The following $rem variables can be used to control the calculation of anharmonic frequencies.
ANHAR
ANHAR
Performing various nuclear vibrational theory (TOSH, VPT2, VCI) calculations
to obtain vibrational anharmonic frequencies.
Carry out the anharmonic frequency calculation.
Do harmonic frequency calculation.
Since this calculation involves the third and fourth derivatives at the
minimum of the potential energy surface, it is recommended that the
GEOM_OPT_TOL_DISPLACEMENT, GEOM_OPT_TOL_GRADIENT and
GEOM_OPT_TOL_ENERGY tolerances are set tighter. Note that VPT2
calculations may fail if the system involves accidental degenerate resonances.
See the VCI $rem variable for more details about increasing the
accuracy of anharmonic calculations.
VCI
VCI
Specifies the number of quanta involved in the VCI calculation.
User-defined. Maximum value is 10.
The availability depends on the memory of the machine. Memory allocation for
VCI calculation is the square of
with double
precision. For example, a machine with 1.5 GB memory and for molecules with
fewer than 4 atoms, VCI(10) can be carried out, for molecule containing fewer
than 5 atoms, VCI(6) can be carried out, for molecule containing fewer than 6
atoms, VCI(5) can be carried out. For molecules containing fewer than 50
atoms, VCI(2) is available. VCI(1) and VCI(3) usually overestimated the true
energy while VCI(4) usually gives an answer close to the converged energy.
FDIFF_DER
FDIFF_DER
Controls what types of information are used to compute higher
derivatives. The default uses a combination of energy, gradient and Hessian
information, which makes the force field calculation faster.
3
for jobs where analytical 2nd derivatives are available.
for jobs with ECP.
Use energy information only.
Use gradient information only.
Use Hessian information only.
3
Use energy, gradient, and Hessian information.
When the molecule is larger than benzene with small basis set,
FDIFF_DER = 2 may be faster. Note that FDIFF_DER will be set
lower if analytic derivatives of the requested order are not available. Please
refers to IDERIV.
MODE_COUPLING
MODE_COUPLING
Number of modes coupling in the third and fourth derivatives calculation.
for two modes coupling.
for modes coupling, Maximum value is 4.
Use the default.
IGNORE_LOW_FREQ
IGNORE_LOW_FREQ
Low frequencies that should be treated as rotation can be ignored during
anharmonic correction calculation.
300
Corresponding to 300 cm.
Any mode with harmonic frequency less than will be ignored.
Use the default.
FDIFF_STEPSIZE_QFF
FDIFF_STEPSIZE_QFF
Displacement used for calculating third and fourth derivatives by finite difference.
5291
Corresponding to 0.1 bohr. For calculating third and fourth derivatives.
Use a step size of .
Use the default, unless the potential surface is very flat, in which case a larger value
should be used.
Example 10.39 A four-quanta anharmonic frequency calculation on formaldehyde at the EDF2/6-31G* optimized ground state geometry, which is obtained in the first part of the job. It is necessary to carry out the harmonic frequency first and this will print out an approximate time for the subsequent anharmonic frequency calculation. If a FREQ job has already been performed, the anharmonic calculation can be restarted using the saved scratch files from the harmonic calculation.
C
O, 1, CO
H, 1, CH, 2, A
H, 1, CH, 2, A, 3, D
CO = 1.2
CH = 1.0
A = 120.0
D = 180.0
JOBTYPE OPT
METHOD EDF2
BASIS 6-31G*
GEOM_OPT_TOL_DISPLACEMENT 1
GEOM_OPT_TOL_GRADIENT 1
GEOM_OPT_TOL_ENERGY 1
READ
JOBTYPE FREQ
METHOD EDF2
BASIS 6-31G*
ANHAR TRUE
VCI 4
Anharmonic frequencies can also be computed using the partial Hessian approximation (see Section 10.7.4).
ANHAR_SEL
ANHAR_SEL
Select a subset of normal modes for subsequent anharmonic frequency analysis.
Use all normal modes
Select subset of normal modes
Example 10.40 This example shows an anharmonic frequency calculation for ethene where only the C–H stretching modes are included in the anharmonic analysis.
$comment ethene restricted anharmonic frequency analysis $end $molecule 0 1 C 0.6665 0.0000 0.0000 C -0.6665 0.0000 0.0000 H 1.2480 0.9304 0.0000 H -1.2480 -0.9304 0.0000 H -1.2480 0.9304 0.0000 H 1.2480 -0.9304 0.0000 $end $rem JOBTYPE freq METHOD hf BASIS sto-3g ANHAR_SEL TRUE N_SOL 4 $end $alist 9 10 11 12 $end
