For electron transfer (ET) and excitation energy transfer (EET) processes, the
electronic coupling is one of the important parameters that determine their
reaction rates. For ET, Q-Chem provides the coupling values calculated with
the generalized Mulliken-Hush (GMH),
200
Chem. Phys. Lett.
(1996),
249,
pp. 15.
fragment charge difference
(FCD),
1312
J. Chem. Phys.
(2002),
117,
pp. 5607.
Boys localization,
1235
J. Chem. Phys.
(2008),
129,
pp. 244101.
and
Edmiston-Ruedenbeg
1231
J. Chem. Phys.
(2009),
130,
pp. 234102.
localization schemes. For EET, options
include fragment excitation difference (FED),
563
J. Phys. Chem. C
(2008),
112,
pp. 1204.
fragment spin
difference (FSD),
1418
J. Chem. Phys.
(2010),
133,
pp. 074105.
occupied-virtual separated Boys
localization,
1234
J. Phys. Chem. A
(2010),
114,
pp. 8665.
or Edmiston-Ruedenberg
localization.
1231
J. Chem. Phys.
(2009),
130,
pp. 234102.
In all these schemes, a vertical excitation
approach such as CIS or TDDFT is required,
and the GMH, FCD, FED, FSD, Boys or ER coupling values are calculated
based on the excited state results.
More recently, the FED and FCD schemes have been extended to work
with RAS-CI wavefunctions,
784
J. Chem. Theory Comput.
(2019),
15,
pp. 2246.
827
(2022),
18,
pp. 1017.
which are multi-configurational in nature.
Under the two-state approximation, the diabatic reactant and product states are assumed to be a linear combination of the eigenstates. For ET, the choice of such linear combination is determined by a zero transition dipoles (GMH) or maximum charge differences (FCD). In the latter, a donor–acceptor charge difference matrix, , is defined, with elements
| (10.130) |
where is the matrix element of the density operator between states and .
For EET, a maximum excitation difference is assumed in the FED, in which an excitation difference matrix is similarly defined with elements
| (10.131) |
where is the sum of attachment and detachment densities for transition , as they correspond to the electron and hole densities in an excitation. In the FSD, a maximum spin difference is used and the corresponding spin difference matrix is defined with its elements as,
| (10.132) |
where is the spin density, difference between -spin and -spin densities, for transition from .
Since Q-Chem uses a Mulliken population analysis for the integrations in Eqs. (10.130), (10.131), and (10.132), the matrices , and are not symmetric. To obtain a pair of orthogonal states as the diabatic reactant and product states, , and are symmetrized in Q-Chem. Specifically,
| (10.133a) | ||||
| (10.133b) | ||||
| (10.133c) | ||||
The final coupling values are obtained as listed below:
For GMH,
| (10.134) |
For FCD,
| (10.135) |
For FED,
| (10.136) |
For FSD,
| (10.137) |
Q-Chem provides the option to control FED, FSD, FCD and GMH calculations after a single-excitation calculation, such as CIS and TDDFT. To obtain ET coupling values using GMH (FCD) scheme, one should set $rem variables STS_GMH (STS_FCD) to be TRUE. Similarly, a FED (FSD) calculation is turned on by setting the $rem variable STS_FED (STS_FSD) to be TRUE. In FCD, FED and FSD calculations, the donor and acceptor fragments are defined via the $rem variables STS_DONOR and STS_ACCEPTOR. It is necessary to arrange the atomic order in the $molecule section such that the atoms in the donor (acceptor) fragment is in one consecutive block. The ordering numbers of beginning and ending atoms for the donor and acceptor blocks are included in $rem variables STS_DONOR and STS_ACCEPTOR.
The couplings will be calculated between all choices of excited states with the same spin. In FSD, FCD and GMH calculations, the coupling value between the excited and reference (ground) states will be included, but in FED, the ground state is not included in the analysis. It is important to select excited states properly, according to the distribution of charge or excitation, among other characteristics, such that the coupling obtained can properly describe the electronic coupling of the corresponding process in the two-state approximation.
