Due to the form of commonly used basis sets, SCF wave functions
are often not easily interpretable in terms of their atomic orbital (AO) basis functions.
Especially for large basis sets it is not possible to achieve an unambiguous
association of a basis function’s contribution to the wave function with
the atom it is centered on.
An expansion of the molecular orbitals over a minimal basis (of free-atom AOs),
on the other hand, does allow for a simple interpretation of the wave function.
However, free-atom atomic orbitals cannot yield a qualitatively correct
minimal basis expansion
as these AOs do not account for the polarization due to the molecular environment.
The approach by Knizia overcomes this drawback by determining a set of polarized
AOs , termed intrinsic atomic orbitals (IAOs)
660
J. Chem. Theory Comput.
(2013),
9,
pp. 4834.
which exactly express
the occupied space of
the wave function .
As a consequence, atomic properties, such as partial charges, become accessible through IAOs.
The IAO-derived atomic charges of a closed-shell system are then given by
| (10.22) |
where is the nuclear charge of atom and represents the closed-shell SCF density matrix .
The resulting IAOs in conjunction with an orbital localization scheme
can be used to construct bonding orbitals, termed
intrinsic bond orbitals (IBOs). The applied localization scheme is similar to
the Pipek-Mezey approach
1019
J. Chem. Phys.
(1989),
90,
pp. 4916.
and effectively minimizes the number of atoms
on which an orbital is centered by maximizing the functional
| (10.23) |
with respect to unitary orbital rotations. In the above equation, is the number of electrons from rotated orbital located on the IAOs of atom A:
| (10.24) |
Intrinsic bond orbitals exactly represent the occupied molecular orbitals and can thus be used to interpret the electronic molecular structure.
Calculation of intrinsic bond orbitals is controlled by the following $rem variable:
DO_IBO
DO_IBO
Enables IBO procedure
BOOL
Do not calculate IBOs
Run the IBO procedure
Additional control parameters for the IBO procedure can be declared in the $loco input section and are listed below.
MIN_BASIS
Specifies the free atom basis used for the construction of IAOs.
INPUT SECTION: $loco
MINAO
MINAO
Use truncated cc-pVTZ basis (same as in original publication)
STO-3G
Use STO-3G basis
STO-6G
Use STO-6G basis
autoSAD
Construct minimal basis from autoSAD procedure.
Use autoSAD procedure.
EXP_FOUR
Whether to use an exponent of in the localization functional
(Eq. 10.23).
BOOL
Use exponent (same as in original publication)
Use exponent
An exponent of is preferred as it leads to discrete localizations in
aromatic systems ( does not).
IBO_POP_THRESH
Threshold for printing IBO occupations.
FLOAT
0.1
0.1
Prints IBO occupations
Use the default.
IBO_MEM
Memory (in MB) for IBO procedure
500
500MB should suffice for most purposes. Increase only when needed.
EXPORT_MOLDEN
Whether to write IBOs in Molden format.
BOOL
Export IBOs in Molden format (ibo.molden).
Do not create Molden file.
Example 10.4 Input for calculating atomic partial charges and bond populations via the IAO/IBO procedure.
$molecule 0 1 O 0.0000000000 0.0000000000 0.1172309766 H -0.7626482594 0.0000000000 -0.4685977726 H 0.7626482594 0.0000000000 -0.4685977726 $end $rem method = wB97M-V basis = def2-TZVP mem_total = 4000 mem_static = 500 scf_convergence = 9 thresh = 14 gui = 2 do_ibo = true $end $loco min_basis = autosad export_molden = true $end
