis set for RI-MP2 to be used or invokes RI-MP2 in case of double-hybrid DFT or MP2
General, Gen
Symbol
Mixed
| Symbolic Name | Atoms Supported |
| RIJ-def2-XX | H, He, Li Ne, Na Ar, K Br, Rb Xe, Cs La, Hf Rn |
| RIJK-def2-XX | H, He, Li Ne, Na Ar, K Br, Rb Xe, Cs La, Hf Rn |
| RIMP2-def2-XX | H, He, Li Ne, Na Ar, K Br, Rb Xe, Cs La, Hf Rn |
| RIMP2-def2-ma-XX | H, He, Li Ne, Na Ar, K Br, Rb Xe, Cs La, Hf Rn |
| RIMP2-def2-ha-XX | H, He, Li Ne, Na Ar, K Br, Rb Xe, Cs La, Hf Rn |
| RIMP2-VDZ | H, He, Li F, Na Cl, K Br |
| RIMP2-TZVPP | H, He, Li Ne, Na Ar, Ga Kr |
| RIMP2-cc-pVDZ | H, He, Li Ne, Na Ar, Ga Kr |
| RIMP2-cc-pVTZ | H, He, Li Ne, Na Ar, Ga Kr |
| RIMP2-cc-pVQZ | H, He, Li Ne, Na Ar, Ga Kr |
| RIMP2-cal-cc-pVDZ | H, He, B Ne, Al Ar, Ga Kr |
| RIMP2-cal-cc-pVTZ | H, He, B Ne, Al Ar, Ga Kr |
| RIMP2-cal-cc-pVQZ | H, He, B Ne, Al Ar, Ga Kr |
| RIMP2-aug-cc-pVDZ | H, He, B Ne, Al Ar, Ga Kr |
| RIMP2-aug-cc-pVTZ | H, He, B Ne, Al Ar, Ga Kr |
| RIMP2-aug-cc-pVQZ | H, He, B Ne, Al Ar, Ga Kr |
XX includes SV(P), SVP, TZVP, TZVPP, QZVP, and QZVPP.
XX includes SV(P), SVP, SVPD, TZVP, TZVPD, TZVPP, TZVPPD, QZVP, and QZVPPD.
XX includes SVP, TZVP, TZVPP, and QZVPP, obtained by systematic pruning of diffuse functions.
For example, RIMP2-def2-ma-SVP is obtained from RIMP2-def2-SVPD by pruning in the same manner
that def2-ma-SVP is obtained from def2-SVPD.
This is the original SVP fitting set from Ref.
1337
Chem. Phys. Lett.
(1998),
294,
pp. 143.
Where cal = may, jun, or jul. These are constructed from the corresponding RIMP2-aug-cc-pVXZ basis set by systematic
deletion of diffuse functions analogous to how the “calendar” basis set cal-cc-pVXZ is constructed from aug-cc-pVXZ.