Within the ambit of the single excitation theory such as the CIS or TDDFT,
one can easily obtain analytical expressions for the matrix elements of
the excitation density and can therefore, use Eq. 10.136 to compute
electronic couplings between adiabatic states. However, for multiexcitation wavefunctions
such as those obtained from RAS-CI no simple expressions exist for the
off-diagonal elements in the excitation difference ( in Eq. 10.136).
To circumvent this challenge, a new scheme was developed known as
-FED
698
(2018),
14,
pp. 1304.
784
(2019),
15,
pp. 2246.
827
(2022),
18,
pp. 1017.
In this approach, the diabatic states are assumed to be functions of a mixing angle .
Consequently, the excitation difference density ( in Eqs 10.131 and
10.136) is dependent on . In order to obtain ‘ideal’ diabatic states,
a scan of is performed from to to maximize the difference of
the excitation, i.e.,
| (10.138) |
with ‘i’ and ‘f’ indicating the initial and final diabatic states, respectively. The corresponding -dependent coupling can then be written as
| (10.139) |
Fortunately, one can still use Eq. 10.135 to compute ET couplings between two adiabatic states for FCD with RAS-CI. This is because the charge difference matrix ( in Eqs 10.130 and 10.135) depends on the one-particle (for ) and transition density matrices (for ), which are also easily obtainable with the RAS-CI wavefunctions.
The $rem variables STS_FED, STS_FCD, STS_DONOR, and STS_ACCEPTOR also apply to FCD and FED calculations with RAS-CI.
STS_GMH
STS_GMH
Control the calculation of GMH for ET couplings.
Do not perform a GMH calculation.
Include a GMH calculation.
When set to true computes Mulliken-Hush electronic couplings. It yields
the generalized Mulliken-Hush couplings as well as the transition dipole
moments for each pair of excited states and for each excited state with
the ground state.
STS_FCD
STS_FCD
Control the calculation of FCD for ET couplings.
Do not perform an FCD calculation.
Include an FCD calculation.
STS_FED
STS_FED
Control the calculation of FED for EET couplings.
Do not perform a FED calculation.
Include a FED calculation.
STS_FSD
STS_FSD
Control the calculation of FSD for EET couplings.
Do not perform a FSD calculation.
Include a FSD calculation.
For RCIS triplets, FSD and FED are equivalent. FSD will be automatically
switched off and perform a FED calculation.
STS_DONOR
STS_DONOR
Define the donor fragment.
No donor fragment is defined.
Donor fragment is in the th atom to the th atom.
Note no space between the hyphen and the numbers and .
STS_ACCEPTOR
STS_ACCEPTOR
Define the acceptor molecular fragment.
No acceptor fragment is defined.
Acceptor fragment is in the th atom to the th atom.
STS_MOM
STS_MOM
Control calculation of the transition moments between excited states in
CIS and TDDFT calculations (including spin-flip variants).
Do not calculate state-to-state transition moments.
Do calculate state-to-state transition moments.
When set to true requests the state-to-state dipole transition moments for
all pairs of excited states and for each excited state with the ground
state. This is not available for restricted open-shell wavefunctions.
Example 10.57 A GMH & FCD calculation to analyze electron transfer couplings in an ethylene and a methaniminium cation.
$molecule 1 1 C 0.679952 0.000000 0.000000 N -0.600337 0.000000 0.000000 H 1.210416 0.940723 0.000000 H 1.210416 -0.940723 0.000000 H -1.131897 -0.866630 0.000000 H -1.131897 0.866630 0.000000 C -5.600337 0.000000 0.000000 C -6.937337 0.000000 0.000000 H -5.034682 0.927055 0.000000 H -5.034682 -0.927055 0.000000 H -7.502992 -0.927055 0.000000 H -7.502992 0.927055 0.000000 $end $rem METHOD CIS BASIS 6-31+G CIS_N_ROOTS 20 CIS_SINGLETS true CIS_TRIPLETS false STS_GMH true !turns on the GMH calculation STS_FCD true !turns on the FCD calculation STS_DONOR 1-6 !define the donor fragment as atoms 1-6 for FCD calc. STS_ACCEPTOR 7-12 !define the acceptor fragment as atoms 7-12 for FCD calc. MEM_STATIC 200 !increase static memory for a CIS job with larger basis set $end
Example 10.58 An FED calculation to analyze excitation energy transfer couplings in a pair of stacked ethylenes.
