The following semi-empirical methods are available in Q-Chem:
PBEh-3c: It is a DFT based method which is used with def2-mSVP basis
set.This is available for all the elements from H to Rn. For the elements from Rb
() to Rn (), def2-ECP has to be used. It is a more accurate
method than HF-3c as it has correlation,
451
J. Chem. Phys.
(2015),
143,
pp. 054107.
although the double- basis set makes it more expensive for large molecules.
Note: The HF-3c and PBEh-3c methods were parameterized for use with the aforementioned basis sets. Although Q-Chem does not enforce this, other basis sets should not be used unless there is a good reason for doing so, and only then with caution as the results may not match published accuracy.
Example 5.4 Q-Chem input for HF-3c method.
method hf-3c
basis minix
ecp def2-ecp
I 0.6539056222 0.0300979939 0.0000000000
O -2.8593081518 0.0835488510 0.0000000000
H -1.8947008157 0.2596704547 0.0000000000
H -2.8641221666 -0.8778240298 0.0000000000
Example 5.5 Q-Chem input for PBEh-3c method.
$molecule 0 1 O -1.551007 -0.114520 0.000000 H -1.934259 0.762503 0.000000 H -0.599677 0.040712 0.000000 O 1.350625 0.111469 0.000000 H 1.680398 -0.373741 -0.758561 H 1.680398 -0.373741 0.758561 $end $rem METHOD PBEh-3c BASIS def2-mSVP XC_GRID 000099000590 INCDFT 0 INCFOCK 0 SCF_CONVERGENCE 8 THRESH 14 INTEGRAL_SYMMETRY false POINT_GROUP_SYMMETRY false $end
