For a molecule of fixed size, increasing the number of basis functions
per atom, , leads to growth in the number of significant
four-center two-electron integrals, since the number of non-negligible product
charge distributions, , grows as . As a result, the use
of large (high-quality) basis expansions is computationally costly. Perhaps
the most practical way around this “basis set quality” bottleneck is the use
of auxiliary basis expansions.
360
Chem. Phys. Lett.
(1993),
208,
pp. 359.
331
Phys. Chem. Chem. Phys.
(2000),
2,
pp. 2113.
620
Proc. Natl. Acad. Sci. USA
(2005),
102,
pp. 6692.
The ability to use auxiliary basis sets to accelerate a variety of electron
correlation methods, including both energies and analytical gradients, is a
major feature of Q-Chem.
The auxiliary basis is used to approximate products of Gaussian basis functions:
| (6.19) |
Auxiliary basis expansions were introduced long ago, and are now widely recognized as an effective and powerful approach, which is sometimes synonymously called resolution of the identity (RI) or density fitting (DF). When using auxiliary basis expansions, the rate of growth of computational cost of large-scale electronic structure calculations with is reduced to approximately .
If is fixed and molecule size increases, auxiliary basis expansions reduce the pre-factor associated with the computation, while not altering the scaling. The important point is that the pre-factor can be reduced by 5 or 10 times or more. Such large speedups are possible because the number of auxiliary functions required to obtain reasonable accuracy, , has been shown to be only about 3 or 4 times larger than .
The auxiliary basis expansion coefficients, , are determined by minimizing the deviation between the fitted distribution and the actual distribution, , which leads to the following set of linear equations:
| (6.20) |
| (6.21) |
In the limit where the auxiliary basis is complete (i.e. all products of AOs are included), the fitting procedure described above will be exact. However, the auxiliary basis is invariably incomplete (as mentioned above, because this is essential for obtaining increased computational efficiency.
Standardized auxiliary basis sets have been developed by the Karlsruhe group
for second-order perturbation (MP2) calculations of the correlation
energy.
1337
Chem. Phys. Lett.
(1998),
294,
pp. 143.
1339
J. Chem. Phys.
(2002),
116,
pp. 3175.
Using these basis sets, absolute
errors in the correlation energy are small (e.g., below 60 Hartree per
atom), and errors in relative energies are smaller still At the same time,
speedups of 3–30 are realized. This development has made the routine
use of auxiliary basis sets for electron correlation calculations possible.
Correlation calculations that can take advantage of auxiliary basis expansions are described in the remainder of this section (MP2, and MP2-like methods) and in Section 6.18 (simplified active space coupled cluster methods such as PP, PP(2), IP, RP). These methods automatically employ auxiliary basis expansions when a valid choice of auxiliary basis set is supplied using the AUX_BASIS_CORR or AUX_BASIS keyword which is used in the same way as the BASIS keyword. The PURECART $rem is no longer needed here, even if using a auxiliary basis that does not have a predefined value. There is a built-in automatic procedure that provides the effect of the PURECART $rem in these cases by default.