$molecule 0 1 C 0.670518 0.000000 0.000000 H 1.241372 0.927754 0.000000 H 1.241372 -0.927754 0.000000 C -0.670518 0.000000 0.000000 H -1.241372 -0.927754 0.000000 H -1.241372 0.927754 0.000000 C 0.774635 0.000000 4.500000 H 1.323105 0.936763 4.500000 H 1.323105 -0.936763 4.500000 C -0.774635 0.000000 4.500000 H -1.323105 -0.936763 4.500000 H -1.323105 0.936763 4.500000 $end $rem METHOD CIS BASIS 3-21G CIS_N_ROOTS 20 CIS_SINGLETS true CIS_TRIPLETS false STS_FED true STS_DONOR 1-6 STS_ACCEPTOR 7-12 $end
Example 10.59 A RAS-FCD calculation to analyze electron transfer couplings in an ethylene dimer.
$comment RASCI for Hole Transfer Stacked-Ethylene / DZ* $end $molecule 1 2 C 0.670518 0.000000 0.000000 H 1.241372 0.927754 0.000000 H 1.241372 -0.927754 0.000000 C -0.670518 0.000000 0.000000 H -1.241372 -0.927754 0.000000 H -1.241372 0.927754 0.000000 C 0.774635 0.000000 4.000000 H 1.323105 0.936763 4.000000 H 1.323105 -0.936763 4.000000 C -0.774635 0.000000 4.000000 H -1.323105 -0.936763 4.000000 H -1.323105 0.936763 4.000000 $end $rem JOBTYPE SP BASIS DZ* CORRELATION RASCI UNRESTRICTED FALSE RAS_ROOTS 5 RAS_ACT 4 RAS_ELEC_ALPHA 2 RAS_ELEC_BETA 1 RAS_OCC 14 STS_FCD TRUE STS_ACCEPTOR 1-6 STS_DONOR 7-12 RAS_SPIN_MULT 1 $end
Example 10.60 A RAS-FED calculation to analyze excitation energy transfer couplings in an ethylene dimer.
$comment RASCI for Excitation Energy Transfer Stacked-Ethylene / DZ* $end $molecule 0 1 C 0.670518 0.000000 0.000000 H 1.241372 0.927754 0.000000 H 1.241372 -0.927754 0.000000 C -0.670518 0.000000 0.000000 H -1.241372 -0.927754 0.000000 H -1.241372 0.927754 0.000000 C 0.774635 0.000000 4.000000 H 1.323105 0.936763 4.000000 H 1.323105 -0.936763 4.000000 C -0.774635 0.000000 4.000000 H -1.323105 -0.936763 4.000000 H -1.323105 0.936763 4.000000 $end $rem JOBTYPE SP BASIS DZ* CORRELATION RASCI UNRESTRICTED FALSE RAS_ROOTS 5 RAS_ACT 4 RAS_ELEC_ALPHA 2 RAS_ELEC_BETA 2 RAS_OCC 14 STS_FED TRUE STS_ACCEPTOR 1-6 STS_DONOR 7-12 RAS_SPIN_MULT 1 $end
When dealing with multiple charge or electronic excitation centers, diabatic
states can be constructed with Boys
1235
J. Chem. Phys.
(2008),
129,
pp. 244101.
or
Edmiston-Ruedenberg
1231
J. Chem. Phys.
(2009),
130,
pp. 234102.
localization. In this case, we
construct diabatic states as linear
combinations of adiabatic states with
a general rotation matrix that is in
size:
| (10.140) |
The adiabatic states can be produced with any method, in principle, but the Boys/ER-localized diabatization methods have been implemented thus far only for CIS, TDDFT or RASCI (section 7.12.6) methods in Q-Chem. In analogy to orbital localization, Boys-localized diabatization corresponds to maximizing the charge separation between diabatic state centers:
| (10.141) |
Here, represents the dipole operator. ER-localized diabatization prescribes maximizing self-interaction energy:
| (10.142) |
where the density operator at position is
| (10.143) |
Here, represents the position of the th electron.
These models reflect different assumptions about the interaction of our quantum
system with some fictitious external electric field/potential: if we
assume a fictitious field that is linear in space, we arrive at Boys
localization; if we assume a fictitious potential energy that responds
linearly to the charge density of our system, we arrive at ER localization.
Note that in the two-state limit, Boys localized diabatization reduces nearly
exactly to GMH.
1235
J. Chem. Phys.
(2008),
129,
pp. 244101.
As written down in Eq. (10.141), Boys localized diabatization
applies only to charge transfer, not to energy transfer. Within the context of
CIS or TDDFT calculations, one can easily extend Boys localized
diabatization
1234
J. Phys. Chem. A
(2010),
114,
pp. 8665.
by separately localizing the occupied and virtual components of ,
and :
| (10.144) |
where
| (10.145) |
and the occupied/virtual components are defined by
Note that when we maximize the Boys OV function, we are simply performing Boys-localized diabatization separately on the electron attachment and detachment densities.
Finally, for energy transfer, it can be helpful to understand the origin of the
diabatic couplings. To that end, we now provide the ability to decompose the
diabatic coupling between diabatic states into Coulomb (J), Exchange (K) and
one-electron (O) components:
1317
J. Phys. Chem. C
(2010),
114,
pp. 20449.
| (10.147) | |||||
BOYS_CIS_NUMSTATE
BOYS_CIS_NUMSTATE
Define how many states to mix with Boys localized diabatization. These states must be specified
in the $localized_diabatization section.
Do not perform Boys localized diabatization.
2 to N where N is the number of CIS states requested (CIS_N_ROOTS)
It is usually not wise to mix adiabatic states that are separated by more than a few eV
or a typical reorganization energy in solvent.
ER_CIS_NUMSTATE
ER_CIS_NUMSTATE
Define how many states to mix with ER localized diabatization. These states must be specified
Do not perform ER localized diabatization.
LOC_CIS_OV_SEPARATE
LOC_CIS_OV_SEPARATE
Decide whether or not to localized the “occupied” and “virtual” components
of the localized diabatization
function, i.e., whether to localize the electron attachments and detachments separately.
Do not separately localize electron attachments and detachments.
If one wants to use Boys localized diabatization for energy transfer (as
opposed to electron transfer) , this is a necessary option. ER is more
rigorous technique, and does not require this OV feature, but will be somewhat
slower.
CIS_DIABATH_DECOMPOSE
Decide whether or not to decompose the diabatic coupling into Coulomb,
exchange, and one-electron terms.
Do not decompose the diabatic coupling.
These decompositions are most meaningful for electronic excitation transfer processes.
Currently, available only for CIS, not for TDDFT diabatic states.
Example 10.61 A calculation using ER localized diabatization to construct the diabatic Hamiltonian and couplings between a square of singly-excited Helium atoms.
he 0 -1.0 1.0
he 0 -1.0 -1.0
he 0 1.0 -1.0
he 0 1.0 1.0
METHOD cis
CIS_N_ROOTS 4
CIS_SINGLETS false
CIS_TRIPLETS true
BASIS 6-31g**
SCF_CONVERGENCE 8
RPA false
LOC_CIS_OV_SEPARATE false ! NOT localizing attachments/detachments separately.
ER_CIS_NUMSTATE 4 ! using ER to mix 4 adiabatic states.
CIS_DIABATh_DECOMPOSE true ! decompose diabatic couplings into
! Coulomb, exchange, and one-electron components.
INTEGRAL_SYMMETRY false
POINT_GROUP_SYMMETRY false
On the next line, list which excited adiabatic states we want to mix.
1 2 3 4
